Like Tree23Likes
Old 03-10-2013, 03:48 AM   #10516
Boadazofa's Avatar
Trader Rating: 33 (100%+)
Originally Posted by flame56mx View Post
The steering mod didnt have much to do with anything locking up, it was mainly to help with bump steering. If you are experiencing a lock up, something else may be wrong. Where are you running the front hub inserts, and how many and where are you front hubs spacers?
thanks for trying to help but after a run today i have discovered it was the servo playing up, just decides to stop for a few seconds if it has some force applied to it! Strange thing is my 410 is having the same issue
Lone Wolf
Boadazofa is offline   Reply With Quote
Old 03-10-2013, 06:48 AM   #10517
Trader Rating: 520 (100%+)
Hmm, what brand of servos are you using?
flame56mx is offline   Reply With Quote
Old 03-10-2013, 07:24 AM   #10518
And what kind of esc and RX?
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 03-10-2013, 07:36 AM   #10519
P6
Check the length of the link between ur servo horn and belcrank I just discoverd I had a odd lock when I rebuilt it the other day I have my servo moved 2mm forward so my horn will clear the bellcrank with the horn and servo I'm using but the steering would lock at full turn whenever I turned it by hand ,, the servo horn being short can lock it or to long and it hits belcrank and if the link is to long or short it'll lock also
P6 is offline   Reply With Quote
Old 03-10-2013, 08:08 AM   #10520
Originally Posted by ekt View Post
Drive shafts popping out is caused by too much droop/little camber. Can be fixed by changing those settings or getting their new optional longer ball diff outdrives #TD310417
Thanks! I'll look into finding some of those outdrives. The drive shaft always seemed to come out when it the suspension was fully compressed. thanks for the part number on the outdrives.
TLRrunner is offline   Reply With Quote
Old 03-10-2013, 10:03 AM   #10521
sc10pc's Avatar
Hey guys like a week or two ago i had a top deck bushing and the screw pull out somehow in the last main i had moved from the b up to the a and won it with the screw out! But i was told to run a longer screw through the bushing and put a nut on the backside by the servo. I have checked this and it will work but i need to know what length mm screw to get so it isn't too short or too long and rub the servo? Thanks guys.
Ofna Nexx 10SC: Novak Ballistic 550 4.5t, Novak GTB2, Orion Vortex 1007
Durango DEX210: Tacon 8.5t sensored, Duratrax DE10, Savox SC1257TG
Team Associated B44.1: Viper VST6.5T, Duratrax DE10, Orion Vortex 1007
RETIRED: Team Associated B44
sc10pc is offline   Reply With Quote
Old 03-10-2013, 03:50 PM   #10522
Rob Phillips's Avatar
I finally got my DEX-210 to the track and I gotta say, this is hands down the best handling buggy I have driven. Thanks to Raul for the set up.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 03-10-2013, 07:15 PM   #10523
Boadazofa's Avatar
210 is a hitec and pretty sure the servo is on its way out!
The 410 is an x power and after closer inspection it is a stripped servo horn
Lone Wolf
Old 03-10-2013, 07:38 PM   #10524
Yeah, the 410 really needs an aluminum servo horn, I had issues with the plastic horns..
Old 03-11-2013, 07:38 AM   #10525
Ok, I've done quite a bit of reading on here today and just have a couple questions. I'm really considering buying one of these soon and while for the time being I'll just be running it out in the dirt field by the motorpool I work at (currently in afghanistan), and maybe occasionally gt over to the air force compound and run on their track which is a figure 8. That being said I don't have any clue what it looks like but judging by the appearance of the dirt everywhere else I would assume it is fairly well packed with a loose layer on top. I'm really just looking for some gearing help and the tires won't matter since they will get replaced once i get back from deployment. I'll most likely run the electronics in my 1/10 truggy for now which consists of a MMP esc and a 4600kv 4 pole motor, with a savox steering servo. Based on my experiences with this motor in my XXX-SCT, I imagine this will be way more than enough motor for this little guy, but it's ok since there really isn't anything to hit. I'm thinking of also getting a gear diff just to compare it to the ball diff. Based on past experience I usually prefer the gear diffs and since I have a few different weights I can play with it till i get it to what i like. So what do you guys think. Again I have no knowledge of their track other than it is a figure 8 and has an area of roughly 50-100' in length and maybe 20-40' in width.
jonu is offline   Reply With Quote
Old 03-11-2013, 09:16 AM   #10526
Originally Posted by murky123 View Post
running RM3 and a balldiff, on which side do you guys adjust the diff ( looking at the back of the buggy.
left side or right side
I always set up my diffs with the adjustment (screw head) side to the left side. This side usually is easier to access and it allows me to just turn the right side tire to tighten it up.
Old 03-11-2013, 09:31 AM   #10527
TAMAK's Avatar
Trader Rating: 28 (100%+)
Just mounted my shocks on the rear of the arm. I facebooked Jorn and he states it provides more rear traction. I am testing this out on Wednesday.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 03-11-2013, 09:41 AM   #10528
heretic's Avatar
hitec= garbage. Seriously. I must have bought like 4 or 5 servos from them and they always went wrong on me. Either they plain stop working, or act funny, or they don't find the neutral well. Plus their announced specs are highly optimistic and if you try them side by side with, say, a Ko with similar announced specs you won't believe the difference. Absolute rip-off IMO
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 03-11-2013, 09:54 AM   #10529
SUPERLOOPER's Avatar
Attachment 1042312
Very interesting! I can't imagine needing more rear bite out of the 210 however.
Brian
2017 Sponsors:
Team SOARSEIKI * AKA * Reds * Sanwa * Nitro Pro fuel * LFR * On point graphics * Xpert * M2C * Daytona RC paint
Brian Looper
SUPERLOOPER is offline   Reply With Quote
Old 03-11-2013, 10:34 AM   #10530
TAMAK's Avatar
Brian
We have some dry clay tracks up this way. I left the same setup on my car from my last time out. My car had plenty of steering but the rear end would step out on power. Just looking for a change and saw Jorns car had this on at EOS... And also noticed this trend throughout the industry for MM, I'll see what it does for RM
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
