Like Tree26Likes
Old 10-21-2011, 01:34 PM   #931
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Add about 1.5 to 2.0 mm to remove the bump steer.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-21-2011, 02:20 PM   #932
Trader Rating: 19 (100%+)
Originally Posted by Cpt.America View Post
1. Anybody else notice that you cannot run holes 1 or 2 (the outside two holes) on the rear hubs? The angle of the turn buckle doesn't allow it.
2. Factory setup introduces a lot of in-bumpsteer. 1 extra mm of washers needed under the ballstud on the turnblock to get closer to 0 bumpsteer (don't know exactly how much yet, haven't played)
Can you space the ballstud away from the hub carrier to gain the clearance you need? I'll look at the car tonite and see.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-21-2011, 02:36 PM   #933
Alon's Avatar
Are the the losi xxx cr wheels fit to this car?
Alon is offline   Reply With Quote
Old 10-21-2011, 02:37 PM   #934
Matt Howard's Avatar
you can run the rear's if you switch to the pin drive instead of the hex drive. You just need the correct spacers and your set.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-21-2011, 02:39 PM   #935
4mm of spacers gives you zero bump steer when running 30 deg of castor, factory setup is 3mm spacer. As you move the castor either up or down you'll have to adjust accordingly to maintain zero bump steer.
RCTech #361
Old 10-21-2011, 03:08 PM   #936
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I'm sure you could, but I would guess that the spacing required to use hole #1, for example, would be pretty significant, putting a lot of leverage against the hole.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-21-2011, 03:14 PM   #937
to answer #1, just use the extra set of angled ballcups. They're longer so you'd have to use a shorter turnbuckle but I just eyeballed it against my car and they would work fine.
RCTech #361
Old 10-21-2011, 03:24 PM   #938
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
[QUOTE=Quad Racer 34;9810606]Wow, really? You must have the wrong tires or something? The first thing I noticed with this car is how much steering it had without breaking the rear end loose.QUOTE]
I have the soft rebars with proline foams on the front. It's all the local shop had at the time.
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
[email protected] or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 10-21-2011, 03:43 PM   #939
Originally Posted by KainK View Post
Did you only have one bearing in diff? If so that could be part of the problem. This diff should be one of the best if built right.
I am running the 3 gear tranny and my car has a little push to it. I have only got to try 1 set of tires so far. Ill have more wheels tonight to mount tires on so I will have to see if that helps. I only got to put 4 batteries through it last night but it was a lot of fun
I had to take the one out to get it to work. It was like it was not tightening all the way.
Old 10-21-2011, 03:56 PM   #940
if you had to take a bearing out to get the diff to work then something isn't built right. I would take it completely apart and rebuild it exactly by the instructions
RCTech #361
Old 10-21-2011, 04:28 PM   #941
Thats what I did the first and second time. I made a half a lap and it was like I burned up the diff. It just slipped.
I loosened it up spun it a few times and tightened it back up n it seemed fine for a lap and did it again.
Old 10-21-2011, 04:47 PM   #942
Super Moderator
what gearbox are you running? RM3, RM4, MM3, or MM4? Then, which side of the car is the diff screw in? I remember in my cougar, if you had the diff in backwards, the torque from the car would back the diff off... and this diff is very similar to the diff that comes in that car.
Anybody else seeing this?
- RCSpecialties -
Old 10-21-2011, 04:47 PM   #943
Team Tekin
Randy_Pike's Avatar
This sounds like you didn't install the thrust bearing properly. Make sure that you have the thrust washers faced the correct way. There is a "race" in the thrust bearing washer that must face the balls and cage.
Old 10-21-2011, 04:48 PM   #944
Super Moderator
Yep. and the thrust assembly goes down into the diff housing, and the Cclip goes in on top of it, holding it in.... then the bearing.
- RCSpecialties -
Old 10-21-2011, 05:06 PM   #945
BostonNelson's Avatar
Here it is. The Austrian time travel machine
Durango DEX410 - SP GT V2.0 Pro - SP 6.5R - KO 2367 - Futaba 3PM/R603FF
Associated B4.1 FT - SP GT V2.0 Pro - SP 7.5R - Savox 1258 - Futaba 3PM/R603FF
BostonNelson is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
EbbTide
