Like Tree17Likes
Old 02-19-2013, 12:17 PM   #10306
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by sparkwraps View Post
Stand up rear shocks and shorten up the rear camber links.
That should help some.
+1
Fishhook
ewashburnaf is offline   Reply With Quote
Old 02-19-2013, 01:20 PM   #10307
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Originally Posted by xrayrc View Post
Looking for more grip cannot seem to put any power down without the rear end washing out. Can anyone provide any tips gonna try RM4 next...
Nobody seemed to ask you what kind of track are you running on.
If it's high bite indoor clay, carpet, etc., I could see laying down your shocks as you have them, but if you are outdoors in dirt, that alone may be your problem.
I assume you are running the right tires and inserts popular at your track.
I would try the suggestions provided to you one at a time to see if your traction is improving. Me personally I would start by running your shocks middle/outside front, and middle/middle rear. Try that, then move to the next step. I was running my rear shocks middle/outside in the rear on an indoor clay track, and switched to middle/middle while driving in outdoor dirt. That alone improved my traction considerably.
One of the suggestions provided to you was to change your rear hub spacers. I run mine 3mm in front 1mm in the rear. Lengthens the wheelbase slightly and brings the weight closer to the tranny and rear axle. Also you have the rear toe listed as 4. Seems a bit much. I would run 3 unless 4 is needed for some reason.
If slow is fast, how come I'm still slow?
zipperfoot is offline   Reply With Quote
Old 02-19-2013, 01:28 PM   #10308
zipperfoot's Avatar
Originally Posted by the big rc View Post
Funny thing is that I have been driving it for a few weeks now. Have just about every part needed. The first thing I break is the one I can't get. B4.2 is looking really nice right now.
Awe c'mon. I know how frustrating it is to find Durango parts sometimes, but to switch brands? I tried the 4.1 with the big bores and all the add ons, went back to Durango.
When I went back to Durango I pretty much accepted that I would need to keep a parts stash just in case. Nobody in AZ keeps any sort of reasonable stock. Some parts but not many. Lets hope parts supply improves.
Also I told another guy to contact Hobbico. I was having trouble finding parts so I emailed them and complained about the lack of parts. They sent me the parts I could not find free of charge.
Old 02-19-2013, 01:51 PM   #10309
Originally Posted by Bman's 3XNT View Post
Guys I have one set of skids left over from this batch. They are the front and larger rear for the dimec chassis. Pm me for details Thanks....
Had a couple sets of BMan's chassis skids show up today. The quality is excellent and I can't wait to bolt these up.
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 02-19-2013, 02:25 PM   #10310
singlemike's Avatar
I was also having trouble finding parts and I contacted Hobbico. They were fantastic- sent me some steering knuckle bushings at no charge.
singlemike is offline   Reply With Quote
Old 02-19-2013, 04:09 PM   #10311
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
[QUOTE=zipperfoot;11835851]Nobody seemed to ask you what kind of track are you running on.
Ya he is on clay per the setup sheet, towards the top there is a section for that.
nolimit208 is offline   Reply With Quote
Old 02-19-2013, 04:30 PM   #10312
just got mine in the mail today too. absolutely top notch. thanks BMan!
glenng is offline   Reply With Quote
Old 02-19-2013, 05:17 PM   #10313
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Hey guys no problem, hope they help you out. Gotta make a few more of these. Can't seem to keep them around for long. I just sent some more out, Cali and Norway.... Going global...
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 02-19-2013, 08:18 PM   #10314
the big rc's Avatar
Trader Rating: 39 (100%+)
Glad to say that Ryan Lutz was able to help me find some and said they should be in stock soon. What a nice dude.
the big rc is offline   Reply With Quote
Old 02-20-2013, 06:33 AM   #10315
zipperfoot's Avatar
[QUOTE=nolimit208;11836586]
Ah, didn't catch that on the setup sheet
Old 02-20-2013, 02:15 PM   #10316
P6
i have a 3* toe block so if i use 1.5 toe out on each hub thats 0 toe correct? the only inserts im missing are the 0
P6 is offline   Reply With Quote
Old 02-20-2013, 03:33 PM   #10317
Trader Rating: 47 (100%+)
The 3* toe block gives 3* toe in on each side... So using + 1.5* inserts in the hubs would give you 1.5* of toe in on each side of the car...
I've rarely seen any set up with a rear toe less than 2*, most of the time 3* will yield the best results. If you have the .5* inserts I would play with those to get either 3.5 or 2.5 degrees of toe in
porter is offline   Reply With Quote
Old 02-20-2013, 05:34 PM   #10318
M3Armand's Avatar
I'm trying to purchase a setup station for my DEX210; most likely Integy. Can someone tell me what size "axles" it has? I need to make sure I purchase the correct one. Here are the choices:
Type-A adaptors are for vehicles with 6mm x M5-threaded axles such as the Traxxas Revo/T-Maxx 2.5/3.3, HPI E-Savage, and Losi LST1.
The Type-B adaptors are for the HPI Savage 2.5/4.6/X/XL which uses 8mm x M5-threaded axles with a reverse thread on one side.
Type C: 5mm x M4 threaded axles i.e. Stampede, Slash; Blitz, 1/10-scale TC/drift, etc. Part #C23130
Type D: 4mm x M3 threaded axles i.e. Associated RC18B/T; Losi Mini-T, Mini LST, etc. Part# C23131
Type E: 3/16 x 5-40 front and 3/16 x 8-32 rear axles i.e. Associated SC10, B4, T4, etc. Part #C23132
Type F: 3/16 x 10-32 threaded axles i.e. Losi XXX/XXX-T, MF2, Losi 1/10 truck, etc. Part #C23215
Type G: 6mm x M4 threaded axles i.e. Associated TC5/TC5R, etc. Part # C23216
Type H: 3/16 x 8-32 threaded axles (all four wheels), Part# C23268
Type J: For all Traxxas 1/16 i.e. E-Revo VXL, Slash 4x4 VXL, Rally VXL, etc. Part# C23344
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 02-20-2013, 05:38 PM   #10319
I'm new to buggies. Picked up one of these for my local indoor carpet tracks. I'm running a tekin rs pro and a redline 10.5. Lol, how do I keep the front end down during acceleration? Besides reducing power
Chrisg23 is offline   Reply With Quote
Old 02-20-2013, 06:00 PM   #10320
nolimit208's Avatar
Just Searched the Thread and got a bunch of hits.
Link of Search:
http://www.rctech.net/forum/search.p...rchid=15353491
Originally Posted by dirtydan
do you need special adaptors to put this on the integy setup station? i have the station that works for 1/8 offroad and 1/10 offroad, but i just wanted to know if anyone has used it with this car before i purchase one.
Dan
Originally Posted by cm.stites
you need the type c adapters i believe that are for the hpi blitz
Digged this back from page 157!
Can someone verify if this is correct? Is this the correct size for both front and rear?
http://www.amainhobbies.com/product_...-C-Adapter-Set
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
