Like Tree24Likes
Old 02-18-2013, 08:31 PM   #10291
the big rc's Avatar
Trader Rating: 39 (100%+)
Sorry, i thought you meant C hubs like AE rears. My mistake.
Originally Posted by ekt View Post
front hub carriers are c-hubs. Here is a pic of RDRP's c-hub they are working on
the big rc is offline   Reply With Quote
Old 02-18-2013, 10:21 PM   #10292
xrayrc's Avatar
Trader Rating: 61 (100%+)
Looking for more grip cannot seem to put any power down without the rear end washing out. Can anyone provide any tips gonna try RM4 next...
Thanks to my sponsors Team Associated, Reedy, Jconcepts, Venom Group
Cruizin With RC's & Raceway
xrayrc is offline   Reply With Quote
Old 02-19-2013, 12:24 AM   #10293
murky123's Avatar
make your wheelbase longer. put the 4mm spacers in front of the rear hub instead of behind.
swap the 7.5 motor for a 8.5 motor, 7.5T is to much for low grip situations
and try a fullsize stickpack instead of a shorty in the back. that will add some weight.
and be easy on the throttle
swap the geardiff for a balldiff , that will give you better "feel" of the power you can put down. Gear diffs work best in high grip situations.
a gear diff witk 2K oil , I use on high grip carpet tracks. the complete opposite of what you drive on. on lowgrip dirt or clay always a balldiff.
edit: what +8mm chassis do you run? On low grip you need the car to be forgiving and therefore a lot of flex in the chassis is good. I advise the DIMEC over the DIMEC20
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 02-19-2013, 04:49 AM   #10294
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Stand up rear shocks and shorten up the rear camber links.
That should help some.
| AFLAC Designs - Custom Airbrushing, in a hurry! | Jakes RC Pro Am - Topeka's Indoor Offroad Track! |
sparkwraps is offline   Reply With Quote
Old 02-19-2013, 05:15 AM   #10295
Trader Rating: 47 (100%+)
May also try going to 30* caster... That should help the car to be easier to drive...
porter is offline   Reply With Quote
Old 02-19-2013, 06:37 AM   #10296
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
What type of rear traction are you trying to increase? Because there is a tradeoff to both. Are you looking for side bite (lateral traction) or forward traction?
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 02-19-2013, 06:39 AM   #10297
Trader Rating: 29 (100%+)
Also if your going to stay with gear diff you need to lighten up the oil. Try 80 wt shock oil or at least drop it to 1,000wt. 2,000 in this car is perfect for high grip conditions.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 02-19-2013, 08:29 AM   #10298
the big rc's Avatar
Does anyone know where the front hub will be in stock? Unreal that a company expects people to wait a month for parts that will obviously break. Thinking I might have made a mistake switching now.
No one in our area carries anything durango, amain and tower are out. Thinking if tower is out, I am gonna be out of luck.
Anyone have any ideas?
Old 02-19-2013, 08:33 AM   #10299
majorsmx521's Avatar
Trader Rating: 44 (100%+)
Default pm
Kevin
pm ed you, might be able to help
521DESIGNS PAINT
R.I.P TQ Speedway Boise
majorsmx521 is offline   Reply With Quote
Old 02-19-2013, 08:39 AM   #10300
singlemike's Avatar
which side do you need?
I may be able to send you one.
singlemike is offline   Reply With Quote
Old 02-19-2013, 08:53 AM   #10301
the big rc's Avatar
Left side.
Old 02-19-2013, 09:07 AM   #10302
the big rc's Avatar
Funny thing is that I have been driving it for a few weeks now. Have just about every part needed. The first thing I break is the one I can't get. B4.2 is looking really nice right now.
Old 02-19-2013, 10:15 AM   #10303
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Check ebay, saw some on there this morning. Absolute hobbyz out of Jersey.
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 02-19-2013, 10:28 AM   #10304
Woulvesbaine's Avatar
I use four-hole pistons that like many others I created using the stock six-hole black pistons and gluing two holes.
I see that some of the four-hole tapered and dual tapered are finally appearing in stock.
I'm thinking about buying these as back up for when the glue holes may pop out.
I have lots of questions regarding pistons as they're still an aspect of setup that I'm not fully comfortable with.
What are the differences between tapered and dual tapered? Is one generally preferred over the other?
How do these compare with the stock non-tapered black pistons? That is, if I'm running 1.2 black (stock), would I bore out the tapered/dual tapered to 1.2 or a size less (or more) to accomidate for the taper(s)?
I figure I'll buy some of these next time I make an order. It seems like I could buy a couple sets and hand bore them out if that's whats suggested.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 02-19-2013, 11:56 AM   #10305
Doughty's Avatar
If you want the car to square up more when exiting corners (more rear traction on corner exit)
Switch to the ball diff and run it reasonably tight.
Change to hole #2 on rear arm
the car will feel 100% different with just the diff changed.
the most critical thing with setting up a 2WD is the diff, its a little about driver preference, but if you want the car to square up on power and your running a gear diff, put a ball diff in there, the car will instantly be different.
Regarding the Caster Blocks - I believe they should be back in stock with Tower within a few days.
Chris Doughty - Team Durango - LRP - BETA Tires - Nibbo Design
Doughty is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
