Like Tree21Likes
Old 12-22-2012, 09:31 PM   #9331
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by RC10Nick View Post
anybody else have this happen to their diff outdrive?
This is only after 5 weekends of racing on this car. The other outdrive looks perfectly fine, but this one looks like its gone through several seasons of racing. The wear actually caused the cvd to pop out in the middle of my main today.
Anyway, I think I might go with a gear diff instead of just replacing the outdrives. Who runs and likes the gear diff?
Mine did the same thing after a month or 2. I really like my gear diff, run it with with just a little bit of black grease inside of it and I have not touched it since the beginning of summer and it just gets smoother and smoother. So I really like using it over the ball diff and stays smooth way way longer. Ya if you put the ball diff together with all ceramic balls and treated rings it can be smoother but at a much much higher cost and more maintenance. So with just a small fraction of performance downside (which the majority wont notice) its worth it.
nolimit208 is offline   Reply With Quote
Old 12-22-2012, 09:31 PM   #9332
Trader Rating: 29 (100%+)
I'm running the gear diff with 2000wt. I run on carpet though, I haven't had this car on dirt. The gear diff is feels real stiff and tight when you 1st drop it in to the point it feels wrong. Just RUN the car the diff will smooth out in 5 mins or so and be perfect and smooth. Also do NOT use the gold ball diff shims. The gear diff doesn't require the shims.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 12-22-2012, 10:10 PM   #9333
The Czechexican's Avatar
I ripped a ball stud out of the transmission case tonight. this was my fix Does anyone run this http://www.tresrey-usa.com/tresrey-a...est210desc210/ If so how do you like it and is it worth it. It got me threw the night and I even took 2nd in the main but it pushed like a school bus.
:DEX210:
:DEX410V3:
MARCCA Carpet Racer.
"I Huff SXT 3.0"
The Czechexican is offline   Reply With Quote
Old 12-22-2012, 10:12 PM   #9334
jnslprd's Avatar
Too much droop would do this on my 410. At full extension the cvd would bind and either wreck the outdrive or break the drive shaft. Always on one side.
WGAS, WGAF
jnslprd is offline   Reply With Quote
Old 12-22-2012, 10:17 PM   #9335
Trader Rating: 520 (100%+)
Originally Posted by The Czechexican View Post
I ripped a ball stud out of the transmission case tonight. this was my fix Does anyone run this http://www.tresrey-usa.com/tresrey-a...est210desc210/ If so how do you like it and is it worth it. It got me threw the night and I even took 2nd in the main but it push like a school bus.
Lol, wow how many shims would it take to raise roll center that high?
I use the part you are referring to, though I have never had a problem with the stock ball stud mount. Its definitely a permanent fix to your issue..
flame56mx is offline   Reply With Quote
Old 12-22-2012, 10:33 PM   #9336
brokenmoto's Avatar
Originally Posted by Peli View Post
+8 mm Carbon chassis...worthy upgrade,more flex,more traction outdoors,all I run.Plus,its nearly on the 1500 weight limit with this.
Was ripping ballstuds out of the gearbox every heat...crap engineering and plastics,went for the Tresrey CF brace or the Rango was getting binned.
Electrics layout,REC sits vertically behind shorty,super neat,no wiring outside battery tray
Avid springs and Tresrey red spacers everywhere,new Hitec servo
Brass Ballstud mount 8ight racing CF V2 towers
TSR racing wheel nuts and clear shock seal sets with red bleeder screws....
The TSR seals are magic....just run a 4hr enduro on the weekend,probably run for 1 and half hrs,no leakage anywhere.they have already done 4 club days.
Ghea Tapered pistons inside shocks
The AE 12mm big bores spring retainers are the same...few colour and material options then.
Love the DEX210,but its definetly overrated in a few area's,strength being 1 of them.
I ripped probably 6-8 ballstuds out of the gearbox in 2 weekends.
The sidepod plastics are shit.Strip so easily,just from use.
The gearbox removal is a nightmare.
The arms and hub inserts slop out super quick compared to 2 yrs running a B4.1.
Can't handle the torque hit down low from Mod motors as well as a B4.1,it will twist the chassis up,the B4.1 just drives through the torque hit.
Shocks are awesome
Slipper is great
Balldiff is in another world,love it.
