Like Tree26Likes
Old 01-08-2013, 12:59 PM   #9601
Trader Rating: 27 (100%+)
Originally Posted by Crawlin View Post
Sure... if you think of it just from that standpoint. However, now that a large distributor carries them, that means that more kits are being sold. With places like Tower carrying them, and the huge discounts for the supersaver stuff, more kits are gonna get sold. So all those parts are going into the kits. Then with more kits being sold, you have a greater demand for the parts as they break. My local "HobbyTownUSA" even started carrying the kits.
It just cancels itself out
Plus it takes a while to establish trends and stock demand. They are working on improving the stock availability all the time and it will improve over time, but unfortunately they did run out of some items.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 01-08-2013, 04:38 PM   #9602
Redwings's Avatar
Originally Posted by Redwings View Post
I have been looking for a sway bar set for the 210 but have not been able to fid one. Is there on out there for it or anything compatable for the 210? Thanks.
Any info guys in my issue?
Redwings is offline   Reply With Quote
Old 01-08-2013, 04:51 PM   #9603
Trader Rating: 112 (100%+)
I don't know if this would work, but the dex410 sway bars mite work? I have not seen any aftermarket sway bar kits for the dex210.
Dave
Sponsors: YuK-Foo Tire Prep
dragracer72nova is offline   Reply With Quote
Old 01-08-2013, 05:18 PM   #9604
Trader Rating: 19 (100%+)
Nothing commercially available at this time. If you can cut/bend some wire of your own, finishing it off isn't bad at all. The straps to retain a sway bar on the front tower are in the kit, so you need a sway bar pivot ball, a few link ends (should have spares from the build, same ones as the servo link uses), and some 8-10mm set screws.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 01-08-2013, 06:19 PM   #9605
Trader Rating: 520 (100%+)
I had one on my car last summer, think I used 410 parts from what I remember.
flame56mx is offline   Reply With Quote
Old 01-09-2013, 06:30 PM   #9606
....and just when you thought you had already seen the dumbest thing in your life..... along comes the 'Los-i-rango'.
Actually, I think it turned out pretty nice.
pete48 is offline   Reply With Quote
Old 01-09-2013, 06:40 PM   #9607
Brushless420's Avatar
Trader Rating: 169 (100%+)
Default GEAR DIFF
Whats the majority running in their gear diff on carpet. Oil or grease? What weight?
Brushless420 is offline   Reply With Quote
Old 01-09-2013, 06:42 PM   #9608
Trader Rating: 29 (100%+)
2,000wgt on carpet.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 01-09-2013, 10:51 PM   #9609
discgolferlee's Avatar
Trader Rating: 42 (100%+)
I know some have had the rear of chassis break especially with the dimec 20 stiffer material. I made a rear brace for my short course tonight that is a little oversized to put some more meat around the rear of the chassis where the screws are tearing thru chassis.
Its not the prettiest and I have no awesome tools to use. Just a dremel and a power drill to get this project done. Lol
Figured I would share in case people were looking for ideas on this.
Nevermind the carpet fibers all over my truck. Needs an air hose taken to it
discgolferlee is offline   Reply With Quote
Old 01-10-2013, 01:43 AM   #9610
Exclamation turnbuckles
Just picked up the Lunsford kit with turnbuckles and ball studs. Which ball cups seem to be the best? Are the lundsford worth a shot? Or should I go with the white J Concepts?
Old 01-10-2013, 04:21 AM   #9611
8ight-e's Avatar
Trader Rating: 57 (100%+)
Originally Posted by Walkman View Post
2,000wgt on carpet.
Ya the gear diff is great on med-high bite.
5,000wt losi diff fluid is ideal, I'd drop back to 2k for loose outdoor tracks.
sorry I run the 5k in the desc210, the photo's above confused me to the thread. I'm not sure how well the buggy would do w/ 5k as I run the ball diff on all surfaces w/ the buggy (at least so far) I have a second dex210 coming setup w/ a gear diff so I will play a bit and see.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 01-10-2013, 04:36 AM   #9612
Use the Lunsford ball cups that came with the turnbuckles. I haven't had a cup pop off since I put them on.
Old 01-10-2013, 07:20 AM   #9613
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Looks good but be carefull of the dust. Breathing in carbon fiber dust is not a good idea. Some say its bad, some say its not. But i would wear a mask when working with the stuff just to be sure.
zipperfoot is offline   Reply With Quote
Old 01-10-2013, 09:08 AM   #9614
oh yeah. mask, long sleeves, gloves,safety glasses. carbon dust isn't something to mess with
Old 01-10-2013, 09:21 AM   #9615
Yeah 5,000wgt seems sluggish on the high speed corners, and the car doesn't rotate goods enough for me that heavy. I also run my ball diffs a little on the loose side. I like the rear a little free.
St Ives RC Club B4Bandit Australian Racing 16568 09-15-2017 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
