Like Tree24Likes
Old 12-27-2012, 08:23 AM   #9406
Tunatsol's Avatar
Tuning clay tires on carpet is the problem to much side bite Wich will brake grip after it rolls on to side of the tire. Schumacher blue ninepins in the rear and ninepins or lpf cutstager fronts. In mm the cuts will be more consistent will less tracktion roll.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 12-27-2012, 08:27 AM   #9407
Trader Rating: 29 (100%+)
Originally Posted by RC10Nick View Post
I had the same experience the one time I raced on carpet. The car would roll in the corner then spin out completely. I was so confused because I thought I had gobs of traction running gold barcodes on carpet. I went so far as to get rid of almost all the droop I could, and still had the problem. It wasn't until the track owner walked up to me with a can of Gojo and told me to try it on my rears that I figured out what was wrong. As much traction as I thought I had, it wasn't enough! That Gojo turned those barcodes into a mushy circle shaped pile of traction! No more spinning out after that! In fact, my biggest problem was traction rolling (which is not a bad problem to have). Moral of the story? Maybe you don't have as much grip as you think, even if its more than you're used to on dirt.
I want to make it back to that carpet track some time, only with mini pins and cut staggers instead of the dirt setup I usually run.
Some folks think I will build the car in MM and its magic on carpet, astro , ect. I by no means am saying thats what you were saying, i'm just making a general observation from my experience. I thought that my 1st time on carpet and wow did I get a kick in the pants. Anyway you are more balanced but you have a lot less rear traction compared to RM setup.
Also you need hard inserts. Gold barcodes with hard inserts with a little traction compound and they will work not great but work. I use sticky kicks "white" on slicks and it like running on fly paper. Check my setup it's real close to Jorn's, but a little easier to drive for me.
http://www.petitrc.com/setup/durango...bies201212.pdf
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 12-27-2012, 08:41 AM   #9408
FRONTI3R's Avatar
I'm running the kit 3/1.5 bar. What did you change to? The 3/0 block?
Yes exactly. Helped alot.
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 12-27-2012, 09:00 AM   #9409
RC10Nick's Avatar
I checked your setup earlier and noticed you were running slicks. My barcodes were already pretty worn, and by the end of the night they were basically slicks. At that point they were hooking up like mad. Anyway, have you tried running a mini pin style tire? If you have, how was it compared to the slicks?
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 12-27-2012, 09:29 AM   #9410
Yes, I have rear Schumacher yellow min pins, and dboots front nanobytes in A compound. I prefer the slicks, then min pin/ nano combo. They are pretty close they both feel glued to the track to me. It's just a preference for slicks for me, plus easier to put on traction compound. All my rear carpet tires have cut down 1/8 scale Panther orange closed cell foams in them and proline closed cell in the fronts. Panther is suppose to be coming out with 1/10 closed cell foam. I can't wait make life a bit easier.
Old 12-27-2012, 09:39 AM   #9411
M3Man03's Avatar
I've seen them - they're pretty nice!
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 12-27-2012, 01:31 PM   #9412
Crawlin's Avatar
Trader Rating: 22 (100%+)
Yeah you lucky bastard, you got to rock them where I'm using the cut up 1/8th scale ones
Crawlin is offline   Reply With Quote
Old 12-27-2012, 01:50 PM   #9413
Is there a time frame on when they will be released yet????
Old 12-27-2012, 02:49 PM   #9414
Finished mine today. Can't wait to give her a spin. Only the second time airbrushing, but I think it came out OK. I copied someone elses design to get a feel for it. I'm learning you really need to back-up the flourescent colors. This time I used white.
I'll be running indoors on cork. Currently there is a 10.5 in her. Any suggestions for pinion (no boost)? I have the stock spur. Thanks.
Also, anyone know if there are shorter sensor wires? I really like having a clean wire job, and that one is just way too long.
pete48 is offline   Reply With Quote
Old 12-27-2012, 06:24 PM   #9415
slow_jun's Avatar
Trader Rating: 14 (94%+)
Default Spare Allu Rear Hubs for 210
Guys,
have this lying around, if anyone is interested, do PM me.
WTS - DEX210 Aluminium-Rear-Hub-Carrier-Set
thanks,
Mag 3 taon, tapos isalpak pa sa PAGMUMUKHA KO......... tagal....Deeeeymmm!!!
slow_jun is offline   Reply With Quote
Old 12-27-2012, 08:14 PM   #9416
sweet paint job dude. amainhobbies has shorter sensor cables
glenng is offline   Reply With Quote
Old 12-27-2012, 09:50 PM   #9417
P6
i have novak 10.5 no boos 35* timing geared 75 spur 28 pinion ,we have long straights and fast jumps so im near full throttle on a couple jumps i may go up to 30 pinion but thats the fastest ill ever need
P6 is offline   Reply With Quote
Old 12-28-2012, 04:24 AM   #9418
Tunatsol's Avatar
The largest p gear you can put on is 24 I think. I run that on a 13.5 boosted short straight only about 75 to 80 ft works well.
Josh Youngs
Old 12-28-2012, 05:14 AM   #9419
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
+1
I usually am between 27 and 29 pinion. With a 75T spur. 10.5 T motor w/ timing and sometimes I have to put throttle limiter on around 80-85.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 12-28-2012, 06:43 AM   #9420
Trader Rating: 86 (99%+)
Thanks to all that helped me with my previous issues that I had with this car, it turned out to be in fact the motor that I purchased used from another member here that was in poor condition. I'm guessing the magnets had lost strength and would slip under load leading me to believe that I had slipper/diff issues when in fact it was the motor .
WideOpenThrottle RC is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
CARD
