Like Tree43Likes
Old 03-14-2013, 09:57 AM   #10561
Heavy B's Avatar
Trader Rating: 18 (100%+)
My car keeps wearing out outdrives, particularly the nut side drive. The funny thing is that its the braking direction that c's out rather than the drive side. Has anyone noticed this same thing, or have any ideas as to why the outdrives don't wear evenly?
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 03-14-2013, 10:42 AM   #10562
Trader Rating: 62 (100%+)
I got a 210 when they were first released and both the outdrives lasted a long time. In recent months I'm lucky if I get 3 race day's on just the one side. As an experiment I flipped the diff around to see if the same side wore out or the same outdrive wore out, turns out the same outdrive wore out. There is clearly a manufacturing issue with that 1 side outdrive.
TEKNO RC * TLR * EXOTEK
patrick is offline   Reply With Quote
Old 03-14-2013, 10:47 AM   #10563
Orion_2kTC's Avatar
Can a couple of you fine folks please post some of your cars with the lids off? I'm getting a 210 soon and I'd like some ideas for clean wiring.
Orion_2kTC is offline   Reply With Quote
Old 03-14-2013, 11:08 AM   #10564
TAMAK's Avatar
Trader Rating: 28 (100%+)
Rear shock mounting worked as i thought! Big success on the same setup with just the rear shocks mounted on the back of the rear arm. Last friday i was lucky to pull a 10.9sec lap. Last night was pulling 10.2 laps! This was on dusty small track med traction dirt/clay mix. The car was way more stable on power and still retained proper rotation.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 03-14-2013, 11:41 AM   #10565
slakr's Avatar
So do the arms remain on the same side and you just flip therm over?
Did you do anything other than that? (like add any shims to the shock mount at the tower or make adjustments to the position of the arm on the hinge pin?)
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 03-14-2013, 11:42 AM   #10566
GregerL's Avatar
Was this with re-drilled or flipped arms?
GregerL is offline   Reply With Quote
Old 03-14-2013, 11:44 AM   #10567
P6
Default jonu
You may wanna buy some spare plastic servo horns I have the 1251 and i stripped the gears soon after I replaced a striped plastic horn with aluminum just not thinking about it being weaker than the titanium and now I had to replace the gears in the servo ,,, and wouldn't moving the shocks to the back just change the point where the weight is over the rear tires just like if you had a heavyier motor or RR block with a shorty lipo compared to full size
P6 is offline   Reply With Quote
Old 03-14-2013, 12:10 PM   #10568
I would never use a 1251 servo without servosaver.. Go for the 1268 in the DEX210 and the alu horn. Just stripped the gears in a brand new 1251 in a touring car with a plastic horn, no saver. Have read that several others also stripped their 1251`s with plastic horns also
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 03-14-2013, 12:10 PM   #10569
Trader Rating: 29 (100%+)
I put a little lock tite on my servo screw and i haven't stripped the plastic horn and I run a Savox 1257. The 1251 gears are not titanium it's just a metal gear set.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 03-14-2013, 12:13 PM   #10570
Old 03-14-2013, 01:02 PM   #10571
GregerL's Avatar
It all depends on what you do I guess. If you flip the arms, you will create a slightly longer wheel base, provided that you don't change your hub shimming.
I also bet that during acceleration the arms are twisting, and they will twist differently depending on if the damper is attached in the front or the rear.
And of course you will be moving the damper mass. Which effect that makes the biggest difference is the big question I guess.
Old 03-14-2013, 01:11 PM   #10572
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Heres mine.
zipperfoot is offline   Reply With Quote
Old 03-14-2013, 02:02 PM   #10573
Heavy B's Avatar
Good to know at least someone else is experiencing the same issue. Weird how it is just the one outdrive. I was hoping it wasn't something in my bench work, or maybe I was to resolve the issue. You're right, my kit outdrives did last longer than any replacements. Hopefully this issue gets resolved, or maybe the availabilty of just purchasing the single side as these things are getting expensive to replace in pairs as only one is needed.
Brian Bernt
Old 03-14-2013, 02:41 PM   #10574
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
The Team Durango guys are doing this in the mid motor setup only. I can see this helping that chassis setup, but rear motor would be best to leave them in the stock location and work on the rest of the setup improve rear traction.
Cameron Kellogg is offline   Reply With Quote
Old 03-14-2013, 03:08 PM   #10575
8ight-e's Avatar
Trader Rating: 58 (100%+)
Sounds like u guys are not setting the rear droop. At a min droop should be set enough to limit the excessive vibration and wear that u will get with no limit. Outdrives will last a long long time if u do this.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Today 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
