Like Tree27Likes
Old 03-08-2013, 05:26 PM   #10501
JS
JS's Avatar
Trader Rating: 70 (100%+)
Originally Posted by knowitall156 View Post
I'm using BMan's front and rear plates(large) on both my DESC210 and DEX210and they work excellent. The layout we are running right now has a high speed sweeper that transitions to a fast jump into the face of a short table top. There is no other way to get through that section other than slamming the face of the jump so it pops you up over the table top. I would be afraid to hit that section without the braces.
So true. I race with Mike at the same track.
The front and larger rear plates are an awesome addition if you are using the Dimec chassis.
I wouldnt even think of running the Dimec chassis without them.
I am still using the same Dimec chassis with the broken rear end and the rear plate has been holding the chassis together very well
Too lazy to replace the chassis
JS is offline   Reply With Quote
Old 03-08-2013, 05:59 PM   #10502
nismomike's Avatar
Originally Posted by Rob Phillips View Post
suggestions are right on par...especially the thumb screws lol
These aren't for everyone, but a decent option for me. M3 12mm countersunk screw and cone washer.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 03-08-2013, 06:46 PM   #10503
ApacheRacer's Avatar
Trader Rating: 17 (100%+)
Ok so I just recieved this buggy used a couple of days ago and while I was setting it up I realized that there was a lot of bump steer once the wheels hit full lock. There was enough play were the camber link could get at an angle with the ackerman that it would actually lock the steering due to the camber links angle...I have it set up just like my desc210r (which is butter)...stumped
ApacheRacer is offline   Reply With Quote
Old 03-08-2013, 07:38 PM   #10504
ekt
ekt's Avatar
Your DEX210 may have old c-hubs, the newer ones that come with the DESC210 have a limiter that prevents your steering going too far and locking. Being second hand the previous owner could have done the bump steer mod to it too, so that may make a difference in your settings.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 03-08-2013, 07:44 PM   #10505
Ok well he didn't do the mod so I'm pretty sure it is the old c-hub design because it has some of the other older parts like the plastic ackerman and so forth...thanks
Old 03-09-2013, 03:46 AM   #10506
murky123's Avatar
running RM3 and a balldiff, on which side do you guys adjust the diff ( looking at the back of the buggy.
left side or right side
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 03-09-2013, 06:05 AM   #10507
opposite of the slipper nut.
ScottZ is offline   Reply With Quote
Old 03-09-2013, 07:40 AM   #10508
ae4ever's Avatar
Right.
ae4ever is offline   Reply With Quote
Old 03-09-2013, 12:10 PM   #10509
Boadazofa's Avatar
Trader Rating: 33 (100%+)
Originally Posted by ae4ever View Post
Right.
I have tried searching but could someone point me to the page that has the steering mod to stop it from locking up?
thanks
Lone Wolf
Boadazofa is offline   Reply With Quote
Old 03-09-2013, 01:40 PM   #10510
Trader Rating: 520 (100%+)
thanks
The steering mod didnt have much to do with anything locking up, it was mainly to help with bump steering. If you are experiencing a lock up, something else may be wrong. Where are you running the front hub inserts, and how many and where are you front hubs spacers?
flame56mx is offline   Reply With Quote
Old 03-09-2013, 04:51 PM   #10511
Hey guys, I'm fairly new to the buggy and dex210 scene. I'm having a hell of a time dealing with my drive shaft coming out. I'm at a loss, can anyone give me a direction to go on a fix or mod?
TLRrunner is offline   Reply With Quote
Old 03-10-2013, 12:05 AM   #10512
ekt
ekt's Avatar
Drive shafts popping out is caused by too much droop/little camber. Can be fixed by changing those settings or getting their new optional longer ball diff outdrives #TD310417
Leo Lorenzen
Old 03-10-2013, 12:14 AM   #10513
murky123's Avatar
whats up with the rear shocks of jorn and hupo ?
seems like its mounted at the back of the arms instead of the front
Old 03-10-2013, 01:12 AM   #10514
hotdognobun's Avatar
Trader Rating: 31 (100%+)
i ran it like this several times. feels ok and way easier to maintance the rear
hotdognobun is offline   Reply With Quote
Old 03-10-2013, 01:27 AM   #10515
murky123's Avatar
do you flip the arms from left to right?
how does it go with the 3 degree toe angle ??
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
