Like Tree43Likes
Old 12-14-2012, 10:07 PM   #9211
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Azagar View Post
They are an upgrade, the stock shafts are in fact too long. The shock body doesn't even have enough uptravel for the shorter 52mm shafts which is why I run two of those shock stoppers for the rear.
I noticed when I originally built my kit that the pistons stuck out of the top of the shock body a little bit, and now with the ti shafts they are just below the top of the shock body.
The instructions don't call for any limiters.
I installed them back on my car with the shorter shaft and noticed even with the shorter shaft I am getting full travel on the arms. So it appears the stock shafts were in fact too long.
zipperfoot is offline   Reply With Quote
Old 12-14-2012, 10:11 PM   #9212
zipperfoot's Avatar
Originally Posted by symmetricon View Post
So how is the quality of the Durango gear diff? Reason I ask I that I destroyed my associates gear diff tonight.
I have never heard of or read of anyone destroying a Durango gear diff, so they must be pretty durable. As a consolation, I am still running the original ball diff that came with the kit. I built the buggy several months ago, and it's still buttery smooth.
Old 12-15-2012, 06:39 AM   #9213
tedstryker's Avatar
Trader Rating: 75 (100%+)
I've been running gear diff.....with no problems...durango's gear diff is light years ahead of A.E.
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
tedstryker is offline   Reply With Quote
Old 12-15-2012, 07:04 AM   #9214
symmetricon's Avatar
Trader Rating: 27 (100%+)
I hope so. Lol. For some reason the after switching to a 7.5T motor my diffs don't seem to like it. The spider gears are wearing out and skipping. I tried to shim the inside of the diff tighter and the is not much extra room under the sun gears to shim it. I was only able to add .1 mm more and that only lasted a couple pack.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 12-15-2012, 08:09 AM   #9215
carlosm's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Cspurlock View Post
you can start with 32/72
download the manual from the durango site, the printed version has mistakes in it.
http://www.petitrc.com/setup/durango...ngoDEX210.html
has all types of build tips & setups.
Cspurlock: Thanks for the link, lots of info on the site!
The rest of you whining about me asking "the same" question sorry for any discomfort I may have caused.
Carlos Macias
Durango - DNX408, DESC410, DEX210
LutzRC.com - AnswerRC - Kal-Gard - Acendancy Racing - PT RC Silicone's
BuckarooGear.com
carlosm is offline   Reply With Quote
Old 12-15-2012, 07:30 PM   #9216
C-MAC's Avatar
Mine broke, dimec20, at the rear where the RR toe block bolts on. No hard crashes either like you mentioned. Besides that I one issue I was really liking the +8. Waiting for a new chassis to arrive and will give it one more chance before I go back to standard aluminum. I have a feeling this will be an area that no matter what will always break. All other buggies with plastic chassis have t-plates in this area to prevent this from happening or at least circumvent it when it does happen, just no way around it.
good luck man. i have a new dimec20 chassis just sitting. dont have the heart to try it again. i only get one play day a week! lol going to wait for durango or some aftermarket company to release a either updated verison or a metal chassis. hope it works out for ya. keep us posted!
C-MAC is offline   Reply With Quote
Old 12-15-2012, 07:37 PM   #9217
C-MAC's Avatar
Originally Posted by ehartman_49348 View Post
For those that had the DIMEC or DIMEC20 chassis break where either the RF or RR hinge pin blocks bolt in, did you use button head screws like outlined in the installation instructions? (http://www.team-durango.com/blog/201...on-the-dex210/)
yes i used the button head screws.
Old 12-15-2012, 09:52 PM   #9218
csracing's Avatar
Trader Rating: 22 (100%+)
Updated setup sheet. Easy to drive and pretty forgiving.
http://www.petitrc.com/setup/durango...de20121214.pdf
csracing is offline   Reply With Quote
Old 12-15-2012, 10:45 PM   #9219
zipperfoot's Avatar
Anybody tried 1.6x2 or 1.7x2 pistons yet? Seems to be catching on with the 22 and b4.1 big bore crowd.
Old 12-16-2012, 06:53 AM   #9220
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 12-16-2012, 09:41 AM   #9221
Ya I run 1.6x2 hole all around with losi oil 30/27.5 and losi green front spring and yellow rr spring
edlaret is offline   Reply With Quote
Old 12-16-2012, 10:31 AM   #9222
8ight-e's Avatar
Trader Rating: 58 (100%+)
1.2 6-hole front, 1.3 6-hole on rear is the best combo Ive found.. just tune your oil to your liking.. im at 45 & 35
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 12-16-2012, 10:39 AM   #9223
majorsmx521's Avatar
Trader Rating: 44 (100%+)
Default dimec t plate?
looking at the rear of the 210 chassis thinking, a quick fix would be to use
the stock alum chassis and cut it like a t plate
then bolt it over the dimec? its 2.5mm thick a little down fall?
but should stop the failures?
pros /cons?
521DESIGNS PAINT
R.I.P TQ Speedway Boise
majorsmx521 is offline   Reply With Quote
Old 12-16-2012, 11:14 AM   #9224
morris's Avatar
Trader Rating: 40 (100%+)
i drilled out some stock durango pistons..1.6x2 and used them front and back with losi 25 in the back and losi 27.5 in the front...
it made my car very lazy and was really hard to drive fast.
so i swithced out to using the stock 6 hole pistons with all 6 holes drilled out to 54..running losi 35 in the back and losi 37.5 in the front..car feels super responsive with this piston/oil setup...maybe a little to responsive...
its like drving a tc on dirt....going to try a different piston setup soon and if i like it i will post on here again and let yall know what i think.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-16-2012, 11:23 AM   #9225
Trader Rating: 18 (100%+)
pros /cons?
If you bevel the leading edge and use screws that are just a tad bit longer I don't see why it wouldn't work. Biggest downside is I've heard some people complain of skid plates making jumping inconsistent because sometimes it will catch the face of the jump and on landings.
Awesomatix A800XA - Xray XB2 2018
iTz Nicholas72 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 11-18-2017 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
