Like Tree43Likes
Old 03-17-2013, 12:46 PM   #10606
sc10pc's Avatar
piston setup is stock i think it is the 6 hole and all the fast guys at my track run the light blue springs all around.
Ofna Nexx 10SC: Novak Ballistic 550 4.5t, Novak GTB2, Orion Vortex 1007
Durango DEX210: Tacon 8.5t sensored, Duratrax DE10, Savox SC1257TG
Team Associated B44.1: Viper VST6.5T, Duratrax DE10, Orion Vortex 1007
RETIRED: Team Associated B44
sc10pc is offline   Reply With Quote
Old 03-17-2013, 03:36 PM   #10607
TAMAK's Avatar
Trader Rating: 28 (100%+)
Originally Posted by nolimit208 View Post
@SC10PC...Petit is a great place to read up. But be VERY careful with the factory guys setups.. For example, Jorns setups shows a modified rear hinge pins changing the kickup, but ALL the drivers were running that and some dont show that in the setups.. Also he was running AE rear hubs and CVD's.. But for shock set, etc. its a great place to start.
A shorty pack is a MUST for this car. And if you can get the Dimec chassis, it will make a world of difference as its easier to set the car up with the plastic chassis (more flex). Also Light blue is VERY soft in the rear. To get it to rotate, I would get a losi Pink on the rear or Durango Dark green. Where do you race?
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 03-17-2013, 08:04 PM   #10608
Rob Phillips's Avatar
My current shock setup:
Front
1.3x4 piston Losi 32.5wt
TLR 22 Red Spring
Rear
1.3x4 piston Losi 27.5wt
TLR 22 Yellow Spring
*Note: I'm using the stock 1.3 x 6 pistons with two holes glued closed (CA'd the tip of a toothpick into place then cut flush) making it a 1.3 x 4 piston.
I think I need to be a little heavier on the front spring, but over all it feels pretty good.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 03-17-2013, 08:42 PM   #10609
Trader Rating: 74 (100%+)
Front
TLR 22 Red Spring
Rear
Oh yeah. Ill have my latest update soon.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-18-2013, 02:33 AM   #10610
sweet, you know where to send it
Old 03-18-2013, 07:16 PM   #10611
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Default Cactus Classic final Setup
Here is my final setup used at cactus classic. I opted to stay rear motor.
I have the rear hinge pin holder mod where you sand off 2mm off the bottom.
I didn't race all my heats mainly in phx to visit friends and raced on the side, but car was handling very well with plenty of steering.
Setup Sheet is on my google docs Listed below
https://docs.google.com/file/d/0B0Ab...it?usp=sharing
nolimit208 is offline   Reply With Quote
Old 03-18-2013, 08:05 PM   #10612
nolimit208's Avatar
petitrc link for setup
http://www.petitrc.com/setup/durango...sic2013031517/
Old 03-18-2013, 09:40 PM   #10613
rcjunky1's Avatar
do you dremel off 2mm and still use the 3* block for 6* of antisquate overal, or just the 0* block for 3* overal?
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 03-18-2013, 10:02 PM   #10614
nolimit208's Avatar
Originally Posted by TAMAK View Post
So to to be clear. The rear shock mounted to the rear of the arm is new.. Hupo stated eos was the first race they tried the setup snd dirt was next, but not sure when. Now, to do the mod, all i did to the arms was mount the left on the right and the right on the left. This does not effect toe or wheelbase. And then cut clearance on the wing for the shocks and done. Some people will nock the idea but i enjoy testing and tweaking, this may or may not work for you period! But to say it wont work is just being small minded. Test On!
I am going to be trying this mod on my local indoor clay. I am hoping with the weight of the shocks being more towards the back it will allow me to run my battery further forward gaining off power steering.
Old 03-18-2013, 10:05 PM   #10615
nolimit208's Avatar
I updated my sheet on the google docs, I have a 0 block when I use the -2mm rear hinge pin holder.
Cornering seems to be more stable on high bite tracks, which cactus was and my local track is also.
Old 03-18-2013, 10:06 PM   #10616
P6
Yes I was just gonna ask about this I have a 1.5 kick up 3 toe in rf if I shave 1mm off the RR block what would I have for kick up I'm looking to buying a lighter rf with less kick up the brass is making me use odd springs combinations to compensate for the weight in the rear and battery placment is never full forward its usually to much I can drop 16g off my rf by not using brass and another 10g under servo to get lighter overall
P6 is offline   Reply With Quote
Old 03-18-2013, 10:21 PM   #10617
nolimit208's Avatar
You would be right around 3, rcjunky can comment better on the actual kickup since he makes them and knows their exact measurements though.
And how to do it, I used a belt sander, mounted the rr block on the bottom of the chassis with 2 screw going through the chassis into the top of the rr block so the bottom part of the rr block is accessible to the sander. This provides better results and is a lot cleaner then trying to dremel it.
Old 03-18-2013, 10:25 PM   #10618
P6
I was gonna go old school to make sure I don't over do it , block of wood and some sand paper to make sure its even
Old 03-18-2013, 10:28 PM   #10619
nolimit208's Avatar
That would work just fine, just measure with your calipers ever few seconds and you should be good.
if you sand off too much you can always shim it up to get the right amount
Old 03-19-2013, 06:29 AM   #10620
So this makes a lrc block 2 kick up approximately. ? You could also shave the front and rear equally too.
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
