Like Tree43Likes
Old 02-15-2013, 08:26 PM   #10261
ekt
ekt's Avatar
Originally Posted by P6 View Post
just want more options im not a fan of red anodizing and im thinking a liver would look good plus the losi hubs i posted have a good amount of adjustment
Ah, in that case, the picture below shows associated hubs, axles and shafts so these two should fit. Would have to look at what size bearings they use.http://www.amainhobbies.com/product_...arriers-Silver or http://www.amainhobbies.com/product_...arriers-Silver
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 02-16-2013, 03:33 AM   #10262
murky123's Avatar
selfmade 2mm thick carbon rear skidplate for the dimec chassis.
should protect the rear enough.
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 02-16-2013, 03:33 AM   #10263
murky123's Avatar
Old 02-16-2013, 04:58 AM   #10264
Snapped my Rango's +8mm Carbon chassis,was not looking forward to replacing it before my next race tomorow morning,then I thought of you guys on here.
And come up with this!!! All up,around 5 mins work max
So,thank you to the guy who originally thought of this for the plastic Rango chassis's,it also fixes broken Carbon ones.
Durango DEX210 Thread-2013-02-16-22.46.56.jpg   Durango DEX210 Thread-2013-02-16-15.22.42.jpg
AE SC10 FT
Durango DEX210
Serpent S100 LT Corvette WGT
FGX Mckune Mercedes W02
Fleet powered by Thunder Power and Tekin,Spektrum and Hitec,painted by HABIBS BODIES
Peli is offline   Reply With Quote
Old 02-16-2013, 07:54 AM   #10265
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Nice work guys, and your welcome.........
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 02-16-2013, 08:16 AM   #10266
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Id be interested to know what springs he is using. I have mine cranked almost all the way down in the rear just to get ride height. His appear longer.
zipperfoot is offline   Reply With Quote
Old 02-16-2013, 09:30 AM   #10267
Khador12's Avatar
Looking at some of the other pictures he be switched back to the stock plastic tower for the race heats. The shock collar is farther down with this one. Maybe the carbon fiber one he ran in practice is shorter than the stock one?
Most off Jorn's dirt RM3 setups use dark blue rear springs.
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 02-16-2013, 12:32 PM   #10268
Trader Rating: 33 (100%+)
I've been racing all year having good luck with a B4. Last night I ran my mid motor Durango for the first time. It would fly through the air and have a tendency to tilt left or right in the air making it very challenging to land flat. Is there anything setup or drive train related that would cause this.
LM22D is offline   Reply With Quote
Old 02-16-2013, 12:58 PM   #10269
M3Armand's Avatar
Hmm... that's very odd. I haven't had that issue. But I'm running gear diff. You might consider tightening your ball diff to see what happens. I also arranged my electronics such that the car is perfectly balanced right/left.
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 02-16-2013, 01:01 PM   #10270
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Could be a couple things. Lateral balance (side to side) may be off. Make sure both sides have equal weight distribution. Also, if you go up a take-off at an angle or turn right before the jump, you will flap like a duck. I'm not sure what else could do it.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 02-16-2013, 02:23 PM   #10271
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
I was thinking possibly the truck springs myself?
nolimit208 is offline   Reply With Quote
Old 02-16-2013, 02:50 PM   #10272
I was running a gear diff with 1000k. It was the first time running a gear diff in 1/10 scale. I thought possibly the light weight oil in the diff could be causing this on the face of the jumps. The track is consistent being that it is a carpet surface.
Old 02-16-2013, 03:04 PM   #10273
Trader Rating: 29 (100%+)
The 1000k wont do that. I run 2000K in mine on carpet. I have had as low as 70wt shock oil in my 22 and never had that happen.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 02-16-2013, 08:13 PM   #10274
Oasis's Avatar
Trader Rating: 36 (100%+)
The Durango was on rails today..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 02-16-2013, 09:57 PM   #10275
nismomike's Avatar
Just finished this mod on my DESC210, and gonna do the buggy next.
I couldn't get away to race today, so I finished a project I started earlier this week. Bunch of pictures to help anyone interested in mounting their electronics inline without using the battery tray.
I noticed last weekend my chassis had a small split, so I used it as the esc platform material.
20mm screws with some faux carbon fiber and HB ballstud washers.
Update, got the carbon fiber and milled aluminum stand-offs. 7grams.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16577 Yesterday 07:21 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
