Like Tree26Likes
Old 02-20-2013, 06:54 PM   #10321
ekt
ekt's Avatar
Dont know how you would do the front, it uses a 5mm id bearing and 3mm screws, but the rear has 4mm threaded axles. It would use the "Type C" http://www.amainhobbies.com/product_...-C-Adapter-Set
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 02-20-2013, 08:24 PM   #10322
M3Armand's Avatar
Yes, the rears will take Type C. To your point, I haven't been able to find out what to do about the front axles... anyone?
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 02-20-2013, 10:03 PM   #10323
ekt
ekt's Avatar
After having another look, you could get http://www.tsrproducts.com/index.php...e-tytd074.html or http://www.team-durango.com/part-inf...artNo=TD330400 and use the "Type E" fronts.
Leo Lorenzen
Old 02-20-2013, 10:15 PM   #10324
P6
Originally Posted by porter View Post
The 3* toe block gives 3* toe in on each side... So using + 1.5* inserts in the hubs would give you 1.5* of toe in on each side of the car...
I've rarely seen any set up with a rear toe less than 2*, most of the time 3* will yield the best results. If you have the .5* inserts I would play with those to get either 3.5 or 2.5 degrees of toe in
but is the 1.5 per side or together? as in a 0* on the toe block with 1.5 on each hub gives only a 1.5 total toe in or would the total be 1.5? ,, im having trouble understanding as i think i may have a problem elsewhere in my buggy ive replaced the rear arms and took out more play but im thinking one of my right side has more toe in than the other even tho both have 1.5 toe out in the hubs ,,im waiting for all new plastic inserts so ill have the 0 and a spares
P6 is offline   Reply With Quote
Old 02-20-2013, 11:03 PM   #10325
ekt
ekt's Avatar
If it looks like you have more toe in with the same insert, you may have it in the wrong way around. Here is TDs guide on inserts http://www.team-durango.com/in-the-p...rticle_id=4518
Leo Lorenzen
Old 02-20-2013, 11:25 PM   #10326
Does anybody have problems with the 210 pushing really bad? Mine pushes through the corners bad... Using the Ryan lutz west coast raceway setup because that's where I drive at I can't seem to stop it from pushing so hard. First 2wd buggy, running on clay, have 35 oil up front with dark green durango springs with 25 in the rear with same springs. Car is brand new super basic setup. Possible any tips? Ride height is 23 up front and 22 in the rear
Bingerfang is offline   Reply With Quote
Old 02-21-2013, 04:08 AM   #10327
for starters, what type of battery do you have and where is its placement on the chassis? do you have a 30g mass under servo like ryan lutz does in his wcrc setups as well? if not (in conjunction with your battery placement), you might be lacking front-end weight which could cause your pushing.
glenng is offline   Reply With Quote
Old 02-21-2013, 04:32 AM   #10328
8ight-e's Avatar
Trader Rating: 57 (100%+)
Here is my clay setup very dialed, but as mentioned battery placement and the front weight are key ingredients.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 02-21-2013, 11:09 AM   #10329
nismomike's Avatar
Just about done with wiring and center mounting my esc on the buggy. Need to touch up the black cap wires.
I really like the way it turned out on the DESC210. I will be running both this weekend.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 02-21-2013, 12:14 PM   #10330
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
What size tubing is that? 1/8?
My brother has a bunch of this since he does electrical work on airplanes, have it on my charger but didn't think of on my wires in the car to clean them up a little.
nolimit208 is offline   Reply With Quote
Old 02-21-2013, 12:19 PM   #10331
nismomike's Avatar
I'm not 100% sure, but I think it's 1/8. I threw away the packaging. The inside looks 1/8 and outside 1/4.
Old 02-21-2013, 04:08 PM   #10332
nolimit208's Avatar
I have access to both will just grab a few feet of each when I am at my brothers next. I had thought of running the wires to the motor all in one just never got around to it but seeing your pictures makes me want to get back to doing it.
Old 02-21-2013, 05:38 PM   #10333
the big rc's Avatar
Trader Rating: 39 (100%+)
Still no front hub carriers anywhere. 3 places that said they were in stock were actually out.
Anyone? I just got a big box of parts from a friend and it had the right side, but of course I need the left.
the big rc is offline   Reply With Quote
Old 02-21-2013, 05:44 PM   #10334
8ight-e's Avatar
Just ordered a set off ebay the other day for my part box.... they had more at least when I ordered. The c-hubs are the only thing that I've ever had an issue w/ on this buggy, the bearing carrier part has never broke. Not the c-hubs fault though; in my case I came down off a triple wrong once, and the other time I hit a guy who screwed up at the mid point on the straight at a pretty good speed and for some reason it didn't like it
\PS those installs look great awesome work... but there is no way I'm adding weight that high in my buggy, for me standard positions are great I've seen a few w/ the trucks put the esc behind the battery low in the tray, but that is about the only way I'd even consider. Just me though
Tekno ET48, EB48.2
Old 02-21-2013, 06:18 PM   #10335
the big rc's Avatar
no luck searched ebay and nothing im after part LXCBZN
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
