Like Tree26Likes
Old 01-04-2013, 10:33 AM   #9541
Radi0Flyer's Avatar
Originally Posted by MODELTECH22 View Post
my situation is the opposite of yours mine is at the end of the outdrive, weird. do you have stock chassis?
Yes stock chassis. The driveshafts are also near the send of the outdrives in my case. See how the diff nut extends quite far? The driveshaft is applying pressure on it at ride height.
The other side seems to have more room. Should the diff be the other way around with the nut on the right side?
Sean
I'll drive it til the wheels fall off and burn
Radi0Flyer is offline   Reply With Quote
Old 01-04-2013, 11:12 AM   #9542
FRONTI3R's Avatar
My thoughts are in the picture attached.
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 01-04-2013, 11:21 AM   #9543
jackcarter3's Avatar
In my mm3 the diff was flipped.
jackcarter3 is offline   Reply With Quote
Old 01-04-2013, 11:30 AM   #9544
TAMAK's Avatar
Trader Rating: 28 (100%+)
+1 I agree with the above!
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 01-04-2013, 11:35 AM   #9545
Radi0Flyer's Avatar
Ok thanks guys. I will have a closer look at the instructions. My son brought it to me to look it over as he's assembling it. I didn't want to have him start disassembling it until I got some guidance.
Sean
Old 01-04-2013, 11:39 AM   #9546
+1 Put the diff spring in a pair of pliers and clamp the pliers closed a few times. The spring will collapse a little bit. When you put the diff back together, tighten it until it is tight and then back it off 1/8 turn. I'll bet the problem will be fixed. Also note that he is showing you that the spacers go under the gearbox (between the gearbox and rear suspension hanger).
______________________________________________________
Team Tulsa - Team R/C Paints by Sonny - Durango DEX410
qwkpony is offline   Reply With Quote
Old 01-04-2013, 11:47 AM   #9547
8ight-e's Avatar
Trader Rating: 57 (100%+)
Sean
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 01-04-2013, 02:21 PM   #9548
ekt
ekt's Avatar
Download the DEX210 manual from the TD site http://www.team-durango.com/pdf/manu...n%20Manual.pdf, there were a few errors that were fixed in it.
ekt is offline   Reply With Quote
Old 01-05-2013, 04:08 PM   #9549
P6
does anyone know if any other savox gears like titanium are universal to the 1251 mg low profile i checked my 1256 but way off ,, i stripped the teeth off one of the center gears from a bad landing , im happy with durango i broke a metal gear servo before anything on the front of the buggy im rethinking the advantage of low profile with steel gears vs titanium gears
P6 is offline   Reply With Quote
Old 01-05-2013, 05:06 PM   #9550
Trader Rating: 19 (100%+)
Yep. It looks like the diff just isn't tight enough. When the diff screw hits the plastic part of the diff nut it feels like it's tight- but it's really not. Just tighten it slowly and 1/8 turn at a time, working it back and forth with your hands (or holding the tire in this case) . The nubs on the diff nut should be approximately 1-1.5mm from the inside edge of the slot in the outdrive.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 01-05-2013, 09:53 PM   #9551
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Default Big bore shock caps
Bought a set Durango big bore shock caps I bought by mistake. The are out of the package but still on their parts tree. 7.00 shipped. PM me if you want them.
F18engineguy is offline   Reply With Quote
Old 01-05-2013, 10:59 PM   #9552
JS
JS's Avatar
Trader Rating: 70 (100%+)
Ouch
My turn to break a Dimec chassis.
No major crash. Got a bit sideways off a crossover jump and landed clean.
Argghhh, just when I finally had the buggy dialed for 17.5 Blinky.
JS is offline   Reply With Quote
Old 01-05-2013, 11:18 PM   #9553
Hey just finished my DEX210 and I was wondering how people with an 8.5 brushless are gearing their cars. I have a 85t RW sour in it right now. I also have a 83t RW spur.
djtang88 is offline   Reply With Quote
Old 01-05-2013, 11:25 PM   #9554
Oasis's Avatar
Trader Rating: 36 (100%+)
Bummer..broke my dime20 chassis..didn't notice till last night but I put the stock 210 chassis on last night..and my stock chassis 210 was freakin dialed today..gotta love this car..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 01-06-2013, 12:05 AM   #9555
JS
JS's Avatar
I wish I could put the alu chassis back on.
I had a hard time dialing it in for 17.5 blinky. Just too heavy.
No interest in putting the alu chassis back on.
Not going to spend $$$ on a CF chassis.
RDRP alu chassis looks nice - but at 11mm might be too long.
My local track is small to medium size.
Using the rear portion of the alu chassis is a great idea.
The dimec chassis was perfect.
Not sure if I will buy another dimec anytime soon, until an actual fix comes up.
For now the buggy will be sitting in the garage - lol
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
