Like Tree26Likes
Old 02-23-2013, 07:17 AM   #10351
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Bingerfang View Post
petite rc hooked me up with some setup sheets for the tekin rs pro for the boost and timing and all those goodies so hopefully i can try that and keep checking the motor temps and go from there. the car still pushes underpower more power= more push for my setup ahaha
Dude, you ask for help, we take the time to help, and then you go over to the 4.2 forum and trash the 210. Good luck to you. Im sure they will be happy to listen to you over there. Cant wait to see what kind of issues you will have with the 4.2.
zipperfoot is offline   Reply With Quote
Old 02-23-2013, 07:55 AM   #10352
Trader Rating: 74 (100%+)
Originally Posted by tedstryker View Post
You're lucky I guess....
Check your layshaft bearings..
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 02-23-2013, 08:35 AM   #10353
thedoc329's Avatar
Durango dex 210 nip tresray hop ups b4 spur and front wheel conversions
Some hop ups I never installed for sale if anyone's looking for some tresrey stuff
Www.TeamScreamRacing.com
www.jConcepts.net
http://www.xfactoryrc.com
www.bfastrc.com
www.rchr.biz / www.pinshophobbies.com/www.wolcotthobby.com/STL Custom Hobbies
thedoc329 is offline   Reply With Quote
Old 02-23-2013, 09:13 AM   #10354
P6
i chewed up my first 81 spur my fault, ive been using RW since, got the 75 in no problems looks new never ran without the gear cover and indoor damp clay so no dust with a 10.5t might go to a 78t since my motor is about 1mm from full forward
P6 is offline   Reply With Quote
Old 02-23-2013, 09:52 AM   #10355
I tried almost everything you guys have told me and it still pushes. Asked a sponsored driver out at the track and he told me what to do, tried that, still pushes hard. Had bad luck with the car so far man and there is plenty of AE guys out at the track to help on setup all the time. Didn't come to the durango forum rattling any cages, just came for help, which I received and thank you guys and ill leave it at that.
Bingerfang is offline   Reply With Quote
Old 02-23-2013, 09:57 AM   #10356
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
I'm sorry to say... but this is one of the hardest sentences I've ever had to read.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 02-23-2013, 10:16 AM   #10357
tedstryker's Avatar
It's a 2wd buggy its gonna push ..
the durango has the least push outta all the 2wd buggies out ....expect maybe the Losi..
good luck with your A.E. buggy you better get use to a lot of brake to make it turn...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 02-23-2013, 10:17 AM   #10358
Brand new to racing and then says the Durango "effin sucks".
Fishhook
Old 02-23-2013, 11:53 AM   #10359
zipperfoot's Avatar
I tried several brands until I found something that worked for me. I really loved the 22 but I could not get it dialed, I liked the B4.1 worlds, but I could not get used to the feel. Each car has it's pluses and minuses. The 210 was just right...
I was surprised how I could drive one brand so much better than another. He just has to find whats right for him.
But I would rather take the high road instead of bash another brand.
Old 02-23-2013, 12:22 PM   #10360
Hi guys, newbie here. I did not look through all the threads, but can someone help me with some pointers on setting ride height, shock lengths, and droop screws. It seems my ride height is too high. Where do most people measure ride height? I assume shock length will affect ride height. Droop screws, are they necessary, or how do I set my suspension with them? It seems with my current rear droop, the cvd's are at the very edge of the diff outdrives, which makes me a little nervous. Oh, running a med/high bite, smooth track.
microracer25 is offline   Reply With Quote
Old 02-23-2013, 02:27 PM   #10361
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
How this made me laugh pretty damn hard. 2wd buggies as mentioned, will always have a tendency to push when applying excessive throttle through a corner.
You said you tried moving battery all the way forward but then got to much steering causing the back end to wash out
I would suggest start with batt all the way forward then move it back in 5mm increments until you have desired turning and rear traction,
Shorty Packs are a must with this car recommend using one if you aren't already.
Also what kick up are you running, More Kickup = more rear grip through corners, Most run 3 degree's.
Some other options you can try, but only do one at a time.
- stiffer rear or softer front springs.
- put the 2 washer on the front hubs on bottom (I have this)
- adjust trailing to be more inline (i am running 0/4 inline)
- raise front inner camber link (2mm under ball stud what I use)
- add 15 grams of weight up front (I got come fishing weights i packed into the front top deck, there is a hollow portion on the bottom where you can stick them
- move shocks on towers out
- decrease rear toe in
- adjust camber (I run 2 degree all around) If you have a lot of high speed corner you will want more camber because of body role will be greater, If you have more slow speed corners then go less.
Also what type of surface are you running on didn't catch that.
nolimit208 is offline   Reply With Quote
Old 02-23-2013, 02:35 PM   #10362
nolimit208's Avatar
I run 21-23 ride height. For measuring: Front, just before the kickup(bend) on chassis, rear usually somewhere around the rear swing arms, usually below the hinge pin holder on the rear.
I run max droop. (I cut a little bit of the chassis off on the rear to gain more droop there. On the front I believe I have 2mm of limiters inside the shock, you put these under the piston
Old 02-23-2013, 03:07 PM   #10363
P6
https://www.hookedonphonics.com/ no one says you have to read it just look at it and skip it if you don't like it
Old 02-23-2013, 03:48 PM   #10364
HAHAHA!! I like your style sir!
Fishhook
Old 02-23-2013, 05:28 PM   #10365
Just posting a pic..
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
