Like Tree26Likes
Old 02-01-2013, 06:07 PM   #10021
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Bman's 3XNT View Post
Make sure you make some kind of skid plate for the front kickup! The chassis breaks there. I have one to prove it. Looks awesome though!!
I am using the front skid plate from the sct. Just cut it down and it works great.
Originally Posted by SUPERLOOPER View Post
That has to be one of the best looking cars I have seen.
Brian
Thanks!
Here is the car complete.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 02-01-2013, 08:49 PM   #10022
P6
flip those front lower shock eyelets around atomic long side goes front ,page 555-556 i double checked the buggy looks great you should be proud of it
P6 is offline   Reply With Quote
Old 02-01-2013, 08:57 PM   #10023
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
Really nice car John!!!
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
Old 02-02-2013, 04:16 AM   #10024
Thanks, but I purposely run in that direction. When they are run like that they are perfectly parallel with the tower. I also run an extra 2mm spacer in rear to make rear shock parallel with tower.
Old 02-02-2013, 04:40 AM   #10025
i am a dex210 owner. i like this car but i wish i would get some of the tuning, as the asso b4.2 has as standard
( alloy on the shocks, titan turnbuckles, alloy rear hubs, alloy servo mount, servo saver, alloy battery nut, alloy shock mounts, a good ball diff, +8mm chassis, carbon battery strap, tin nitride shock shafts...)
it cost much to get the dex210 on the b4.2 tuning level.
mihaelbencek is offline   Reply With Quote
Old 02-02-2013, 05:00 AM   #10026
kevinpratt823's Avatar
Building this kit right now. My first Durango, and first 2wd car, but I have many others.
Is it normal to be short a couple screws and shims in the first couple bags? Is there any baseline setup for initial build?
Thanks.
May you always hold your line, and keep the rubber side down.
My private track- https://www.youtube.com/watch?v=XC3HpcDO4Ig
kevinpratt823 is offline   Reply With Quote
Old 02-02-2013, 05:30 AM   #10027
majorsmx521's Avatar
Trader Rating: 44 (100%+)
Default check next bag
Thanks.
my kit had extras? there is sometimes a bag of misc hardware?
check for it
should be all there Durango quality control is pretty good
521DESIGNS PAINT
R.I.P TQ Speedway Boise
majorsmx521 is offline   Reply With Quote
Old 02-02-2013, 05:30 AM   #10028
sparkwraps's Avatar
Trader Rating: 34 (100%+)
I think you used the word tuning when you meant hop-ups. Box stock, there is no kit that has more tuning options. You would have to spend $100+ to get all the hub options that come standard on the 210.
"Battery nut" are not tuning - that is show. A "good ball diff" comes with the car - watch the video online and build it right. It will go far longer than any diff you have used.
The buggy is a tuners dream out of the box. Actually to many options for a bulk of the racers out there.
| AFLAC Designs - Custom Airbrushing, in a hurry! | Jakes RC Pro Am - Topeka's Indoor Offroad Track! |
sparkwraps is offline   Reply With Quote
Old 02-02-2013, 05:39 AM   #10029
Trader Rating: 520 (100%+)
+1, couldn't have been better said..
flame56mx is offline   Reply With Quote
Old 02-02-2013, 05:47 AM   #10030
hi there.. yes i mean hop ups :-)
if i look how much set up option is on the car, this would be the other positive side of the dex210.
the other + on the dex210, is how bulletproof the car is.
Old 02-02-2013, 06:15 AM   #10031
RC10Nick's Avatar
After breaking my second rear tower of the season last night (in the middle of the main, might I add), I decided I should invest in a sturdy CF tower. The exotek looks like the best option, but its out of stock. Does anybody know how long Exotek generally takes to restock?
What are other good options? I know about Tresrey, but they are a little on the pricier side.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 02-02-2013, 06:18 AM   #10032
check for it
It was bag A, with the chassis. I was short 2 tiny shims and 2 screws.
Now I'm having trouble assembling the diff, should the caged thrust bearing fit all the way onto the shaft? Only one side plate(that sandwiches the caged bearing) of it will, on the other side plate the hole is a touch too small and won't go past the threads. Something doesn't seem right to me...............
Edit- searched and found a link to the description/video. Thanks.
Old 02-02-2013, 06:30 AM   #10033
Default diff
i have found that the diff needs to be broken in very carefull!
take some extra time to break it in, and it seems to work best a little on the tight side? (bench testing) on the track feels free as any other diff
521DESIGNS PAINT
Old 02-02-2013, 06:33 AM   #10034
Default Exotek
Exotek stuff is super trick!! fits perfect!
might shoot them an email? they seem to only be out a couple days at most?
521DESIGNS PAINT
Old 02-02-2013, 06:42 AM   #10035
Khador12's Avatar
Stormer Hobbies has the Exotek rear shock tower in stock.
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
