Like Tree26Likes
Old 03-20-2013, 07:33 PM   #10636
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by ekt View Post
Savox 1257TG super fast and has handled all the crashing I do. Also matches all my exotek bling
+1
nolimit208 is offline   Reply With Quote
Old 03-21-2013, 07:57 AM   #10637
jsp619's Avatar
Originally Posted by coltsfan View Post
My Dex210 is on the way. I am looking for a good servo for my buggy. I have a Green Radiopost in my Durango 4x4, which is great. Is it overkill for the buggy? I have never tried a Protek. Any suggestions?
I am using a hitec 7940 super fast and more toque then the buggy could ever use, plus Hitec titanium gears trains are bullet proof.
Xray XB913, NOVA Engines
Associated B5, LRP Speedo, Reedy Motors
Futaba 4PLS
Hi-Tec Servos
jsp619 is offline   Reply With Quote
Old 03-21-2013, 08:33 AM   #10638
Trader Rating: 74 (100%+)
Hitec 7940 in all my cars. I am changing one at a time to the hitec 8360 . Its the latest mega servo.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-21-2013, 09:48 AM   #10639
singlemike's Avatar
Can you guys recommend the dimec +8mm chassis or the dimec20? I run indoor clay track- more of an 1/8 scale with large jumps. Would the dimec have too much flex?
singlemike is offline   Reply With Quote
Old 03-21-2013, 09:52 AM   #10640
murky123's Avatar
depends on how high or low your grip level is. high grip level demands the dimec20
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 03-21-2013, 10:21 AM   #10641
Trader Rating: 21 (100%+)
"Ideal for 20-120 class aircraft, all EP 600-700, and GP .30-.90
class helicopters, 1/10-1/4 scale vehicle steering"
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LNCJVN
It sounds like a great servo but I'm going to have to call BS on the 1/4 scale steering application of it.
mulepic is offline   Reply With Quote
Old 03-21-2013, 10:39 AM   #10642
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by P6 View Post
the 1251 no servo saver is bound to break sometime if you land wrong go with titanium gears , ive had the 1256 1258 and now the 1251 after fixing the gears the 1256 was way overpowered and the 1258 is 10g heavier than the 1251 but you wont notice the differences in performance speed im not putting the 1251 down yet but i am only gonna use plastic horns and cross my fingers 10mm more forward makes a big difference with a 200g shorty or you can fit the receiver behind the servo with the front battery stop on mount holes closer to the rear and offset that and the esc mounted in the rear battery tray to the opposite side of the motor hanging out and servo horn for almost perfect left to right balance
If you're having issues with servos breaking, this is a great solution. http://www3.omnimodels.com/cgi-bin/w...=WR&I=TDRC4912
Fishhook
ewashburnaf is offline   Reply With Quote
Old 03-21-2013, 01:10 PM   #10643
P6
havent seen that one before i was afraid of clearance with the other savers ive seen , itll be on my buggy as soon as the mail gets here thanks
P6 is offline   Reply With Quote
Old 03-21-2013, 01:26 PM   #10644
murky123's Avatar
I dont understand how peeps are breaking metal geared servo's
I never use servosavers, not in my scaler, 4x4 SC, 2wd SC, 2wd Buggy,
never stripped a servo in the last 4 years.
I use savox and ace
Old 03-21-2013, 03:37 PM   #10645
Oasis's Avatar
Trader Rating: 36 (100%+)
I use savox and ace
....I've been racing for 25 years and have NEVER stripped a servo..had a few that quit working (solved that problem..don't use hitec anymore)....but just an FYI the Durango servo saver is junk..your steering will suffer for sure.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 03-21-2013, 03:43 PM   #10646
Woulvesbaine's Avatar
And back to ball cups. The only ball cups that seem to pop off with any frequency for me are one on the steering ackerman plate (320124-12) and one on the left camber link. The rear camber link is a new issue so this is just wear but the ackerman plate one has been popping off from the start.
What do I need or what is a good solution to deal with just the ackerman plate ball and the steering link cup that links to it? I don't think I need or want to change all the balls and ballcups.
Thanks!
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 03-21-2013, 03:44 PM   #10647
SOuthernFRIED's Avatar
Picked up a used dex210 today.. Can't wait till it gets here and I get it setup. Since running the DESC410v2 I am turning into a big Durango fan. I will be running on a loose outdoor 1/8th scale track. Any tips or must haves?
James Cooper
SouthernFriedRacing
[email protected]
SOuthernFRIED is offline   Reply With Quote
Old 03-21-2013, 04:00 PM   #10648
The stock ball cups sucks. It can not be, that i need 3 tools in the same time to adjust the turnbuckles like dirango shows on there site.
If i try to adjust the turnbuckle wirh one tool, the ball cup pop off. This sucks. I never had rc car, where the ball cups pop off by adjusting the turnbuckles.
I have brand new hd ball cups on my dex210.
This thinks let me thinking about to switching the brand.
mihaelbencek is offline   Reply With Quote
Old 03-21-2013, 04:02 PM   #10649
I have heard the RPM or AE ball cups will work.. I bought the Lunsford kit for my DESC410.. Pricey but haven't had a single issue.
James Cooper
SouthernFriedRacing
[email protected]
Old 03-21-2013, 04:04 PM   #10650
This big issue must be fixed by durango
St Ives RC Club B4Bandit Australian Racing 16570 Yesterday 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
