Like Tree26Likes
Old 03-14-2013, 02:53 PM   #10576
TAMAK's Avatar
Trader Rating: 28 (100%+)
So to to be clear. The rear shock mounted to the rear of the arm is new.. Hupo stated eos was the first race they tried the setup snd dirt was next, but not sure when. Now, to do the mod, all i did to the arms was mount the left on the right and the right on the left. This does not effect toe or wheelbase. And then cut clearance on the wing for the shocks and done. Some people will nock the idea but i enjoy testing and tweaking, this may or may not work for you period! But to say it wont work is just being small minded. Test On!
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 03-14-2013, 03:13 PM   #10577
GregerL's Avatar
Agree that the toe won't be affected, but looking at the arms they are asymmetrical where the hub goes, so if you don't change your shimming this operation should give you a couple of mm extra wheel base, moving the rear wheels a bit further back, or is there something that I am missing out on?
GregerL is offline   Reply With Quote
Old 03-14-2013, 03:21 PM   #10578
TAMAK's Avatar
Ill look at that again. Edit: Took some arms out of the package and i found that the wheelbase will not be affected as the arms are symetrical looking at the pins and pin gap alignment
Old 03-14-2013, 03:40 PM   #10579
Trader Rating: 62 (100%+)
8ight-e, I actually have the droop limited about 5mm, so that's not it. And that still wouldn't explain why it only happens to one side.
TEKNO RC * TLR * EXOTEK
patrick is offline   Reply With Quote
Old 03-14-2013, 04:54 PM   #10580
P6
how does your wheel hub look on that side is the pin bent or anything im sure you had it apart by now to check, im thinking you may have the wrong spring , on mine had this issue when i bought it the diff and slipper spring were close to the same length if you count the number of coils it should be no more than four on the diff or the length compressed would change (so nut out to far)
P6 is offline   Reply With Quote
Old 03-14-2013, 05:37 PM   #10581
Trader Rating: 74 (100%+)
Guys I ran the +10 Tresrey chassis this weekend. Let's just say it is the best my car has been to date. It's super consistent, easy to drive, and very comfortable. I did go back to 4 hole pistons, I felt more safe with this setup. I'll test more soon with 2 hole pistons soon. Proline Velocity wheels are the bomb!
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 03-14-2013, 06:42 PM   #10582
Trader Rating: 21 (100%+)
Originally Posted by Raul Garcia View Post
Guys I ran the +10 Tresrey chassis this weekend. Let's just say it is the best my car has been to date. It's super consistent, easy to drive, and very comfortable. I did go back to 4 hole pistons, I felt more safe with this setup. I'll test more soon with 2 hole pistons soon. Prokibe Velocity wheels are the bomb!
Mid or rear motor configuration?
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 03-15-2013, 02:41 AM   #10583
murky123's Avatar
anybody running 2 hole pistons ?
I have 1.6mm 2 hole in the back, running on low grip little bumpy and rutted dirt track.
this 2 hole piston wil soak up the small rutts and bumps very good and still enough pack when I have to land hard
so slow damper action has no or little pack, and fast and hard damper action has good pack
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 03-15-2013, 03:02 AM   #10584
LoudOne's Avatar
Trader Rating: 31 (100%+)
Originally Posted by zipperfoot View Post
Heres mine.
Wow! Nice!
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
X-RAY XB4 (2013), XB2 Carpet (2017)
Schumacher KF2
LoudOne is offline   Reply With Quote
Old 03-15-2013, 04:40 AM   #10585
Rear motor.
Old 03-15-2013, 08:33 AM   #10586
Heavy B's Avatar
Trader Rating: 18 (100%+)
Yes, I've been running 1.7mm (Losi 37.5 lt red) front and 1.6 (Losi 32.5 lt red) back for about 3 months. Seems to be same static dampening as 4 hole but significantly more pack. No more chassis slapping and more consistent chassis roll.
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 03-15-2013, 11:46 AM   #10587
Camp-Dog's Avatar
Trader Rating: 20 (100%+)
Originally Posted by patrick View Post
I got a 210 when they were first released and both the outdrives lasted a long time. In recent months I'm lucky if I get 3 race day's on just the one side. As an experiment I flipped the diff around to see if the same side wore out or the same outdrive wore out, turns out the same outdrive wore out. There is clearly a manufacturing issue with that 1 side outdrive.
Same here original outdrives wore as same rate good life out of them, New one's Iv'e gone thru 2 sets of out drives with the one side wearing a lot faster than the other? I also have 4mm limiters in my shocks so rules out plunge vibration theory IMO. I hope they just had a bad batch...
Camp-Dog is offline   Reply With Quote
Old 03-15-2013, 03:53 PM   #10588
ekt
ekt's Avatar
TD know about the issue and are offering replacements, last time I checked.
http://www.oople.com/forums/showpost...4&postcount=14
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 03-15-2013, 04:05 PM   #10589
Ah-ha! I knew it!
Old 03-15-2013, 08:03 PM   #10590
Khador12's Avatar
Did anyone else notice the bigger gear cover on Jorn's car?
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
