Like Tree36Likes
Old 12-08-2012, 04:08 PM   #9076
Default Jconcepts body
Will the body fit 8mm chassis and the aluminum chassis?? Also how about the mid motor and rear motor configurations ??
dolfns1 is offline   Reply With Quote
Old 12-08-2012, 05:03 PM   #9077
zipperfoot's Avatar
Trader Rating: 16 (100%+)
I feel I really have my standard chassis buggy dialed in at the moment. I practiced last night at SRS here is AZ and felt I turned some respectable and consistant lap times. The buggy felt great, and very stable.
I am going to stick to the old "if it ain't broke don't fix it" mantra, but I can't help but wonder if the dime +8 would be even better? Or just different...
zipperfoot is offline   Reply With Quote
Old 12-08-2012, 05:47 PM   #9078
ekt
ekt's Avatar
Originally Posted by Ssilverfz1 View Post
Does anybody use one? If so which is the best?
I remember a while back people saying the losi 22 ones are a direct replacement.
ekt is offline   Reply With Quote
Old 12-08-2012, 05:49 PM   #9079
Trader Rating: 86 (99%+)
Quick question for you guys, I'm new to the 210 but not new to building kits. I followed the diff build video to a T and have the diff tight enough so that I can just barely turn the outdrives by hand. Strange thing is I can hold the gear and wiggle the outdrives back and forth like something isn't seated right against the diff faces. Am I missing something here or when it's installed and ran in will it tighten up?
WideOpenThrottle RC is offline   Reply With Quote
Old 12-08-2012, 06:15 PM   #9080
symmetricon's Avatar
Trader Rating: 27 (100%+)
I switched to the dimec 20 and it is SO much better. Do yourself a favor and try it out.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 12-08-2012, 06:26 PM   #9081
Atomicsickness's Avatar
Trader Rating: 26 (100%+)
That is completely normal.
☆http://www.loganvillerc.com☆
☆http://hotshotrc.com/☆
Atomicsickness is offline   Reply With Quote
Old 12-08-2012, 06:58 PM   #9082
Whew, thanks...
Old 12-08-2012, 07:15 PM   #9083
P6
its hard to get that answer ive asked and i researched the +8 newer design is 7" wide the old style bodys have two parts i noticed its not as wide on the sides around 5 1/2" and the curve is rounded outwards to so it would take some heat or modified i think to make it fit and even then im not sure where the body will line up if it would be all the way forward exposing the space from the body to rear shock tower or if it would go to the back and the cab would be further back , thats why i dont own dimec yet im planing to buy a body and the chassis for $50 then paint is the only other cost
P6 is offline   Reply With Quote
Old 12-08-2012, 07:30 PM   #9084
Another quick question, page 25 in the manual shows part# 320128-6 which are spacers. Do these go on top of the front rear suspension holder, without them the tranny sits down flush with the chassis, with these spacers under there it's up in the air and everything is in a bit of bind screwing together. I remember guys raising the tranny on the 22 is that what this is for or is it a mistake in the manual or am I not reading it right???
Old 12-08-2012, 07:43 PM   #9085
Trader Rating: 29 (100%+)
Manual is wrong. Download the manual from the Durango website http://www.team-durango.com/pdf/manu...n%20Manual.pdf
The part should be 310257-4
DEX210 | DESC210 | TC6.1WC | B5m
Eclipse Hobbies & Raceway Bradley, IL | Sticky Kicks |
Bodies by P.C.R. Problem Child Racing|
Walkman is offline   Reply With Quote
Old 12-08-2012, 08:05 PM   #9086
Much better...
Old 12-08-2012, 09:13 PM   #9087
zipperfoot's Avatar
When you switched did you have to change your set up or battery placement at all? Are you runing the full size or stick pack? Thanks for the help.
Old 12-08-2012, 10:07 PM   #9088
I had to lighten the shock oils a bit and I also added the exotech 20gram brass piece for the front. I am running a shorty pack with the battery positioned at the front of the rearmost battery position.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 12-09-2012, 04:55 AM   #9089
onekiwi's Avatar
Originally Posted by jhhack View Post
Seriously... with the sale and the december super saver coupon, 189.98 shipped for the dex210 kit. Cant beat that. Just ordered.
How do you get those discounts?
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 12-09-2012, 06:33 AM   #9090
M3Man03's Avatar
Why not move the battery up slightly instead of adding weight?
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
