Like Tree24Likes
Old 10-20-2011, 07:05 PM   #886
x7tristan's Avatar
Originally Posted by Atomicsickness View Post
Ebay. Searched for snap ring pliers.
what are the snap ring pliers for?
TJ
DURANGO DESC410R
x7tristan is offline   Reply With Quote
Old 10-20-2011, 07:08 PM   #887
trx-1racer's Avatar
Originally Posted by teeforb View Post
what's the verdict on the rear gear setup? 3 or 4? i may start my build tonight!
3 gear rear for the US fast guys so far.
http://www.team-durango.com/pdf/setu...16_10_2011.pdf
Fischer has it right here.
www.shortcoursehobbies.com
T-RCE Slash 4x4 - Kyosho SC-R - TLR 22
Think you're fast? Try racing in Arizona, it's like going to the Nats every weekend...
trx-1racer is offline   Reply With Quote
Old 10-20-2011, 07:12 PM   #888
rcman182006's Avatar
Send a message via Yahoo to rcman182006
part of the diff build (some of us scoped the manual on the site)
-=-Charles Kilbarger-=-
Serpent SRX2 MM - D4 17.5 - Hobbywing Justock
AE RC10 Team Car - RevTech 17.5 - Hobbywing Justock
#NoChuck2015
rcman182006 is offline   Reply With Quote
Old 10-20-2011, 08:29 PM   #889
Are they for the Clip ring? Do you have to use them??
JayBuc is offline   Reply With Quote
Old 10-20-2011, 08:55 PM   #890
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
You don't have to use the snap ring pliers.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 10-20-2011, 09:28 PM   #891
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Yes you do... you can NOT get the circlip out of the diff housing without them. Getting it in... maybe... Definite a "must have" tool.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 10-20-2011, 09:31 PM   #892
Super Moderator
Anybody elses rear wheels REALLY out-of-round?... my god, mine are like eggs.
- RCSpecialties -
Old 10-20-2011, 10:46 PM   #893
Super Moderator
Kit - check
Electronics - check
glued up wheels/tires - check
All that I have left now, is painting up a shell. A couple other small tid-bits about the car:
1. The largest pinion you can fit on the car with the stock 87 spur, is a 25, which means you will be slightly under geared even with a 9.5 turn motor (what I always run). It truly is a bizarre choice for the one and only spur gear.
2. Lunsford fatty motor screws with the fatty washers don't fit under the pinion/spur dust cover. They even rub a tiny bit with normal small flat washers.
That's it for now... my first run will be Saturday.
- RCSpecialties -
Old 10-20-2011, 11:09 PM   #894
Super Moderator
Sorry I keep posting guys... just have more stuff to add, and im still awake. Here are pictures of my build.
- RCSpecialties -
Old 10-20-2011, 11:25 PM   #895
arn671's Avatar
Trader Rating: 14 (100%+)
Default DEX 210
Cpt.America, I'd be interested in hearing your thoughts about the 210 compared to the RB5 SP2. All the features of the 210 are tempting me to pick one up, especially since you race in the same general area. Looking forward to your review/thoughts
arn671 is offline   Reply With Quote
Old 10-21-2011, 02:48 AM   #896
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
My front wheels are. I cant run the inserts to shorten the wheel base without them rubbing the hing pin screws when I turn.
Any setups yet?
Mine has a real bad push but it's getting better. I only had a couple of hrs on the track to make some adjustments.
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
biscayne348@gmail.com or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 10-21-2011, 02:53 AM   #897
Any problems with the diff?
Mine was missing a bearing for the inner part and I used one from my TC5. It seemed to work at first then it was like I had no diff at all. I removed the one Bering so the rings would rub the diff balls.
I think the male part of the one out drive may be to long .
Old 10-21-2011, 02:55 AM   #898
Old 10-21-2011, 03:52 AM   #899
Matt Howard's Avatar
Any setups yet?
looking at your build, you built it using the 4 gear transmission, right? That would explain your real bad push as the 4 gear setup yields more rear traction.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-21-2011, 03:55 AM   #900
That would partly explain the wheelies . I'll have to change it to 3 gear tonight.
Is there a spring rate chart any where
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
