Like Tree33Likes
Old 02-04-2013, 07:49 AM   #10066
OSherman's Avatar
Default MidMotor configurations..
MM3 vs MM4.. Which generates the more grip of the two? and why?
Lost in translation..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-04-2013, 08:01 AM   #10067
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
I just got a DEX210 and was wondering what are good must haves for this buggy(hop ups)? I will be running 17.5(Tekin Gen2) blinky(Novak Club) class. Any good set ups for a blinky class? Only set up I see are for MOD class.
( ) - is what I have in the car.
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 02-04-2013, 08:42 AM   #10068
Trader Rating: 29 (100%+)
MM4
The rotation of the motor is in the same direction as the rotation of the wheels. The torque of the motor is in opposition to the rotation of the motor and is ‘aimed’ between the motor and the contact patch of the tyre. This causes the rear end to squat under acceleration aiding forward traction.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 02-04-2013, 08:54 AM   #10069
What kind of set up you looking for MM or RM? What kind of track, how big, surface?
Must have hop ups, I would get a carbon fiber or Aluminum steering plate, and upgrade the battery thumb screws the plastic one suck, and maybe get a carbon fiber rear shock tower I have heard alot of people breaking the stock towers. Thats really the only must haves everything else is personal preference or bling.
Old 02-04-2013, 09:14 AM   #10070
P6
cf never hurts and titanium buckles studs and hinge pins to drop some weight plastic its already lighter than the kit but those parts are the only other way to get lighter ,, i just broke the transmission case the ball stud pulled out so the cf rear camber link is pretty needed i only have the rear cf tower but diggy desighns makes a nice all cf front tower so theirs no aluminum metal types as the inner camber links ,,, has anyone weighed a rtr without electronics vs kit no electronics vs custom with cf/titanium ,setup i wouldnt change mine if i threw in a 17.5t in maybe lower oils just to handle the straights and bumps better but blinky you wanna downside so you dont need tons of pack and if your running light then maybe lighter on the springs to
P6 is offline   Reply With Quote
Old 02-04-2013, 11:28 AM   #10071
8ight-e's Avatar
Trader Rating: 57 (100%+)
exotek front bulkhead, front chassis weight, ackerman (steering)
Rear alum hinge pin holders FR and RR (ie both sides of the rear)
I guess the rear shock tower depends on how often you crash, specifically if you land hard on the top (upside down). I've never broke one or even seen one broke. (knock on wood lol)
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 02-04-2013, 12:05 PM   #10072
Originally Posted by mr. Jepsen View Post
Hi.
I need a rear swaybar for my DEX210 - does anyone know which one
will fit??
René
Denmark
I've used a b44 sway bar before when I run on really high bite carpet mid motor.
chet is offline   Reply With Quote
Old 02-04-2013, 12:08 PM   #10073
Originally Posted by flame56mx View Post
I believe he was talking about the front C-hubs, RDRP looks to be coming out with some:
http://www.facebook.com/media/set/?s...2913017&type=3
This sure would help if we could get are hands on them? I'm almost out of caster blocks.
Has anyone found a caster block off another car if it fits? I was thinking of trying a RB6's?
Old 02-04-2013, 12:34 PM   #10074
zipperfoot's Avatar
Trader Rating: 16 (100%+)
FYI, I continue to receive questions about Prograde Racing, so I started a thread in the Chat Forum. Have at it guys and gals.
Have you dealt with Punch it, HiRev Hobbies, Prograde Racing?
zipperfoot is offline   Reply With Quote
Old 02-04-2013, 01:59 PM   #10075
Trader Rating: 42 (100%+)
anyone noticing the front droop screw stops/ arms packing up with mud?
i noticed my car was great for the first 3 minutes of a heat sunday then like a light switch went to shit for the rest of the round.
i got back to the pits and found soft clay packed up in the arm/droop screw area limiting the droop.
i know i had over jumped a small jump to flat to cut a corner off, as its the faster line.
Just trying to decide if i should cut the droop stops off the front or not?
bumpsandjumpsrc.com
Scale Speed - High Performance Dirt Oval
ShtLuck is offline   Reply With Quote
Old 02-04-2013, 03:41 PM   #10076
P6
i am not a good driver so tons of nose dives and hard landings i noticed i had a problem with that real bad i used 1000 grit around the inside so smooth the plastic and simple green but wipe it out it helped it fallout alot easier to me and then i have the revolution front suspension block the aluminum doesnt stick to it alot ether
Old 02-04-2013, 03:51 PM   #10077
zipperfoot's Avatar
What is a good fighting weight for this buggy?
Mine is at 1635g with a bunch of bling and aluminum towers.
Old 02-04-2013, 04:08 PM   #10078
i guess i need to start cutting before practice tomorrow....
bumpsandjumpsrc.com
Old 02-04-2013, 04:09 PM   #10079
DBL15's Avatar
my stock one with carbon chassis and carbon towers etc with lightened parts is just over 1500g
my mod one with the same parts just a plastic chassis is just around the 1560g mark
i am using shorty packs only as well 3800 venom
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 02-04-2013, 04:37 PM   #10080
ekt
ekt's Avatar
TD has a good explaination on their site http://www.team-durango.com/in-the-p...rticle_id=4472
As 8ight-e said, suspension holders and rear towers are the weak spots if you have hard crashes. You can find a list of option parts here (a website I am making) http://durangofansite.com/DEX210aftermarket.html
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
