Like Tree43Likes
Old 10-21-2011, 05:01 AM   #901
Matt Howard's Avatar
Originally Posted by twelvegauge View Post
That would partly explain the wheelies . I'll have to change it to 3 gear tonight.
Is there a spring rate chart any where
http://www.team-durango.com/blog/201...spring-charts/
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-21-2011, 06:21 AM   #902
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Can any check to see if a CF lipo strap from a B4 would work on the 210 if you have one? More importunely, check to see if the armswill reach the screw holes and the TD thumbscrews will tighten down.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 10-21-2011, 06:28 AM   #903
Trader Rating: 25 (100%+)
Any problems with the diff?
Mine was missing a bearing for the inner part and I used one from my TC5. It seemed to work at first then it was like I had no diff at all. I removed the one Bering so the rings would rub the diff balls.
I think the male part of the one out drive may be to long .
Did you only have one bearing in diff? If so that could be part of the problem. This diff should be one of the best if built right.
I am running the 3 gear tranny and my car has a little push to it. I have only got to try 1 set of tires so far. Ill have more wheels tonight to mount tires on so I will have to see if that helps. I only got to put 4 batteries through it last night but it was a lot of fun
KainK is offline   Reply With Quote
Old 10-21-2011, 06:53 AM   #904
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Originally Posted by Cpt.America View Post
Yes you do... you can NOT get the circlip out of the diff housing without them. Getting it in... maybe... Definite a "must have" tool.
Well yea to get it out you HAVE to have it. I was talking about just putting it together
Car looks great Cpt America! Same setup I have going on.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 10-21-2011, 06:56 AM   #905
My front wheels are. I cant run the inserts to shorten the wheel base without them rubbing the hing pin screws when I turn.
Any setups yet?
Mine has a real bad push but it's getting better. I only had a couple of hrs on the track to make some adjustments.
Wow, really? You must have the wrong tires or something? The first thing I noticed with this car is how much steering it had without breaking the rear end loose.
On my B4, I always ran a 81t spur with a 23t pinion with an 8.5 motor. Now I have a 7.5, so do you think with the 23t pinion, the 87t spur will be a good match?
Dylan Gerard
Old 10-21-2011, 06:57 AM   #906
TAMAK's Avatar
Trader Rating: 28 (100%+)
Just stayed up all night building the roller. I was missing all of the screws that mount the rear brace to chassis. Oh well I have extras. Also some very tight tolerances: Idler shaft, front steering brace block, and even the shock shafts where the spacer goes on before the piston. Nothing a little sanding, polish and time didn't fix. I did strip out the heads on a few cheap screws to. And Yes, I do have EDS drivers.
A great Diff, had 0 problems assembling that. The car is so smooth, I cant wait to hear only the tiny thumps of the tires on the clay. . I should have it ready for Leisure Hours this Saturday!! Just missing a transponder. Oh well.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 10-21-2011, 07:01 AM   #907
he was running the 4 gear transmission, hence the push
RCTech #361
Old 10-21-2011, 07:37 AM   #908
TAMAK's Avatar
And Front Rebars
Old 10-21-2011, 08:31 AM   #909
Ohh Gotchya. Those of you who are not using TD shock oil, what weight oil are you guys going with? losi, ae
Dylan Gerard
Old 10-21-2011, 08:42 AM   #910
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
I started with 35 front and back. The front feels good, but the rear feels over damped. I'm certain I will be at 35/27.5 by the end of the day tomorrow at the track.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-21-2011, 08:47 AM   #911
TAMAK's Avatar
I did 30 / 27.5 Associated. We will see... Did you use 6 hole pistons?
Old 10-21-2011, 08:54 AM   #912
Super Moderator
I used the 1.3s and 1.2s right out of the book. I forget which went in front and which went in the rear... and not sure which has the larger holes. I assume the 1.3 are larger, but im not sure... Either way, the smaller holes should be in back, with lighter oil than the front. But all of my previous thinking might go out the window with the RM4 setup.
I have ALL DAY saturday to test, should be fun.
- RCSpecialties -
Old 10-21-2011, 09:00 AM   #913
TAMAK's Avatar
Same here buddy!! And we report back on Sunday
Old 10-21-2011, 09:04 AM   #914
I have 1.3's front, 1.2's back. 35wt front 30wt rear. 30wt rear felt fine the other night at the track but probably will try 27.5 this weekend.
Dylan Gerard
Old 10-21-2011, 09:06 AM   #915
Super Moderator
But with the extra rear downforce with my RM4 setup, I might need/want to run a stiffer rear end with more anti-squat to keep some on-power steering... Should also make the car land like a champ.
- RCSpecialties -
St Ives RC Club B4Bandit Australian Racing 16581 Yesterday 03:23 PM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
