Like Tree27Likes
Old 12-25-2012, 04:46 PM   #9391
Trader Rating: 31 (100%+)
Originally Posted by Crawlin View Post
sorry, was starting with the box setup WITHOUT the camber link mod from tresrey. so the ball stud is on the gear case like stock with the 2mm shim the manual started with. so that would mean to add the shim
i have the aluminum hubs on it that I took off the short course truck figuring the buggy open wheel would benefit more compared to the truck. so I have the correct amount on that already to get it lined up. now its just on to tuning to get rid of some of this on power push
Oh, well that is completely different. I personally wouldn't try to tune that out with the shims. IMO I would toss that setup, and trade it for something off petitrc that is on a similar surface to what u run it on. I think u will be able to tune it better from one of those setup's.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 12-25-2012, 05:49 PM   #9392
Crawlin's Avatar
Trader Rating: 22 (100%+)
yeah started with chad stenson's setup since its same track and he's been huge help. just starting with it so we will figure it all out. thanks again!
Crawlin is offline   Reply With Quote
Old 12-25-2012, 07:22 PM   #9393
Trader Rating: 112 (100%+)
Ya me too! I should be over on Friday and will be over for the 1st!
Dave
Sponsors: YuK-Foo Tire Prep
dragracer72nova is offline   Reply With Quote
Old 12-25-2012, 08:10 PM   #9394
Crawlin's Avatar
we are usually in the back corner of the pit area by the dirt oval when you come down.
Old 12-25-2012, 09:21 PM   #9395
M3Man03's Avatar
"Durango Row" was it? I think that's what you and Chad were yelling during the race. lol
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 12-26-2012, 06:18 AM   #9396
CRFRCBODIES's Avatar
Trader Rating: 18 (100%+)
The car uses a traxxas slash bumper flipped over
Mr. Chunkys Race Cars
Cfrkc.com
CRFRCBODIES is offline   Reply With Quote
Old 12-26-2012, 02:44 PM   #9397
Laloosh's Avatar
If anyone is looking for a mint 210, let me know fellas. Bind and go
F/S: Durango DEX210 ARTR
Schumacher Cougar KR
If in doubt, stay in it.
Laloosh is offline   Reply With Quote
Old 12-26-2012, 05:06 PM   #9398
Default 210 RTR Gear Diff
I opened up the gear diff, and noticed it only has 1 cross shaft axle with 2 small spider gears, does not look like your typical diff set up with 2 cross shaft axles with 4 small diff gears. Is this normal on RTR ? Or am I missing some parts in this diff ?
Hobby PRO-USA
Agama A8 / A8T / A8E
Team Strike / Sidewinder
Sirio ExTech
Pro Match Racing
Ramirez24 is offline   Reply With Quote
Old 12-26-2012, 05:59 PM   #9399
tedstryker's Avatar
Trader Rating: 75 (100%+)
http://www.team-durango.com/part-inf...artNo=TD210034
all the info you need
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 12-26-2012, 06:02 PM   #9400
Trader Rating: 29 (100%+)
Originally Posted by The Czechexican View Post
Wow. 27.5 in the rear? Any weight in the front or rear? Does the rear end roll?
I have been trying to take the roll out of the rear. It rolls then spins. Ive been trying to calm it down. Does the hevy weight oil up front help. I have 40 up front with the light brown springs and 1.3 4 hole pistons and I have 21 grams up front and I cant get it down to ride height. I to have been using this set up with some tweeks. I been trying to get high roll center in the rear. My links are all the way out and shocks lay down all the way. Tried putting 4 mm under the inner ball studs too.
Originally Posted by Walkman View Post
I have my ride height at 19mm front and rear. I'm running Panther slicks with Proline closed cell from foams in the fronts, and Panther 1/8 scale closed cells cut down in the rear, and battery to the back. I will try to post a complete setup sheet tomorrow.
Here is my setup for carpet.
http://dl.dropbox.com/u/14824938/RC%...210_Carpet.pdf
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 12-26-2012, 10:25 PM   #9401
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Ur missing a set, email durango a pic and they will send you some in the mail.
nolimit208 is offline   Reply With Quote
Old 12-27-2012, 06:48 AM   #9402
RC10Nick's Avatar
I had the same experience the one time I raced on carpet. The car would roll in the corner then spin out completely. I was so confused because I thought I had gobs of traction running gold barcodes on carpet. I went so far as to get rid of almost all the droop I could, and still had the problem. It wasn't until the track owner walked up to me with a can of Gojo and told me to try it on my rears that I figured out what was wrong. As much traction as I thought I had, it wasn't enough! That Gojo turned those barcodes into a mushy circle shaped pile of traction! No more spinning out after that! In fact, my biggest problem was traction rolling (which is not a bad problem to have). Moral of the story? Maybe you don't have as much grip as you think, even if its more than you're used to on dirt.
I want to make it back to that carpet track some time, only with mini pins and cut staggers instead of the dirt setup I usually run.
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 12-27-2012, 07:04 AM   #9403
FRONTI3R's Avatar
What rear toe bar were/ are you running? I had that same issue till I went with less Anti-Squat.
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 12-27-2012, 08:06 AM   #9404
Looking at the picture on the box it looks like it only comes with 1 - if so I think you can just buy the shaft and gears as a set if you want 4. The extra gears just help take the load if you run higher torque motors than supplied
TLR 22 3.0
TLR 22 3.0SCT
Hobbywing
Sanwa
losi8lunie is offline   Reply With Quote
Old 12-27-2012, 08:15 AM   #9405
RC10Nick's Avatar
I'm running the kit 3/1.5 bar. What did you change to? The 3/0 block?
JT RC Products
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
