Like Tree27Likes
Old 02-05-2013, 07:15 PM   #10126
so i took away 5* of caster in hopes of more steer in but i got the opposite, more push. is it the other way around ?
twisted is offline   Reply With Quote
Old 02-05-2013, 07:17 PM   #10127
P6
Originally Posted by pete68 View Post
it should calm the car and easier to drive ill let everyone know tomorrow!!
what other dex210 chassis have you used when you let us know how it goes just for everyone to compare +10 or +8 cf, alum, plastic, and kit
P6 is offline   Reply With Quote
Old 02-05-2013, 07:19 PM   #10128
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Potoczak View Post
Would the track width still be the same??
Yes
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 02-05-2013, 08:01 PM   #10129
KH
I would like to know what parts are being used to convert the rear to 12mm hex? Also if anybody knows where I can get some c-hubs that would be great.
I converted mine using parts from the dex410. It's a gold spacer sleeve, a gold washer that's slight coned and a shorter pin. I use stock tlr22 hexes. I share the rear wheels between my 22's and 210 and 410. All my rear tires are mounted on tlr22 rear wheels. The Durango rear axle is about 1/4mm smaller in dia but it still works fine. The jconcept tlr22 wheels are a slightly tighter fit and work great.
TLR22, TLR22 #2
T4.1
TC6.1 17.5tc
X-ray T3 Mod tc
DEX410, DEX408
KH is offline   Reply With Quote
Old 02-06-2013, 02:58 AM   #10130
Default Neumann's turnbuckles??
Hi.
Does anyone know which turnbuckles, ball cups and ball studs Neumann is using on his DEX210??
René
mr. Jepsen is offline   Reply With Quote
Old 02-06-2013, 03:52 AM   #10131
pete68's Avatar
i was running the original chassis before
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 02-06-2013, 04:45 AM   #10132
8ight-e's Avatar
Trader Rating: 57 (100%+)
Originally Posted by mr. Jepsen View Post
Hi.
René
Several run the associated studs with the concepts ends. I've had good luck w/ the stock ;P
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 02-06-2013, 09:44 AM   #10133
P6
So I'm using ae 27.5wt front 4x1.3 piston / 25wt rear 4x1.2 piston, I have plenty of pack and the wheels stay on the ground in the rougher areas its working great I picked up a set of spare shocks so I'm gonna try 2 hole pistons what size and oils at should I try?
Old 02-06-2013, 10:15 AM   #10134
Trader Rating: 19 (100%+)
Hi.
René
It actually appears that he is running the stock ballcups/ballstuds with AE turnbuckles. I have the same setup on my SC and it works great- the AE turnbuckles are slightly smaller than the stock ones so they adjust easily without popping. I've never popped a ballcup off my SC, and I've had it since they came out.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 02-06-2013, 10:55 AM   #10135
1.6 seems to be the popular 2 hole setup.
Old 02-06-2013, 12:45 PM   #10136
Khador12's Avatar
Hi.
René
He is using Yokomo ball cups, and ball studs. The turnbuckles are Durango ti.
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 02-06-2013, 02:40 PM   #10137
nismomike's Avatar
Sure wish I could find the Tresrey rear camber mount in stock. Need 2 asap. If anyone knows where to find them, let me know. Thanks!
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 02-06-2013, 02:50 PM   #10138
slakr's Avatar
Trader Rating: 28 (100%+)
Possible substitution? http://www.rcshox.com/durango-gearbox-fix/
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 02-06-2013, 03:32 PM   #10139
ekt
ekt's Avatar
http://www.teamxtreme.co.uk/store/in...roducts_id=430 is an option too, in the UK though.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 02-06-2013, 06:08 PM   #10140
nismomike's Avatar
Thanks guys, both are option I may seriously consider. I want to have something before Cactus Classic. Never had a problem yet, so it's not a huge deal. But I like to be proactive, not reactive. Thanks again.
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
