Like Tree27Likes
Old 12-22-2012, 01:14 PM   #9316
Trader Rating: 38 (100%+)
Anyone having trouble with their gear diff? I ran mine for two race nights with no trouble. In last night's first qual I had no forward go, kind of like if someone loosened my slipper up like 4 turns. I just pulled everything apart and it feels like maybe the gears aren't catching like I need a small washer under the sun gears like I had to do on my A/E gear diffs. That being said it is still notchy feeling, almost like it's not broken in yet. What the heck is going on? Luckily i had the trusty B4.1 waiting in my hauler to run the 2nd qual and main.
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 12-22-2012, 02:15 PM   #9317
onekiwi's Avatar
If you can try the AE HT pads or even the schumacher ones both fit and are a little thicker.
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 12-22-2012, 02:22 PM   #9318
So you think it's the slipper and not the diff? The diff is really strange feeling but it doesn't explain the not going part...
Old 12-22-2012, 03:07 PM   #9319
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Or layshaft spacer, the stock one is a soft alum material and crunches easily making it impossible to tight the slipper enought to pinch it. If you look at your lay shaft and it looks worn at all u can run thicker pads or put tape on the backside of them to make them thicker and run temp while you wait for a new layshaft spacer, They have a new one out which is a hard finished material which will last a lot longer.
nolimit208 is offline   Reply With Quote
Old 12-22-2012, 03:16 PM   #9320
Thanks bro, great info there
Old 12-22-2012, 03:39 PM   #9321
ekt
ekt's Avatar
Another temp fix is to put a nitro clutch shim with the spacer http://www.petitrc.com/setup/durango...perSpacerWear/. #310243 is the updated layshaft spacer.
ekt is offline   Reply With Quote
Old 12-22-2012, 03:53 PM   #9322
M3Man03's Avatar
Originally Posted by javijp View Post
There are other brand compatible mount?
http://www.amainhobbies.com/product_...l-O-Ring-Set-8
Is there something better? I've found that I have a lot of leaks.
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 12-22-2012, 05:22 PM   #9323
perfect, you guys are awesome, i'll take a look at these fixes.
Old 12-22-2012, 05:51 PM   #9324
Trader Rating: 520 (100%+)
I haven't used these before, but have heard they are good:
or these work, but I had to do some mods to make them feel smooth.
flame56mx is offline   Reply With Quote
Old 12-22-2012, 06:30 PM   #9325
tedstryker's Avatar
Trader Rating: 74 (100%+)
got new ink....just thought I'd share...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 12-22-2012, 06:32 PM   #9326
tedstryker's Avatar
never said i was a photographer...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 12-22-2012, 06:34 PM   #9327
tedstryker's Avatar
last one...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
Old 12-22-2012, 06:48 PM   #9328
majorsmx521's Avatar
Trader Rating: 44 (100%+)
very trick!!
521DESIGNS PAINT
R.I.P TQ Speedway Boise
majorsmx521 is offline   Reply With Quote
Old 12-22-2012, 07:52 PM   #9329
RC10Nick's Avatar
anybody else have this happen to their diff outdrive?
This is only after 5 weekends of racing on this car. The other outdrive looks perfectly fine, but this one looks like its gone through several seasons of racing. The wear actually caused the cvd to pop out in the middle of my main today.
Anyway, I think I might go with a gear diff instead of just replacing the outdrives. Who runs and likes the gear diff?
JT RC Products
https://www.facebook.com/JTRCProducts/
RC10Nick is offline   Reply With Quote
Old 12-22-2012, 09:26 PM   #9330
Trader Rating: 31 (100%+)
Yes I have had it happen to several of my diffs and my friends too. I am sure u were running mod, stock seems to not cause the problem. I think these outdrives suck! I have switched over to AE hybrid diff because of this very issue. Gear diff works, several people on this forum love it.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
