Like Tree43Likes
Old 03-15-2013, 10:56 PM   #10591
Originally Posted by Khador12 View Post
Did anyone else notice the bigger gear cover on Jorn's car?
Avid slipper
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 03-16-2013, 12:25 AM   #10592
P6
Anyone have any tips for storing springs I noticed that my old light blue springs that I haven't used on my buggy almost since I've had it have almost no paint left after I ran my finger across them a couple times , kinda made me worry if its td I have losi springs and the coating on them is fine and they have seen a lot more use by me I do the matinence and I go a while without going to the track so I tear down about half the time when I'm bored so they were clean and dry and kept at 65-70*
P6 is offline   Reply With Quote
Old 03-16-2013, 04:36 AM   #10593
interesting, mid motor on dirt
mihaelbencek is offline   Reply With Quote
Old 03-16-2013, 04:45 AM   #10594
ekt
ekt's Avatar
sugar treated track, super high grip
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 03-16-2013, 05:29 AM   #10595
maybe the new mid motor buggys has a good chance go good with mid motor on loose tracks?
Old 03-16-2013, 08:22 AM   #10596
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
I run in a stock buggy class (17.5 blinky). The track I run is small with a lot of turns. It's also blue groove clay in door track. I'm looking for a good set up for my buggy. All the ones I have seen are for mod class and they are running 8.5's with a 81 spur and 23 or 24 pinion gears and stuff. Would anyone know a good set up I could run? Not just looking for gear setup but the whole chassis set up.
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 03-16-2013, 09:06 AM   #10597
Oasis's Avatar
Trader Rating: 36 (100%+)
Don't forget super high tire wear..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 03-16-2013, 09:11 AM   #10598
Oasis's Avatar
Is this for 17.5? And what chassis? Their is a difference between the stock and the +8..on the gearing I'm at 34/69 and I "think" I should be at 35/69 or 36/69 to get a bit more speed on the straights. I also race on a small, tight indoor track..I do have a few set-ups that work pretty good..but I'm not a "self professed" expert..
Old 03-16-2013, 10:07 AM   #10599
yes, 17.5.
Don't really have a stright away at the track I race at. Here is where I race. This is one of the Mains I was in. Started in 7th and finished out in 3rd. Not bad huh.
https://www.youtube.com/watch?featur...&v=upYxT-TxvEo
Old 03-16-2013, 02:36 PM   #10600
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
I put my springs in small zip lock bags that are almost the size of the springs and I write the compression rate on the bags. I got the bags at hobby lobby.
nolimit208 is offline   Reply With Quote
Old 03-16-2013, 07:56 PM   #10601
i use these nalgene airtight bottles from container store:
http://www.containerstore.com/shop/t...sort_default|0
the one on the far right (the 1 oz. bottle) i use for rear springs, the far left fits front springs (the 0.6 oz bottle). and then I p-touch label the brand of the spring, the color spring and its spring rate.
glenng is offline   Reply With Quote
Old 03-16-2013, 10:12 PM   #10602
TAMAK's Avatar
Trader Rating: 28 (100%+)
Originally Posted by knowitall156 View Post
Avid slipper
I saw it on travis and carsons car as well. I bet its a Team Durango part, too many custom pieces for avid to deviate from AE and TLR.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 03-17-2013, 09:12 AM   #10603
sc10pc's Avatar
hey guys i want to know if you have any good setups for rm3 for an indoor clay track? right now i am running:
front:
35wt
light blue spring
outer hole arm
middle hole tower
exotek 20g weight
using stick pack in the middle of the car
rear:
30wt
light blue spring
outer hole arm
middle hole tower.
i cannot for the life of me geth this thing to get stable on power and im having troubles on certain corners getting it to turn tight enough it just wants to push around or slide out. thinking about trying the rear shock mounting as stated earlier in this forum but idk. what are your guys setups?
Ofna Nexx 10SC: Novak Ballistic 550 4.5t, Novak GTB2, Orion Vortex 1007
Durango DEX210: Tacon 8.5t sensored, Duratrax DE10, Savox SC1257TG
Team Associated B44.1: Viper VST6.5T, Duratrax DE10, Orion Vortex 1007
RETIRED: Team Associated B44
sc10pc is offline   Reply With Quote
Old 03-17-2013, 11:40 AM   #10604
front:
35wt
light blue spring
outer hole arm
middle hole tower
exotek 20g weight
rear:
30wt
light blue spring
outer hole arm
middle hole tower.
well if you are pushing, you need more front traction/grip in addition to getting your rear to stick. i'd move pack all the way back. if that doesnt help reaR, then you need a different tire and/or compound. check with the fast guys and see what they got on their cars. with pack all the way back, maybe the 30 gram mass can help more front end grip. i run on clay indoor and use 25 degree caster (zero insert) up front and inline axle setup with 4mm spacing in front of the caster block on the outside of a-arm. it works for me. i get a lotta steering. you never specified piston setup so i got no comment on your shocks setup with the exception of saying its really soft springs you got going on.
Old 03-17-2013, 12:39 PM   #10605
nolimit208's Avatar
front:
35wt
light blue spring
outer hole arm
middle hole tower
exotek 20g weight
rear:
30wt
light blue spring
outer hole arm
middle hole tower.
http://www.petitrc.com/setup/durango...ngoDEX210.html
St Ives RC Club B4Bandit Australian Racing 16581 11-23-2017 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