Steering is amazing,so much,and so sharp and slop free.
Now I have a setup on it,it flys,and will kick my B4.1s ass easily....
Incredible car in the air,can whip it hard,the torque hit that upsets the chassis on the ground can save some huge angles in the air,and level itself for the down ramp....
Now it is strong enough to deal with my 7.5 and my hack driving,it's unreal!! Faster,easier to drive,but far from stock,and super exxy!!
I LOVE THIS CAR!!!!!!!!
Thanks for the honesty. Most people think thier stuff is great because it's what they have. My local shop owner has 1 & he's the only 1 running them. I've been racing off & on for 30 yrs & as soon as i saw rear ballstud placement, all thoughts of getting 1 went in the trash. Now i see there's an allturnitive, it will be my next car. Thanks again!
brokenmoto is offline   Reply With Quote
Old 12-22-2012, 10:50 PM   #9337
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Worthy upgrade in my opinion. Have not had an issue since. My car did not push at all after the upgrade.
If slow is fast, how come I'm still slow?
zipperfoot is offline   Reply With Quote
Old 12-22-2012, 10:55 PM   #9338
zipperfoot's Avatar
Update. I upgraded to Lunsford turnbuckles, with rpm long ball cups and AE ball studs from the tc6. Have not popped one ball cup, or had to make a camber adjustment since. Recommended upgrade over stock.
Old 12-22-2012, 11:16 PM   #9339
onekiwi's Avatar
Originally Posted by vw addict View Post
So you think it's the slipper and not the diff? The diff is really strange feeling but it doesn't explain the not going part...
I was replying to rcjunky but you got in there first. Happy you got your solution
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 12-23-2012, 05:26 AM   #9340
Ya know I had hard time understanding how roll center worked. Now I know exactly how it works. Awsome going to order one today. Thanks mx.
:DEX210:
:DEX410V3:
"I Huff SXT 3.0"
Old 12-23-2012, 06:17 AM   #9341
RC10Nick's Avatar
Ok, so next question for you gear diff guys. Do you have the same problem with your outrdives wearing out?
It seems the TD gear diff will be out of stock for a bit. Should I wait for that, or go with the AE gear diff? Is there a difference in quality between the two?
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 12-23-2012, 06:42 AM   #9342
murky123's Avatar
I have ran a durango geardiff the whole season on outdoor dirt. the outdrives still look brand new.
the AE gear diff need more shimming
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 12-23-2012, 07:29 AM   #9343
Trader Rating: 31 (100%+)
AEGear diff needs a lot of shimming, like 8 shims or so each side. Also the AE main gear is a touch smaller than the Durango one, so I am not sure how people are using it as a direct replacement.. or if they really checked it out before they put it in.
That is why I build a hybrid ball diff using the the Durango main gear and balls and every thing else is AE.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 12-23-2012, 07:29 AM   #9344
8ight-e's Avatar
Trader Rating: 57 (100%+)
With the dex210 kit you do have to set the rear limiter so while at full extension you don't have binding, this will put additional stress on the motor and will wear the outdrives much faster. I'm pretty sure this would be the same with the gear diff. Maybe certain setups are more prominent, but using the 1.5 kick and 3 toe, I absolutely have to set the droop.
+1
I've had the ae and losi buggies in the past (not the 22) and not enough can be said for not crashing into the pipe or wall in terms of breakage with any of them. If you are just starting with the buggy format maybe limit the throttle until you are making perfect laps..then add speed as needed. In months I've only popped one cup off and it's cause I caught a pipe. While it sucked that I lost two laps, the vehicle did not break and thanks to the marshall finished the race only 1 lap back as I was throwing some wicked fast laps down. This last week I broke my first part on what seemed to be a soft hit, but it must have caught the wheel just right on a wall area as it tore my inner hinge pin right out of the front plastic retainer. If you replace anything on these durango's it should be (as with any vehicle mind you) the FF,FR(or bulkhead),RF,RR hinge pin holders.. that plastic is just way too soft on that part iMO.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 12-23-2012, 07:31 AM   #9345
+1
U need to adjust your rear ball stud washer and your push will go away.
MBX6-ECO, B5m
St Ives RC Club B4Bandit Australian Racing 16562 Today 05:07 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
