Like Tree23Likes
Old 01-02-2013, 07:16 AM   #9496
Crawlin's Avatar
Trader Rating: 22 (100%+)
i know it sucks, but that shaft was the best investment i've made even though its the only tresrey part i've bought. just made things easier.
if you think you've wasted money on rw spurs, the first couple times you ream out the center and its slightly off and then you start chewing up spur gears again, you'll be pissed.
i'd either search high and low for the durango spurs through all the vendors possible or you can try reaming. I did an ae spur and bored out the center and you could tell it was slightly off. even taking my time. slipper pad shows the offcenter based on how much is showing on each side of the plate.
sucks you had bad luck, and maybe its because i'm running stock motor in the truck, but my 75 in it is lasting great.
Crawlin is offline   Reply With Quote
Old 01-02-2013, 07:21 AM   #9497
Trader Rating: 21 (100%+)
Originally Posted by mihaelbencek View Post
I ordered 3 rw spurs. They are terrible, never lasting longer then 10 minutes. The durango spur i run a couple of wheeks and month in my dex and desc210.
Make sure your slipper pads are nicely placed and that the shaft isn't bent. Also make sure your mesh is set correctly and the motor screws are nice and tight. I've been using my RW for over a year and its flawless.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 01-02-2013, 07:53 AM   #9498
My RW spurs are great also.
Are they not machined ?
My collection :
Durango DEX410/210, DEST410
Tamiya AVANTE, PORSCHE 934 1/10, DF03, TB EVO V, TB02, TRF414, TA04R, TRF501X, TRF511, TRF201, TT01210wb, TXT-1, TLT-1, CLOD BUSTER, TOP FORCE, MAZDA 787, RM-01 +++
KYOSHO INFERNO GT2, ST-RR VE, TURBO OPTIMA, OPTIMA MID LWB, ULTIMA +++
ridgeracer is offline   Reply With Quote
Old 01-02-2013, 08:25 AM   #9499
FRONTI3R's Avatar
Yes they are. So therefore the best spur you could get. I don't understand why that other guy had issues with them? That's all i've been using for the past 9 months without an issue. I think he had some motor or transmission screws get loose for him to eat a spur.
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 01-02-2013, 09:22 AM   #9500
discgolferlee's Avatar
Trader Rating: 42 (100%+)
sounds like user error to me....
RW spurs are the finest I have ever used. Very "round" and accurately machined over the molded gears
discgolferlee is offline   Reply With Quote
Old 01-02-2013, 10:38 AM   #9501
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
hi there
has someone try to reaming out associated spur gears?
i need a 81 spur gear. the schmuacher will fit, i know.
rw spur gears: i dont like the quality of the rw spr gears. they are not round enough.
i like durango spur gears, good quality but 81 size is never avaible here.
i dont wanna to buy the tresrey slipper shaft.
someone try to reaming out the asso spur gears?
i run my dex210 with a 6.5 engine on carpet and want to gears with the smaller spur gear.
asso spur gears are always avaible, so i think its better to try this
thank you
We have a guy at our track that runs through spur gears like crazy... he just can't ever seem to get the mesh right on them... Maybe you should have some of your friends look at your gear mesh. If your typing is any indication of your attention to detail... you may have found your problem. Set your spur gear and then have someone check your gear mesh... those RW spurs are the best thing since sliced bread.... and if you're having an issue with them, then you are going to have an issue with any spur you touch. Spur gears should last longer than "a couple of wheeks and month".
Fishhook
ewashburnaf is offline   Reply With Quote
Old 01-02-2013, 10:41 AM   #9502
Also, best way to set your gear mesh.. if you don't like to "eyeball" it:
Put on a pinion gear one tooth bigger than the one you want to run and put the gear mesh as far into the spur as you can get it. Make sure their is no gap between your teeth at all. Then tighten your motor. Take off the pinion and put the 1-tooth smaller pinion on. Voila, awesome gear mesh.... roll it around to make sure there aren't any gaps that are too big.
Fishhook
Old 01-02-2013, 11:01 AM   #9503
hi there. i would order some new spurīs from rw. i think i got a couple of bad spurs from them.
i just have problem with this 3 rw spur gears. all others are fine.
i will post again
thank you
mihaelbencek is offline   Reply With Quote
Old 01-02-2013, 11:38 AM   #9504
i will post again
thank you
I don't think the problem is the spur gears themselves....
like stated above check your gear mesh. are you using the paper method or any other method or just eyeballing it
Old 01-02-2013, 11:48 AM   #9505
jackcarter3's Avatar
I have toasted 1 rw spur. The motor moved on a big hit so that's to be expected. My current rw has been on for roughly 8 months racing avg 8+ nights a month plus practice. I think they are the best made.
jackcarter3 is offline   Reply With Quote
Old 01-02-2013, 03:08 PM   #9506
Trader Rating: 520 (100%+)
Originally Posted by JKRacing37 View Post
Thanks a lot, I appreciate that!
What are common parts to have in my pit box? Hobby shop at the track doesn't carry Durango parts so I need to have all the spares on hand myself. All I have seen broken at the track is a rear shock tower. We race ozite carpet over concrete, 2x4 boards - not a very forgiving track.
I would say shock towers, front & rear hubs and c-hubs, and maybe tranny cases, some have broken or pulled the ballstuds out of the mounts. I have had no issues with my car, I did let a friend drive it and he broke a c-hub for me..I have had my car since initial release, and its been very reliable..
Lol, I have seen this first hand, those screws like to move around if you don't loctite 'em..
flame56mx is offline   Reply With Quote
Old 01-02-2013, 03:29 PM   #9507
Trader Rating: 20 (100%+)
Hey thats a neat trick.. I have had a hard time explaining it to my boys how to set up gear mesh. This might help... Thanks
TLR 22
Desc410r
zleader_99 is offline   Reply With Quote
Old 01-02-2013, 03:48 PM   #9508
ive been in the hobby 15+ years and i never even thought of that. ive used the paper method tho.
good idea.
twisted is offline   Reply With Quote
Old 01-02-2013, 05:34 PM   #9509
P6
so i just installed the losi lungsford turnbuckles with losi ball studs and titanium hinge pins on before the install i could feel a noticeable difference by hand my gram scale battery is dead or i would have weighed ,,im trying to figure out my bump steer the cf rack i have only has one centered hole my setup is very close to http://www.petitrc.com/setup/durango...2012072829.pdf ....i compensated for cold with 2.5wt under his f/r i get close to 0 bumpsteer with no spacers on steering knuckles or rack i have 37g added on the front but a 44g servo and 30g brass rf the buggy feels great with the sc10 gear diff but i feel like i have almost no on power steering any opinions? the only thing i can think of is more weight in front or black front springs for a little more roll
P6 is offline   Reply With Quote
Old 01-02-2013, 05:51 PM   #9510
Trader Rating: 29 (100%+)
The turnbuckles, and hinge pins are 1 gram each lighter, and each ball stud is .5 gram lighter.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
