Like Tree23Likes
Old 12-09-2012, 11:02 AM   #9106
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by majorsmx521 View Post
Hey guys
what are the options for rear camber plates? tresrey and???
thanks
As you can see in the pic I posted yesterday, I have a rear camber piece made by rcshox.com it does its job perfectly.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 12-09-2012, 11:05 AM   #9107
Originally Posted by M3Man03 View Post
Why not move the battery up slightly instead of adding weight?
Sorry, I should have multi quoted. Anyways, like I said, my local track is very low traction and the car just feels better like this. I am still trying to get is dialed all the way in, and am very close, just need to get the front dampening correct.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 12-09-2012, 11:10 AM   #9108
majorsmx521's Avatar
Trader Rating: 44 (100%+)
thanks!! it looks very trick
521DESIGNS PAINT
R.I.P TQ Speedway Boise
majorsmx521 is offline   Reply With Quote
Old 12-09-2012, 11:20 AM   #9109
Woulvesbaine's Avatar
Default Defective part
So far, I really like this car despite how much work it needs out of the box. In getting the car dialed (by Cspurlock!), we noticed that my near brand new car has a defective driveshaft (310253).
The pin that hooks up to the outdrive is really loose. I will try to threadlock this, but at best it's only a temp solution.
Anyone have any luck with replacement of defective parts from TD? Any suggestions on who to contact?
If it's not too much of a PITA, I'll contact them as, in addition to buying a new dimec chassis, and body, a gear cover that fits over a stock pinion, AND ballcups, I'll already be investing $80+ dollars into this buggy and would prefer to avoid having to shell out another $20 for a pair of 310253 driveshafts.
Any assistance greatly appreciated.
|| Team C TM4 || OCRC || SCVRC || Facebook: Squid Ink Paint
Woulvesbaine is offline   Reply With Quote
Old 12-09-2012, 11:30 AM   #9110
Matt Howard's Avatar
you mean the pin that goes into the hex on the axle? those are a loose fit, put a drop of threadlock on them before you slide them in and they'll stay in place.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-09-2012, 11:37 AM   #9111
No, sorry, I mean the pin that fits into driveshaft and connects into the outdrive (where it gets powered by the gearbox).
With the amount of weight and force, I'm not sure that threadlock will hold forever there. Guess I'll find out!
This is the driveshaft with the pin:
http://www.ebay.com/itm/Team-Durango...-/290759465929
I'm going to buy some read threadlock, so hopefully that will fix it.
Old 12-09-2012, 11:41 AM   #9112
first I've heard of that problem, do you have a pic?
RCTech #361
Old 12-09-2012, 11:52 AM   #9113
Here is a pic. Hopefully, it shows the issue. I've not seen this before either with any car (and I've owned dozens).
Old 12-09-2012, 11:55 AM   #9114
This is defiantly an isolated incident. I'm sure TD would replace it for you.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 12-09-2012, 11:55 AM   #9115
wow, never saw that problem before. I'd definetly be calling Durango to get a replacement
RCTech #361
Old 12-09-2012, 11:56 AM   #9116
Here is a larger pic. Struggling a bit with google plus instant upload. I need to find a better solution than that as well. hehe.
Old 12-09-2012, 12:04 PM   #9117
217-398-3630 is the number for Hobbico. I'll give them a try on Monday (I'm sure they're closed on Sunday). If anyone sees reads this and has an email I should use, please let me know.
It's probably more efficient to send them a pic, so they know what I'm talking about as well.
Old 12-09-2012, 12:05 PM   #9118
Trader Rating: 112 (100%+)
I run on a very low traction track, lots of loam, and between the 3 gear and the 4 gear the increase in on power traction is very helpful. Its funny, the tires of choice are the old school step pins or ifmar studs.
Thank you for the info. The track that I race on is a medium to high bite dirt track(would say its close to a clay track). The track is not 100% clay. I am also only running blinky/17.5. I was wondering if this would help in a stock class or be a bad choice. Bar codes are the tire of choice too.
Dave
Sponsors: YuK-Foo Tire Prep
dragracer72nova is offline   Reply With Quote
Old 12-09-2012, 12:13 PM   #9119
Dave
I would hate to give bad advice on the matter since our respective tracks are completely different, but if you have time to play around and try it, its worth a shot. What is your setup anyways? Maybe the prevailing minds here can point you in the right direction.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 12-09-2012, 01:46 PM   #9120
well 1st race in with the buggy. i have the rtr version. i did nothing to it but change rear tires to suburbs and a better servo and radio.
how the car felt: it pushed really bad and was sometimes loose. changed shock positions and it seemed to help but the track was drier and that brought up traction issues.
also and this is a big one for me, once in awhile landing off of jumps the car would do a complete 180. i found that odd.
any advice would be great , thanks Geo
twisted is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16563 Today 04:32 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
