Like Tree24Likes
Old 02-05-2013, 08:44 AM   #10111
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
it looks like journ used the AE hubs, b4 rear hexes and perhaps the b4 cva's. But i have not seen any confirmation.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-05-2013, 09:30 AM   #10112
Originally Posted by singlemike View Post
Does anyone know where to get the steering knuckle bushing set,
TDR340004? Amain just changed the expected date to March 6.
Alternatively, does anyone have a possible substitution?
I've used Tamiya touring car bushings I had in my Tamiya parts box before.
I have a TRF416, TRF415 and a TA-05 so they could have been for any one of those models. I don't know if that helps, but it's the best I've got.
Also, when you do get replacements....use a little shoe goo to stick them to the c-hub and you won't lose them again barring a major catastrophe.
______________________________________________________
Team Tulsa - Team R/C Paints by Sonny - Durango DEX410
qwkpony is offline   Reply With Quote
Old 02-05-2013, 10:16 AM   #10113
Originally Posted by zipperfoot View Post
Contact Hobbico. I did, told them I could not find parts, and they sent me what I needed, no charge.
Zipperfoot, thank you for the tip! I just got off the phone with Hobbico; after a 7 minute call I have a TDR330339 set coming my way on Friday. Even Hobbico doesn't have any of these in stock and they said they'll be receiving them Thurs/Fri like other distributors. I already have 5 of them back ordered on Amain, but at least I have 1 free one coming from Hobbico -- I always like free stuff
Now to wait for the end of Feb for the RDRP Aluminum C-Hub's... I've been in contact with them asking what's the fastest way to get my hands on a set, and they said just to wait for Amain to get them in (at least for North American customers). See below...
Hi Neil,
shipping from here to the US isn't really fast. Honestly I would recommend to wait until they are in stock at Amain. Amain already made the preorder for them and gets them ASAP.
regards
Sven
-------- Original-Nachricht --------
> Datum: Mon, 4 Feb 2013 14:49:40 +0000
> Von: "MacLean, Neil"
> An: Sven Rudig <ruddog@gmx.de>
> Betreff: RE: DEX210 Aluminum C-Hub Availability
> Hi Sven,
> Thanks for the reply. What would be the fastest way to get a hold of
> these C-hubs once they're available? I need them ASAP, so I'm
> wondering if I can pre-order them directly from you or if I have to
> wait until Amain has them available, etc?
> Thanks,
> Neil
> -----Original Message-----
> From: Sven Rudig [mailto:ruddog@gmx.de]
> Sent: Tuesday, January 08, 2013 10:48 AM
> To: MacLean, Neil
> Subject: Re: DEX210 Aluminum C-Hub Availability
> Hi Neil,
> the new DEX210 c-hubs will be available end of February.
> best regards
> Sven Rudig
> RUDDOG Distribution
Neil
MacLean is offline   Reply With Quote
Old 02-05-2013, 10:29 AM   #10114
singlemike's Avatar
qwkpony-
I will try the shoe goo next time- not sure it would have helped this time-my c- hub ended up in a couple of pieces and the bushings were mia. The way parts are I should have taken a metal detector and searched the track.
singlemike is offline   Reply With Quote
Old 02-05-2013, 10:45 AM   #10115
qwkpony-
If you can find the pieces of the broken c-hubs you will get your bushings back. That has been easier for me in the past than finding the small bushings.
Old 02-05-2013, 11:40 AM   #10116
KH
Can someone tell me the part number of the kyosho orings that work in the td big bores? I saw someone post pn KYOORG03XR and the OD is too small. Also comment on if there's any mods that need to be done while installing these orings.
Thanks!
TLR22, TLR22 #2
T4.1
TC6.1 17.5tc
X-ray T3 Mod tc
DEX410, DEX408
KH is offline   Reply With Quote
Old 02-05-2013, 11:43 AM   #10117
csracing's Avatar
Trader Rating: 22 (100%+)
Thanks!
I'm just running Associated 5407 o-rings. Leak less than the kit o-rings and are readily available.
csracing is offline   Reply With Quote
Old 02-05-2013, 11:48 AM   #10118
The Kyosho P3 x-rings work fine. They just need to soak in silicone oil and swell up a bit. I just build the shocks with the x-ring inside and regular O-ring outside. That way the cheapo regular ones get worn and can be replaced frequently. So far no leaks.
skipper_tim is offline   Reply With Quote
Old 02-05-2013, 03:48 PM   #10119
P6
im using ofna crt5 bushings it comes in the kingpin and bushing set their thick so i would only need 0.5mm to each side im just using 1mm under the hub i felt the ones on the buggy were thin and weak looking
P6 is offline   Reply With Quote
Old 02-05-2013, 04:49 PM   #10120
pete68's Avatar
here are some pic of the P68 +10 chassis its a 6061-t6
Yokomo BD7-15&16/YZ2 HOBBYWING/SMC/FUTABA/XPERT/MRT-PTX
pete68 is offline   Reply With Quote
Old 02-05-2013, 05:03 PM   #10121
LoudOne's Avatar
Trader Rating: 31 (100%+)
Attachment 1027772
Attachment 1027773
What is the advantage over the stock chasis?
Kyosho RB6.6, ZX6.6
Serpent SRX2 MM
X-RAY XB4 (2013), XB2 Carpet (2017)
Schumacher KF2
LoudOne is offline   Reply With Quote
Old 02-05-2013, 05:31 PM   #10122
pete68's Avatar
it should calm the car and easier to drive ill let everyone know tomorrow!!
Old 02-05-2013, 05:39 PM   #10123
Potoczak's Avatar
Trader Rating: 111 (100%+)
I would like to know what parts are being used to convert the rear to 12mm hex? Also if anybody knows where I can get some c-hubs that would be great.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 02-05-2013, 05:45 PM   #10124
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
For the hex conversion all you need is the hex for a B4.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 02-05-2013, 05:49 PM   #10125
Potoczak's Avatar
Would the track width still be the same??
Pete Potoczak
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
