Like Tree43Likes
Old 12-31-2012, 03:36 PM   #9466
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
I don't know... petitrc is an awesome resource for all things RC
Fishhook
ewashburnaf is offline   Reply With Quote
Old 12-31-2012, 03:40 PM   #9467
The Czechexican's Avatar
Originally Posted by mihaelbencek View Post
I am a big fan from revolution design racing parts. Thats not bling bling stuff. Awesome stuff
+1 Me too! I have a mix of exo and RDR in my car.
:DEX210:
:DEX410V3:
MARCCA Carpet Racer.
"I Huff SXT 3.0"
The Czechexican is offline   Reply With Quote
Old 12-31-2012, 03:48 PM   #9468
Trader Rating: 520 (100%+)
Originally Posted by onekiwi View Post
Not sure..I have a couple of my pics in there also..lol
flame56mx is offline   Reply With Quote
Old 12-31-2012, 03:52 PM   #9469
Boadazofa's Avatar
Trader Rating: 33 (100%+)
thanks guys you are awesome!
Lone Wolf
Boadazofa is offline   Reply With Quote
Old 12-31-2012, 03:54 PM   #9470
Originally Posted by Walkman View Post
+1 on this setup. Im so close to your setup.....dialed
:DEX210:
:DEX410V3:
"I Huff SXT 3.0"
Old 12-31-2012, 04:32 PM   #9471
P6
what sites are you guys buying exotek from , i just cant stand the gold brass or red color all tho i do have a brass 30g rf ,, im trying to go with a black and silver look
P6 is offline   Reply With Quote
Old 12-31-2012, 04:54 PM   #9472
Exotek If you want more gold
TeamSR if you want blk/silver, though they have much less bling..
Old 12-31-2012, 05:34 PM   #9473
P6
i dont have all the alum brass upgrades as cush does but i ended up very close (ae 32.5 rear losi pink 22 springs,, (ae 27.5 front dark green springs) 10g under servo, 10g bellcrank, and 17g under bulkhead, 44g low profile servo then (30g r/f brass 1.5kick/3.0toe) then my ball diff felt horrible almost locked thats why i had so much push so i switched to gear and it rotates way to easy with 2k may try 3k until the cir clips come in,,, then hopefully revolutions front bulkhead comes into stock and im thinking a brass front battery stop with cf front tower and i already have all the titanium hinges and buckles just to get rid of the lead stick on weights .......im open to opinions and one last favor jonny5 thanks for all your help could you list all the added weight parts to cush dex????? ill find the weights myself but i think i might be a little light or to stiff of front springs i barely roll through corners
Old 12-31-2012, 06:01 PM   #9474
Trader Rating: 29 (100%+)
Glad it's working for you.
I also put my car on a diet, and put on Lundford Turnbuckle kit, and Lunsford hinge pins. Not sure if it's been covered but the Lunsford ball cups fit on the MM setup, it's very close, and almost touches the spur cover when the shocks are fully compressed. She now weights in at 1568gr. The Lunsford cut 1 gram per turnbuckle, .5 gram per ball stud, and .5 gram per hinge pin on average for all pins as the difference in pin size.
I think I will let it stay around this weight. I ran it Friday night and it was perfect.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 12-31-2012, 08:03 PM   #9475
I added weight to the back and front. 21 up front 48 in the rear. I feel it's more planted that way. It could just be my driving style. I have my shocks all the way down in the rear with dark blue springs 27.5. I may try lighting it up some day but I like it right now
:DEX210:
:DEX410V3:
"I Huff SXT 3.0"
Old 12-31-2012, 08:16 PM   #9476
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Can someone please post a pic of the Bulldog body painted up an mounted on their buggy? also does it fit the +8 chassis?
**Over The Top RC - Cars for Kids Program**
***Looking for a responsible person to help run the track and program***
EvanAZ is offline   Reply With Quote
Old 12-31-2012, 08:29 PM   #9477
Trader Rating: 112 (100%+)
Here you go! Bulldog on a Demec+8mm chassis.
Dave
Sponsors: YuK-Foo Tire Prep
dragracer72nova is offline   Reply With Quote
Old 12-31-2012, 08:35 PM   #9478
EvanAZ's Avatar
thank you, just adding it to my shopping cart.
Old 12-31-2012, 09:28 PM   #9479
since were posting pics..
Old 01-01-2013, 09:51 AM   #9480
Does anyone know if these rear hubs will fit the dex210? I believe they are for the 4wd.
Reason I'm asking is that I'm running 'down and dirty' at about 14mm ride height. Handles great on high traction surface, but the dog bones aren't level. I believe using the lower screw hole on these hubs will solve the problem.
Also - I'm sure everyone knows by now, but the Losi 22 springs are quite a bit shorter than the TD springs. Makes a great way of lowering ride height for those carpet guys out there...(requires droop screw adjustment or limiters).
Thanks.
pete48 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16576 Yesterday 07:25 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
