Like Tree23Likes
Old 02-10-2013, 08:40 PM   #10201
ajj
ajj's Avatar
Trader Rating: 18 (100%+)
Originally Posted by Shane4928 View Post
What pinon would you start off with for a 17.5 blinky setup running a 81 spur. DEX 210, Speed passion comp v3mmm?
Thanks!!
Not sure if it would fit but a 35 tooth pinion for a FDR around 6. I run 69/34 for a FDR around 5.3 with a SP MMM with 15 timing on the can.
AJ
Associated SC5M, Hot Bodies D413, Durango DEX210, Durango DEX410, Mugen Seiki MBX7R
ajj is offline   Reply With Quote
Old 02-10-2013, 10:00 PM   #10202
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
New body, the top sides on the left and right are tinted to allow people to see my electronics.
nolimit208 is offline   Reply With Quote
Old 02-10-2013, 10:24 PM   #10203
Jtipsy's Avatar
Has anyone tired the Diggity Designs carbon fiber front tower. It turns the front camber links from upright to sideways.
http://www.diggitydesigns.com/Durang...ockTower.html#
Joseph Tuepker
Jtipsy is offline   Reply With Quote
Old 02-10-2013, 11:30 PM   #10204
Oasis's Avatar
Trader Rating: 36 (100%+)
My local track is running a 17.5 class and I just got a 17.5 and have no idea on gearing..any help would be great..I'm just looking for a good starting point, thanks..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 02-10-2013, 11:46 PM   #10205
ekt
ekt's Avatar
34/69 is a popular gearing for 17.5T
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 02-11-2013, 03:07 AM   #10206
The tint is sweet dude! i especially like it on the wing too! i tried pactra spray can tint on a wing, but found it very hard to spray on a clean coat without it running, dripping, etc. what kinda tint did you use? it looks real good. very nice man.
glenng is offline   Reply With Quote
Old 02-11-2013, 05:36 AM   #10207
Oasis's Avatar
Thanks..
Old 02-11-2013, 06:22 AM   #10208
Trader Rating: 33 (100%+)
I'm rebuilding my buggy for a carpet track. Most of the setup's I see are calling for 1000k or 2000k gear diff. fluid. That seems light to me. Is this what everyone is running.
LM22D is offline   Reply With Quote
Old 02-11-2013, 06:51 AM   #10209
FRONTI3R's Avatar
For Carpet and Astro yes. Even 1000k is heavy I found. I've seen on setup sheets that Jorn uses 650cst.
I run mine on Astro turf with just black grease in the diff. with great results.
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 02-11-2013, 07:14 AM   #10210
Trader Rating: 29 (100%+)
Yes I run 2,000 fluid in my diff. I run on a medium size carpet track.
When I had Losi 22 I would run 80wt shock oil in the diff, but with the Durango I like 2,000wt
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 02-11-2013, 07:29 AM   #10211
8ight-e's Avatar
Trader Rating: 57 (100%+)
5k losi diff fluid in the gear diff is awesome for any med to high bite track... I would only go less for a loose outdoor track. My buggy and truck have been on rails most nights w/ the current setup.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 02-11-2013, 07:59 AM   #10212
Thanks for the input. I've ran gear diff.s in my 4x4 SC but never in a 2wd. So for the higher traction surface the thinner the oil. And thicker for low traction surface.
Old 02-11-2013, 08:53 AM   #10213
Default Gear box ball stud mod
Has anyone done the gearbox mod where you are moving the ball stud in to avoid breakage?
If so, how amny millimeters in are you going from the original ballstud hole and what size drill bit are you using on the new hole?
Team Durango DESC 410V2,Team Durango DESC 210R
Team Durango DEX 410V5,Team Durango DEX 210V2
Mike Maniscalchi www.team-durango.com
knowitall156 is offline   Reply With Quote
Old 02-11-2013, 08:59 AM   #10214
Trader Rating: 27 (100%+)
I have not done the gearbox mode by moving the ballstud hole, but I created my own aluminum brace that wraps around the gearbox and is mounted by screwing the ballstuds into the gearbox through the brace. I made the brace out of an aluminum 1/8th scale skid plate. It eliminates the 2mm spacers under the ballstuds. It has held up very well and I have not broken a gearbox with the brace in place. The only downfall is that you can not lower the inner camber link mount....
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 02-11-2013, 10:09 AM   #10215
This depends on what kind of carpet you run on? The eruo series carpet is very low bite. If I run on really HIGH bite carpet like you would see in a office, I run 3000 to 5000. If I run on carpet like you see Jorn run on, I use 1000 or less!
chet is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
