Like Tree28Likes
Old 01-02-2013, 08:25 PM   #9511
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Have any of you guys had to add weight after going to a 17.5? I just put one in and noticed it is smaller and lighter than my 13.5.
zipperfoot is offline   Reply With Quote
Old 01-02-2013, 08:26 PM   #9512
zipperfoot's Avatar
Originally Posted by FRONTI3R View Post
Yes they are. So therefore the best spur you could get. I don't understand why that other guy had issues with them? That's all i've been using for the past 9 months without an issue. I think he had some motor or transmission screws get loose for him to eat a spur.
+1
Old 01-02-2013, 08:30 PM   #9513
zipperfoot's Avatar
Originally Posted by Crawlin View Post
i know it sucks, but that shaft was the best investment i've made even though its the only tresrey part i've bought. just made things easier.
if you think you've wasted money on rw spurs, the first couple times you ream out the center and its slightly off and then you start chewing up spur gears again, you'll be pissed.
i'd either search high and low for the durango spurs through all the vendors possible or you can try reaming. I did an ae spur and bored out the center and you could tell it was slightly off. even taking my time. slipper pad shows the offcenter based on how much is showing on each side of the plate.
sucks you had bad luck, and maybe its because i'm running stock motor in the truck, but my 75 in it is lasting great.
The Tresrey slipper plates and shaft are $30. If you wear down a plate or score a line on one of the plates, do you have to buy the whole assembly at $30? Or can you use AE slipper plates?
Old 01-03-2013, 06:12 AM   #9514
llaves's Avatar
Trader Rating: 135 (100%+)
Does anybody know . Of anybody that has the steering knuckle bushings in stock . Or does any one have an xtra set I can buy from them. Or is there any alternative part I can use . Thanks any help is appreciated .
llaves is offline   Reply With Quote
Old 01-03-2013, 06:41 AM   #9515
im just more concerned with the play between topshaft and metal gear. really annoying, though it is same play that exists on TD stock layshaft. I wish tresrey could offer just a replacement topshaft for this slipper conversion. my topshaft is exhibiting rounding of the beveled edges where the gear mates to. Plates with a garodisk have been a non-issue thus far.
glenng is offline   Reply With Quote
Old 01-03-2013, 07:04 AM   #9516
zipperfoot's Avatar
I have noticed recently stock has been low or non-existent on some parts at most of the places I shop. I thought with a new distributor parts would be plentiful. In 2011 and early 2012, i got so sick of hunting for parts for the 410, I sold it. There seemed to be plenty of parts in the later part of 2012, but it seems there is a shortage again.
Not everything, just the things we use most.
Ill check around and see what i can find.
Old 01-03-2013, 08:08 AM   #9517
Trader Rating: 37 (100%+)
I was in your same boat a few weeks ago...had to buy them off ebay. $4 w/$2 for shipping. Better than waiting until Feb. for stock.
jzwolen is offline   Reply With Quote
Old 01-03-2013, 08:22 AM   #9518
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
I have silver one for the 410v1 fits right into the 210 but its a smidgen longer it looks like.
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 01-03-2013, 08:52 AM   #9519
llaves's Avatar
That will work I can always blend it down to size .
Old 01-03-2013, 08:53 AM   #9520
llaves's Avatar
I coudnt find any on eBay either. . Right now I am using one of the servo sleeve mounts but don't want to run like that . It's the only thing I had laying around.
Old 01-03-2013, 08:58 AM   #9521
Send a message via Yahoo to nitro-rob Send a message via Skype™ to nitro-rob
Hi guys, I purchased a 210 a few months ago and I just started racing it. Its a pet project that I am trying to get set up while I focus on other classes.
I am reading through the forum, about 100 pages in the middle done, and I will read more. I am carefully setting the truck up with a lot of assistance from the text in this forum. I have a few observations that I would like your feedback on.
1. I notice that the rear ride height around ~25mm nicely puts the axles level which is good. Its hard to get the front ride height down, I find it not very sensitive to the collar position. I have to have the droop screws all the way out, and the shock on the outer arm mount position (middle on tower) to get things below 30mm. I am running kit springs now (tuning kit coming).
2. I had to run a little droop in the rear (two turns out from flush) to stop the rear end flutter on one side. The dogbone was catching and lifting the arm when the cup and pin are horizontal. I read something of this flutter but can't find the information.
A setup sheet and questions will likely follow when I get some laps in.
nitro-rob is offline   Reply With Quote
Old 01-03-2013, 10:21 AM   #9522
Slash and Burn's Avatar
Trader Rating: 24 (100%+)
I don't know what kind of traction you have at your track, but we just converted my son's DEX210 from RM3 to MM3 to run in stock 17.5 and removed the weights he had up front. You might try running MM3, he loves it and the car is dialed.
Shannon
A big "Thank You" to my son's sponsors:
Pro-Line Racing | O'Donnell Racing Fuel | RCAmerica / Xray | TeamSR
Slash and Burn is offline   Reply With Quote
Old 01-03-2013, 10:48 AM   #9523
zipperfoot's Avatar
Thats amazing. I searched everywhere I could find, even ebay. No one has part TD340004 in stock. The only place that said they were in stock was a site called nankinhobby.com, but I have never heard of them or used them. Tower said mid-January. I can check a few local shops, that have SOME Durango parts. Maybe we'll get lucky.
Old 01-03-2013, 11:02 AM   #9524
Trader Rating: 27 (100%+)
Nankin Hobby is an well established hobby shop here in MI. I personally have not dealt with them, but know of several people that have without any issues.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 01-03-2013, 11:19 AM   #9525
P6
i used ofna steering bushings they took out alot of play and their thicker but dont fit tight so i only had to use 1mm spacer on the lower bushing ,,i just hate to much play im the type to replace what i need to get rid of it
P6 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
