Like Tree23Likes
Old 12-17-2012, 01:01 PM   #9256
Trader Rating: 85 (99%+)
Originally Posted by flame56mx View Post
mine is 11.84mm
Thanks, are you finding you have to run it pretty tight, how many threads show off the back side of the nut?
WideOpenThrottle RC is offline   Reply With Quote
Old 12-17-2012, 02:32 PM   #9257
Trader Rating: 520 (100%+)
Not really tight, there is a small black washer on each end of the spring. I would say 1-2mm of the shaft is exposed when tightened in the "right spot" area. Are you running the Durango slipper plates? They are gold in color, or are your plates more of a silver?
flame56mx is offline   Reply With Quote
Old 12-17-2012, 03:40 PM   #9258
They appear gold in color to me, I to have the washers on each end of the spring but for some reason it's not grabbing, kind of at a loss on this issue.
Old 12-17-2012, 03:59 PM   #9259
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Anyone??
You need a new Layshaft washer. I had the same issue and was the washer. They have a new one that is more durable but is on back order at amain.
http://www.amainhobbies.com/product_...ayshaft-Spacer
nolimit208 is offline   Reply With Quote
Old 12-17-2012, 05:12 PM   #9260
Trader Rating: 29 (100%+)
Tower has them in stock.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCMXK&P=7
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 12-17-2012, 06:19 PM   #9261
This one I have is brand new , was something wrong with these from the factory? So after looking at the exploded view in the manual is the supplied layshaft spacer to short not allowing it to hold the inside slipper disc out far enough so as you tighten it doesn't create tension?
Old 12-17-2012, 06:22 PM   #9262
Tunatsol's Avatar
some of the spacers were a bit long you could sand it down a bit.
Josh Youngs
Team Durango: DNX8, Dex8, 408, 210, 410v3,
Sponsored By: Dialed Hobbies
Tunatsol is offline   Reply With Quote
Old 12-17-2012, 06:27 PM   #9263
The Czechexican's Avatar
http://www.facebook.com/john.krizan....type=1&theater
:DEX210:
:DEX410V3:
MARCCA Carpet Racer.
"I Huff SXT 3.0"
The Czechexican is offline   Reply With Quote
Old 12-17-2012, 06:29 PM   #9264
Originally Posted by The Czechexican View Post
Oh yeah!
:DEX210:
:DEX410V3:
"I Huff SXT 3.0"
Old 12-17-2012, 07:03 PM   #9265
Well I just ordered a couple, gonna pull everything apart while I wait for them to arrive. Really like the design concept of the buggy but if everything else looks fine and this doesn't solve the problem this baby is going down the road.
Old 12-17-2012, 07:52 PM   #9266
Dont give up yet, it seems you have had more issues with your kit than I have ever seen..It is a very different design, and it takes a while to adjust to the differences from other cars, once you figure it out, it will be worth it IMO..
Old 12-17-2012, 07:56 PM   #9267
Trader Rating: 31 (100%+)
Take your slipper apart and wipe the plates down with motor spray and then put 2 new ae pads in and put it back together and try it again with the method I told u where u bench test it and try to get the front wheels off the table a little. It will just rule out that as an issue. I once had a bad set of pads and they coated my plates and caused my next set to slip.
If that doesn't work, then try the washer others were suggesting.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 12-17-2012, 07:58 PM   #9268
zipperfoot's Avatar
Trader Rating: 16 (100%+)
What brand of springs are you guys running? I kind of went overboard and picked up the complete Durango spring set and the Avid set as well. Not to mention several sets of Losi springs. Not sure where to begin. The Avids are ok but seem to be very "active". Losis have been pretty good, but i have no experience with the factory springs.
If slow is fast, how come I'm still slow?
zipperfoot is online now   Reply With Quote
Old 12-18-2012, 07:51 AM   #9269
Heavy B's Avatar
Trader Rating: 18 (100%+)
check your slipper plates and make sure they go inside the spur without slipper pads. I've heard a lot of problems with the Avid Triad slipper plates being slightly too big and not making proper contact with the pads. Haven't heard of this issues with Durango, but may be the aftermarket spur. I have nearly 4mm of threads showing on my top shaft, but the traction was really up friday night, usually not that tight.
Brian Bernt
2013 9th Annual HobbyPLEX Enduro Open Class Co-Champion
2011 ROAR Region 8 Mod 2wd SCT Champion
2010 & 2007 Summer Series at the Plex Modified 2wd Buggy Champion
2009 Summer Series at the Plex Modified 2wd Stadium Truck Champion
Heavy B is offline   Reply With Quote
Old 12-18-2012, 08:21 AM   #9270
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
Avid Yellow and Yellow on large outdoor medium traction track. I also run the DIMEC+8 and a Shorty.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Dopkal
