Like Tree43Likes
Old 10-22-2011, 07:53 PM   #991
Originally Posted by teeforb View Post
So far!
Nice! Can't wait to start on mine this week. Did you go 3 or 4 gear setup. I am doing rear 3 gear on mine
JayBuc is offline   Reply With Quote
Old 10-22-2011, 07:59 PM   #992
Matt Howard's Avatar
Race one is in the books and the verdict is in, this car ROCKS Played with shocks and tires most of the day and ended up with 4 hold 1.3's with 30wt and dark green up front and 4 hole 1.2's with 20wt and black springs in the rear. This car is SO smooth on the track, plenty of steering and the shocks are awsome. Only problem I ran into is popping the camber link off the rear hub, happened twice in practice and my first qualifier before I swapped it out with a losi ball/cup setup, no problem after that.
One happy DEX210 owner
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-22-2011, 08:01 PM   #993
trx-1racer's Avatar
Originally Posted by JayBuc View Post
What do you mean longer wheelbase?
In my humble opinion, Durango will find that with the success they have with this car, that they will want to make sure they have a competitive car for all situations. Which would mean the development of a longer chassis for large/fast tracks. (also good for the R/C gods that can actually use a 6.5 on 60C+)
However, the car looks really good right out of the box. No need to jump to far ahead on the development time line.
www.shortcoursehobbies.com
T-RCE Slash 4x4 - Kyosho SC-R - TLR 22
Think you're fast? Try racing in Arizona, it's like going to the Nats every weekend...
trx-1racer is offline   Reply With Quote
Old 10-22-2011, 08:01 PM   #994
Glowster21's Avatar
Trader Rating: 116 (100%+)
Seeing that the motor is on the traditional side it's an RM3 setup. The RM4 flips the motor to the other side.
Glowster21 is offline   Reply With Quote
Old 10-22-2011, 08:28 PM   #995
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
As u see in my pic, I'm running saddle packs
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 10-22-2011, 08:38 PM   #996
teeforb's Avatar
3 gear for now
Old 10-22-2011, 08:46 PM   #997
teeforb's Avatar
I notice my EPA are off. 100 on my side and 130 on the other. Any one else notice this?
Old 10-22-2011, 08:57 PM   #998
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
If your links are the same left to right then look at the steering rack while the cars tires are centered. IF the rack is off to one side then you need to adjust the steering link to servo connection.
Mine is only different by 8 on the epa's left to right.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-22-2011, 09:19 PM   #999
teeforb's Avatar
It's straight. But I'll give it another look!
BTW , u can see its staight by the pic.
Old 10-22-2011, 09:34 PM   #1000
Trader Rating: 19 (100%+)
Did you center the rack with the subtrim first? My subtrim is about 20 to one side, but the epa is within 5 of each other on the steering throw.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 10-22-2011, 10:11 PM   #1001
teeforb's Avatar
No subtrim
Old 10-23-2011, 06:41 AM   #1002
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Time to take it apart, post some pics of all the parts layed out please.
This is a simple diff to build. There is only one loose shim that could be missed. IF trimming the outdrive "nub" helped then the thrust assembly isn't full seated.
I'll take some pics later today.
The c clip is fully seated and thrust barrings are in correctly I'M POSITIVE.
I rebuilt the diff with ceramic balls and it felt like there was spot it was tighter when turning it out of the car.
Are there any other manufacturer rings that will fit the diff, something available?
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
[email protected] or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 10-23-2011, 07:15 AM   #1003
Trader Rating: 17 (100%+)
Just looked at a 210 at the IhobbyEXPO and it looks great. They also showed me a DEX408 electric chassis that just showed up too. The Durango rep didn't know too many details on the 210 about running stock so I may have to take everyone's advice and modify some other spur gears to accomodate a stock class.
Right now I'm torn between getting a DEX210 Buggy or a Losi 22T Stadium truck.
My concern with the 210 besides making in run in a stock class is parts availability. The distributor told me that they are just having issues getting the parts into the states and enough of them. Anyone found this to be the case?
Thanks for the help.
Bob
LOSI 22, LOSI 22T, LOSI 22-4, MST FXX-D drift, Axial Crawler
bobsavenger is offline   Reply With Quote
Old 10-23-2011, 07:21 AM   #1004
Only unique DEX210 parts available are shock towers and wing mounts at the moment. I'm sure parts support won't be a problem soon though, alot of different shops and online stores stock Durango parts for their other vehicles. HRP stated they're working with RW to make spurs in smaller sizes, hopefully they'll be available soon.
Good luck finding a kit now, most places I know of are sold out at the moment
RCTech #361
Old 10-23-2011, 07:22 AM   #1005
Glowster21's Avatar
A Main seems pretty well stocked, I'm also lucky enough to have 3 LHS's that stock parts too. No issues as of now that I can see! As for stock, until the next batch of spurs comes out, SLOWLY ream the center of an Associated spur. We did it on the Schumachers for a while and we had to make the hole much bigger. For the 210 it should only need a little taken out, reducing the odds greatly of throwing off the spur on the shaft. This buggy should be an animal in stock class once you can gear it.
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
