Like Tree17Likes
Old 02-14-2013, 03:03 PM   #10246
rsxskyd's Avatar
Trader Rating: 48 (100%+)
Originally Posted by rsxskyd View Post
Hey whats up guys, finally getting my first durango, will be getting the dex210 obviously. Im a AE guy and will always be, but, I have decided its time to just try different brands and see how I like it. I originally plan on getting the b4.2 buggy, but decided to hold off and give the dex210 a shot first, I already have the b4.1 worlds and i love it.
I will be running a 9.5 motor with tekin rs in it, wondering what you guys suggest for a starting point in gearing on med - high bite clay. This is a whole new brand so i will have to learn how to tune this thing. If anyone has suggestions that may make a huge difference even something small, let me know. All help is appreciated!! Thank you guys!
rsxskyd is offline   Reply With Quote
Old 02-14-2013, 04:27 PM   #10247
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Originally Posted by FL_SilverEvo8 View Post
I think the biggest pinion gear you can run on a 81 spur gear would prob be a 24t. Anything else higher would over heat the motor. That is the gearing I have in mine. And I run 17.5 blinky also. Still hunting for a better set up for my car.
With an 81 spur, you can fit a 30 pinion.
Edit: I ran that with a 13.5 and didn't overheat.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 02-14-2013, 05:33 PM   #10248
P6
http://www.amainhobbies.com/product_...r-Set-Silver-2 http://www.amainhobbies.com/product_...inum-Rear-Hubs anyone try ether of these im wondering if using the right shims would be the only key to using something aluminum are the hinge pins and bearings the right size?
P6 is offline   Reply With Quote
Old 02-14-2013, 06:48 PM   #10249
ekt
ekt's Avatar
Any particular reason you are looking for ones from a different brand? There are 3 aluminium options for the DEX210 http://durangofansite.com/DEX210afte...t.html#rearhub
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 02-14-2013, 07:01 PM   #10250
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Id look at the manual for each car the hubs apply to and see what size bearings they are using. I suspect the size is standard, and as you know the 210 is metric.
If slow is fast, how come I'm still slow?
zipperfoot is offline   Reply With Quote
Old 02-14-2013, 07:27 PM   #10251
rcjunky1's Avatar
I've never heard of that site, but thanks for posting, even I made it on there
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 02-14-2013, 07:49 PM   #10252
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by Bman's 3XNT View Post
Yes, just put a brand spanking new front skid plate on also. Man is it pretty....why don't you give me some setup tips. Long pack or shorty??? Thanks
I would definitely run a shorty, the cut weight is nice but being able to balance the car more is the key part.
nolimit208 is offline   Reply With Quote
Old 02-14-2013, 08:27 PM   #10253
ekt
ekt's Avatar
Its a site I've been working on in my spare time, let me know if you want a different icon and if you get those chassis happening and I'll add it on there.
Leo Lorenzen
Old 02-15-2013, 12:57 AM   #10254
nolimit208's Avatar
Nice reference site for us Durango enthusiasts. Appreciate your work.
Should add setup to the list that goes to; http://www.petitrc.com/setup/durango...ngoDEX210.html
Old 02-15-2013, 03:01 AM   #10255
ekt
ekt's Avatar
Thank you for the idea, added http://durangofansite.com/DEX210addition.html
Leo Lorenzen
Old 02-15-2013, 10:28 AM   #10256
Brushless420's Avatar
Trader Rating: 169 (100%+)
Default CARPET QUESTION
Im running on a high bite very small and tight carpet track. Going to run MM4 and had a few questions on setup.
What springs would be good to have on hand?
What shock oil weights to try front and rear? (I'm going to be running GHEA delrin tapered 6x 1.2 pistons)
What wt gear diff fluid to run and or options?
Also I picked up the exotek MM RR block http://www.exotekracing.com/dex-desc...m-rr-5-degree/ What RF would be good to run in conjunction with it?
Brushless420 is offline   Reply With Quote
Old 02-15-2013, 10:39 AM   #10257
Khador12's Avatar
I race on a small tight carpet track and have been using Jorn as a base. It can be found here.
One thing that is not listed on the set up sheet but you can see in the pictures is the use of a 65 gram front bulk head.
This has been a very good starting point for the DEX210 on carpet.
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 02-15-2013, 04:53 PM   #10258
Trader Rating: 74 (100%+)
Our cars are dialed @ Motorama. Check out liverc.com
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 02-15-2013, 05:01 PM   #10259
Send a message via Yahoo to nitro-rob Send a message via Skype™ to nitro-rob
Originally Posted by Oasis View Post
You'll be suprised at how well the +8 chassis works on small tracks.im a real careful driver & I don't crash much and my +8 did break from a small hit..so good luck..
Thanks for the heads up. I have a dimec20 and if I break the regular dimec I will switch to the thicker one. I want to try the more flexible chassis first to feel so I am holding off on using the stiffer one first.
nitro-rob is offline   Reply With Quote
Old 02-15-2013, 07:06 PM   #10260
P6
just want more options im not a fan of red anodizing and im thinking a liver would look good plus the losi hubs i posted have a good amount of adjustment
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
