Like Tree43Likes
Old 12-11-2012, 05:46 PM   #9151
zanernator's Avatar
Hay guys,
i am looking at buying the 210 what are some parts that i should look at buying when i order the car besides the normal wear parts and another diff?
Thanks, Zane
Zane Courtway
Airtronics / Orion
Tacoma R/C Raceway, Bremerton R/C Raceway
zanernator is offline   Reply With Quote
Old 12-11-2012, 06:03 PM   #9152
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by zanernator View Post
Hay guys,
Thanks, Zane
I've been running one for about 1.5 mos now no broken parts.. I did pop 1 ball when I got into some pipe. I've seen a few people break front hubs.. thats about it.
Upgrades from the get go.. exotek alum bulk, exotek rear hex's, exotek front chassis weight Thats about it Just posted my setup sheet a bit back, it's dialed on a med bite clay track.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 12-11-2012, 06:40 PM   #9153
Trader Rating: 86 (99%+)
Guys, think I'm experiencing the dreaded c clip issue. Just completed my build and was running the buggy around on the carpet with very light throttle and with the diff feeling snug and the slipper tightened down it still unloads for a while before taking off under power, off the bench seems fine but under load it slips. When I assembled it I forgot to grab snap ring pliers from work so just used the tools that I had which bent the snap ring a bit, I straightened it out and installed it but wondering if thats the culprit. Where is your guys slipper nut in relation to the threads on the shaft after a rebuild? Thanks
WideOpenThrottle RC is offline   Reply With Quote
Old 12-11-2012, 07:13 PM   #9154
The Czechexican's Avatar
Originally Posted by Walkman View Post
I run MM4 on carpet and my stating point is this setup. Dialed!
http://www.petitrc.com/setup/durango...und2012042022/
What would be the shock oil conversion in this setup if using let say Losi shock oil?
:DEX210:
:DEX410V3:
MARCCA Carpet Racer.
"I Huff SXT 3.0"
The Czechexican is offline   Reply With Quote
Old 12-11-2012, 07:20 PM   #9155
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
Originally Posted by Serzoni View Post
The sale that Hobbico/Great Planes was having is over, so the price is back to normal. I got mine last night w/free tshirt, imperial front axles, and DEX410 rear wheel cones for $201 shipped after using a $50 off coupon code.
Just in time..
That being said, what's a recommended starting setup for a dusty, bumpy, blown out 1/8th scale track? I looked at setups on the Durango site, but they don't really give a description of the track conditions unless you download and open each setup sheet.
Here is a setup I used on a large 1/8 scale track back in Aug or when ever, I think its all correct. I would probably start with a little more ride height though 22 fr/rr. The car was on rails compared to everyone else but ballcups kept popping off after a couple of laps in, in a haggard rhythm section, so I would also recommend updating those asap to some other cheapo's, I did the losi's.
http://www.petitrc.com/setup/durango...lCity20120702/
nolimit208 is offline   Reply With Quote
Old 12-11-2012, 07:28 PM   #9156
Trader Rating: 29 (100%+)
I have 27.5 Losi in the rear and 50 AE in the front.
This should get you close.
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 12-11-2012, 07:31 PM   #9157
Trader Rating: 73 (100%+)
Hers is a conversion chart from durango that may help you out.
http://www.team-durango.com/pdf/setu...on%20Chart.pdf
Edit - Beaten by Walkman as I found my link - LOL
mister_g is offline   Reply With Quote
Old 12-11-2012, 07:51 PM   #9158
Awsome! This is what I been looking for. Thanks Walkman and Mister G
:DEX210:
:DEX410V3:
"I Huff SXT 3.0"
Old 12-11-2012, 07:59 PM   #9159
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Check this one out.
http://www.petitrc.com/setup/durango...eline20120603/
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 12-11-2012, 08:01 PM   #9160
M3Armand's Avatar
+1 I'm about to install the gear diff since I'm tired of readjusting...
Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
M3Armand is offline   Reply With Quote
Old 12-11-2012, 08:12 PM   #9161
Wow. 27.5 in the rear? Any weight in the front or rear? Does the rear end roll?
I have been trying to take the roll out of the rear. It rolls then spins. Ive been trying to calm it down. Does the hevy weight oil up front help. I have 40 up front with the light brown springs and 1.3 4 hole pistons and I have 21 grams up front and I cant get it down to ride height. I to have been using this set up with some tweeks. I been trying to get high roll center in the rear. My links are all the way out and shocks lay down all the way. Tried putting 4 mm under the inner ball studs too.
:DEX210:
:DEX410V3:
"I Huff SXT 3.0"
Old 12-11-2012, 08:26 PM   #9162
I have my ride height at 19mm front and rear, and 7grams next to reciever and 7 grams next to ESC. I'm running Panther slicks with Proline closed cell from foams in the fronts, and Panther 1/8 scale closed cells cut down in the rear, and battery to the back. I will try to post a complete setup sheet tomorrow.
Old 12-11-2012, 08:39 PM   #9163
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
If you are putting shims under the inner camber links and raising them on the rear then you are actually getting a lower roll center.
But I believe you are going in the right direction. Just the wrong terminology.
Fishhook
ewashburnaf is offline   Reply With Quote
Old 12-12-2012, 12:25 AM   #9164
Oasis's Avatar
Trader Rating: 36 (100%+)
Hay guys,
Thanks, Zane
It's pretty sturdy stock, I would get the dime 20 chassis (+8), ti shock shafts, a few sets of springs, I'm running 14 grams of weight behind the servo (stick on) and my buggy is dialed..me not so much but the Durango is freakin awesome! Best thing I ever did was putting the +8 chassis on it..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 12-12-2012, 07:07 AM   #9165
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Thanks for posting set up sheets guys. This really helps, but man the set ups are all over the place. Just goes to show how adjustable this buggy is. My set up is nowhere near the recent posts.
Question. The front steering rack has three sets of holes. I have the ball studs mounted in the center holes. What does mounting them forward or back do to the steering?
The reason i ask is because on my radio i am running a bit of negative expo in the steering to calm things down a bit, and wondered if i could do the same thing using another steering rack position.
zipperfoot is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16581 Today 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
