Like Tree17Likes
Old 02-08-2013, 07:40 AM   #10171
pete68's Avatar
Originally Posted by SPOT MY 6 View Post
Which body does everyone recommend running? Just picked up a 210 and need to get one sprayed with my color scheme. Thanks
i was running the original but just gotthe jconcepts cabforward to along my
P68+10
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 02-08-2013, 10:54 AM   #10172
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Has anyone tried pistons from another brand in the big bore shocks?
I am not talking aftermarket. I am interested to know if AE 4.2 big bore pistons, Losi 22, etc., would work in the Durango.
If slow is fast, how come I'm still slow?
zipperfoot is offline   Reply With Quote
Old 02-09-2013, 12:29 AM   #10173
rustler1995's Avatar
Trader Rating: 22 (100%+)
+1 anybody know?
Team Durango DEST210
Team Associated B64 C.R.
Hyper 10TT
SDRC Raceway!
rustler1995 is offline   Reply With Quote
Old 02-09-2013, 04:20 AM   #10174
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by pete68 View Post
Durango DEX210 Thread
CHK MY picture of the P68+10
When will you start selling them?
nolimit208 is offline   Reply With Quote
Old 02-09-2013, 04:34 AM   #10175
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Originally Posted by rustler1995 View Post
+1 anybody know?
AE/losi pistons are 12mm and Durango shocks are, I think, 14mm.
I think Schuey pistons might be the only ones to try besides durango.
| AFLAC Designs - Custom Airbrushing, in a hurry! | Jakes RC Pro Am - Topeka's Indoor Offroad Track! |
sparkwraps is offline   Reply With Quote
Old 02-09-2013, 05:37 AM   #10176
Potoczak's Avatar
Trader Rating: 111 (100%+)
Please pm me if anyone is interested in aluminum c hubs!!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 02-09-2013, 06:35 AM   #10177
Oasis's Avatar
Trader Rating: 36 (100%+)
As far as size goes they are the same, all 3 are 12mm. The new shuie shocks are 13mm so they will not fit, as you all know the Durango uses a screw to secure the piston to the shaft..both AE & Losi use a c clip, I have all 3 pistons and some spare shock shafts..I'll see if they fit..I don't think they will but you never know..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 02-09-2013, 09:06 AM   #10178
Bman's 3XNT's Avatar
Trader Rating: 70 (100%+)
Why are you guys even interested in trying different manufactors pistons anyways. What's wrong with the TD ones?
Team Durango DEX410 w/3 Diffs ;) The original
Xray Xb2 CE
www.rchr.biz------www.Wolcotthobby.com
Bman's 3XNT is offline   Reply With Quote
Old 02-09-2013, 09:58 AM   #10179
Nothing wrong with TD pistons at all...
Hyper 10TT
SDRC Raceway!
Old 02-09-2013, 10:47 AM   #10180
RC10Nick's Avatar
Other than they come in the kit as 6 hole when everybody runs 4 hole, and they have just about no tuning options
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 02-09-2013, 11:40 AM   #10181
Trader Rating: 42 (100%+)
huh? i cant complain about my 6 hole pistons...
i got blanks in my kit too...
bumpsandjumpsrc.com
Scale Speed - High Performance Dirt Oval
ShtLuck is offline   Reply With Quote
Old 02-09-2013, 12:25 PM   #10182
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
I've played with other companies pistons in my shocks while testing different setups at the track. The TD pistons are fine but I prefer the "taper" style pistons for their different compression and rebound characteristics. My friends at the track race Kyosho and TA cars and we swap pistons back and forth all day long looking for the right "feel".
I doubt I'd buy all the different pistons I've tested. Swaping back and forth with my friends on practice days just gives you more options.
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 02-09-2013, 03:38 PM   #10183
Default Gears
Have the stock 87 spur with a 25 poinon real tight no room for adjusting. Should I be using different gears indoor clay track med size 18 sec laps?? Thanks
dolfns1 is offline   Reply With Quote
Old 02-09-2013, 07:12 PM   #10184
JS
JS's Avatar
Default Bman's SS Skid/Chassis plates
Just received the front and rear SS Skid/Chassis plates from BMan's 3XNT.
Fit and Finish are perfect. Very thin and strong.
The Rear plate has more material and more mounting holes compared to his original version.
Weight - Front/10.6g and Rear/13.7g
Thickness - less than 1mm (0.88mm)
Will test in a few days.
I have no doubt that it will be way better than the stock alu plates that I used before. The Stock alu plates were 2.5mm and really picked up a lot of clay and debris.
Still using the dimec chassis with the broken rear end
Will report back in a few days.
Durango DEX210 Thread-bmanfrontplate1.jpg   Durango DEX210 Thread-bmanfrontplate2.jpg   Durango DEX210 Thread-bmanv2rearplate.jpg
JS is offline   Reply With Quote
Old 02-09-2013, 08:22 PM   #10185
zipperfoot's Avatar
TD come with 6 hole, and do not work at the tracks I run at. The four hole 1.2 and 1.3 are best.
I don't like the idea of using toothpicks or melting the extra holes closed. I have also read 2 hole pistons work well, but again i would need to plug holes or drill my own.... Not my first option. AE makes two hole for their big bores, so if I could use those without having to mod anything, that would be my first choice.
St Ives RC Club B4Bandit Australian Racing 16561 Today 03:54 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
