Like Tree23Likes
Old 01-17-2013, 06:58 AM   #9751
discgolferlee's Avatar
Trader Rating: 42 (100%+)
Originally Posted by mulepic View Post
Can you use the buggy knuckles on the SC to get those tuning options?
no
sc uses hex to mount wheel where as buggy rim sits on bearings on axle.
different axle setups.
discgolferlee is offline   Reply With Quote
Old 01-17-2013, 07:42 AM   #9752
Trader Rating: 29 (100%+)
Just an FYI guys. Promatch Racing has there new 4600 80C shorty pack. I can tell a good difference between the pop of this and my Losi 60C and Promatch 65C shorty's that I have. Just over $50, I have 4 of them and all are great.
http://promatchracing.com/products.php?cat=38
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 01-17-2013, 08:40 AM   #9753
link removed
Old 01-17-2013, 08:57 AM   #9754
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Originally Posted by discgolferlee View Post
no
That brings up a question a have.
I am building an DEST210 truck and noticed the kit came with front steering knuckles that use bearings, and the same front knuckles that the 210 uses with inserts. The parts appear swappable.
My question is can you convert the front end to hex? I know the truck uses 15mm hexes, but I have a set of Jconcepts 12mm hexes laying around and found they seem to fit.
I was wondering if anyone has tried this? My reasoning is if I could convert the buggy to 12mm hexes all around, then I could use b4 hex wheels from Avid, Proline, Jconcepts, etc. Much easier to find than Durango 210 wheels.
zipperfoot is offline   Reply With Quote
Old 01-17-2013, 09:25 AM   #9755
hi there
i have the durango desc210. he uses hexes in the front.
so i can switch the front and rear wheels. i like it because the front wheels doesnīt need to much grip. so i can swithc the old rear wheels to the front. itīs perfekt
just look at the TD site, which partnumber you need.
it would be a direct fit to the dest210
mihaelbencek is offline   Reply With Quote
Old 01-17-2013, 09:31 AM   #9756
Trader Rating: 21 (100%+)
brushless hobbies has some great new 75c shorty packs for 46 bucks!
http://www.brushlesshobbies.com/2S-7...ty-_p_193.html
If you don't want to deal w/ Stan that pack looks to be the same as:http://www.hobbyking.com/hobbyking/s...dProduct=33217
Unfortunately it is out of stock in the US but international shipping has been quicker than usual.
mulepic is offline   Reply With Quote
Old 01-17-2013, 09:36 AM   #9757
Khador12's Avatar
I think this is what you are looking for.
Billy Stewart
Xray T4 17
Khador12 is offline   Reply With Quote
Old 01-17-2013, 10:16 AM   #9758
for sure not the same pack. I know the supplier and it is in no way shape or form associated with turnigy or hobbyking
but anyways back to the topic of the vehicle..
Old 01-17-2013, 10:27 AM   #9759
What the heck is that? I click your link to Brushlesshobbies and 1st thing that comes up it a rant back and forth with a customer! I read the whole thing and yes the customer sounds like a tool thats ignorant, but for a buisness owner to get into a back and forth like that and post it on the website is 1000% unprofessional, childish, and flat out wrong. Just seeing that will and does turn people off. Me included. I had never heard of this company until today and wow what a 1st impression they have left. Sorry guys rant over.
Old 01-17-2013, 12:17 PM   #9760
sorry not my site. He has some issues with a customer ranting and raving and slandering him. I don't want to start up garbage here. While I may not agree with this business practice I will say the batteries are great!! especially the shorty packs..
back on topic of vehicles
Old 01-17-2013, 04:55 PM   #9761
Send a message via Yahoo to nitro-rob Send a message via Skype™ to nitro-rob
I personally like the stock chassis. Yes because with that low of rear toe the car wants to go straight and not turn.
1.) Up your rear toe between 3-4 play with it to where it turns better but doesnt get loose.
2.) lighter front spring
3.) little heavier rear spring
4.) go to 4 hole 1.3 pistons rear 1.2 pistons front
5.) I would look into 35wgt front and 30wgt rear.
6.) move your battery forward.
You can try these changes, do not change them all at once do 1 at a time so you know what the change is doing. Unless you want to ditch your current setup all together.
Walkman, thanks for the tips. I will incorporate the changes one at a time to feel them. Unfortunately I am waiting for a shock tower so I will have to wait. I have never been able to 'drive' this buggy yet.
I will report back.
DEST and DEX 210 front hubs are the same (its where I get my spares when I break mine).
nitro-rob is offline   Reply With Quote
Old 01-18-2013, 05:26 PM   #9762
Redwings's Avatar
Originally Posted by Redwings View Post
I have just recently taken my tranny apart for maintenance due to some binding issues. I put the tranny back together as instructed but still have the binding issues.
I've looked very closely and found out now that the slipper plate has some play from side to side. I tighten down the spring yet still big time slipping and some play from side to side. I have added a washer onto shaft on the inside (back) slipper plate that goes through the motor plate. Now no slipping or play.
Is there a chance that the inside slipper plate has worn out enough to cause the play from side to side and not allowing the slipper to tighten?
Ok guys, I posted this a few days ago but yet have had no reply's yet several other posts have gone up. I would appreciate some help. thanks
Redwings is offline   Reply With Quote
Old 01-18-2013, 05:35 PM   #9763
ekt
ekt's Avatar
Some of the original slipper spacers had an issue with wearing, TD has released a new spacer made with different materials TD310243. As you said, using washers you can create a temporary fix like http://www.petitrc.com/setup/durango...perSpacerWear/
ekt is offline   Reply With Quote
Old 01-18-2013, 07:03 PM   #9764
Redwings's Avatar
Greatly appreciate thanks
Old 01-19-2013, 03:25 PM   #9765
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
You probably have the screws that go through the tranny onto the motor mount too tight. I just put lock tight on the motor mount not the screw it self and just barely snugg them, and it should be fine then.
and the spacer wearing atleast for me didn't cause any binding, just made the slipper plates and slipper pads not bind toghether/mesh together properly.
nolimit208 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
jcr
