Like Tree23Likes
Old 01-16-2013, 07:14 PM   #9736
phq2's Avatar
Trader Rating: 21 (100%+)
thats a good looking car, how do you like it? im kicking around the idea of a different car, im a b4 driver and not a losi fan, just looking for honest input, pros and cons! thanks
phq2 is offline   Reply With Quote
Old 01-16-2013, 07:27 PM   #9737
Trader Rating: 29 (100%+)
Originally Posted by nitro-rob View Post
Thanks, Walkman. You are spot on with the pushing. Is it just the toe that made you think that? I am using losi 27.5 in the rear and 32.5 in the front. drk blue spring in the front and light blue in the rear (kit springs, I am waiting for the spring kits). Pistons I don't remember and was sloppy during that part of the build but I was planning on changing them once I did more reading and played with the truck more.
Rear rebar tires now with soft AKA foams.
I have a dimec20. I hesitate to use it since I am driving in a winter series in a heated barn and I wonder if it would be too stiff. I would only make a chassis change to try to see what a flexible chassis feels like. I have read of people saying they tried both dimec chassis but have not heard of any reports.
I personally like the stock chassis. Yes because with that low of rear toe the car wants to go straight and not turn.
1.) Up your rear toe between 3-4 play with it to where it turns better but doesnt get loose.
2.) lighter front spring
3.) little heavier rear spring
4.) go to 4 hole 1.3 pistons rear 1.2 pistons front
5.) I would look into 35wgt front and 30wgt rear.
6.) move your battery forward.
You can try these changes, do not change them all at once do 1 at a time so you know what the change is doing. Unless you want to ditch your current setup all together.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 01-16-2013, 07:36 PM   #9738
mechanic77's Avatar
Originally Posted by the big rc View Post
Got mine on the way!!! So anyone have a solution for the outdrives. From what i hear they wear out really fast.
I realize most guys aren't having outdrive wear issues, but I have....3 sets of outdrives just this winter.....
Here's the fix I came up with:
http://www.team-durango.com/part-inf...artNo=TD310022
Grease the outdrives and put those on it (they fit perfect)....no more issues
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 01-16-2013, 07:37 PM   #9739
Curious what other 210's are weighing in at please post up your weight.
My Carpet setup 1499 without body and 1536 with body full race dress.
I'm now setting up for dirt I think it will add around 20 to grams to the rear as I'm going to try and make the mid motor work.
Old 01-17-2013, 12:17 AM   #9740
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
New paint job, I forgot to back the green on the body with white, so not as bright as I would have liked.
Also my liquid mask was a pain to get off so there are blemishes, Had let is dry for to long (24ish hours), and soaking it in water for several hours didn't loosen it off the body.
nolimit208 is offline   Reply With Quote
Old 01-17-2013, 02:10 AM   #9741
Boadazofa's Avatar
Trader Rating: 33 (100%+)
I like it! Simple but effective! I like green and black aswell and the cab forward bodies look sick!
Lone Wolf
Boadazofa is offline   Reply With Quote
Old 01-17-2013, 02:57 AM   #9742
triplesix's Avatar
This is my carpet missile. Currently waiting for my Proline body to be painted.
Sav÷x 1258TG
Brushless Hobbies 120A ESC (SpeedPassion Mod. Firmware)
CS-Electronic Magnetic Pro2 6.5 Motor
Nanotech 5100mAh Saddle Packs
almost full RDRP Options, Associated gear diff
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 01-17-2013, 05:27 AM   #9743
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
My car without battery is 1407 grams 1690 with battery.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 01-17-2013, 05:28 AM   #9744
Potoczak's Avatar
Trader Rating: 111 (100%+)
Hey guys are the front c hubs and spindles the same between the dex210, desc210r and the dest210r??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-17-2013, 05:53 AM   #9745
discgolferlee's Avatar
Trader Rating: 42 (100%+)
I don't owna dest210 so can't comment on what that uses but the desc210 and dex210 use different front hubs. the buggy has tuning options to change trailing/inline setup and also an axle the rim rides on.
The short course has no tuning options for trailing/inline setup and the wheel rides on a hex on the axle.
hope that all makes sense to you
Short course
buggy
discgolferlee is offline   Reply With Quote
Old 01-17-2013, 06:12 AM   #9746
Can you use the buggy knuckles on the SC to get those tuning options?
mulepic is offline   Reply With Quote
Old 01-17-2013, 06:15 AM   #9747
I sort of knew mine was a little porky: 1505 grams w/o battery 1720 grams w/ 3.6A 2s pack.
Old 01-17-2013, 06:20 AM   #9748
RC10Nick's Avatar
I finally put a gear diff in my buggy. Long story short, I always had to run my ball diff tighter than I would have liked to keep it from barking. The gear diff with 5k diff lube felt great on the track. I was definitely faster around the track with it. My car had more steering all around and felt more stable/planted/confident in the sweepers. I'm happy.
I used an AE gear diff because it was actually in stock (TD's part support is really starting to bug me) but didn't order enough 10x12x.02mm shims. I grabbed some m10 flat washers from work and they did the trick in a pinch. They're heavy, but they'll work.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 01-17-2013, 06:38 AM   #9749
nolimit208's Avatar
Thanks, EVERYONE in my area has cab forward bodies so I am not the biggest fan of them but I am sure I'll come to like it once I have it on the track.
Old 01-17-2013, 06:47 AM   #9750
Yeah that is a heavy little piglet! Im running the 90c orion 5000 hardcase.
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Kremzeek
