Like Tree24Likes
Old 11-24-2012, 05:31 PM   #8881
M3Man03's Avatar
Originally Posted by OU812_77 View Post
With the stock ball studs and cups and turnbuckles
1st put one of the turnbuckles in a drill
2nd using a body reamer slightly ream the thread side of the ball cups
3rd on half of the cups thread in and out a few times leave it on the turnbuckle until it cools
4th flip the turnbuckle over and repeat step 3 on the rest of the cups
5th put a small amount of diff lube on the turnbuckle and thread the cups on
With this method you are cutting the threads and setting them and luberucating them this allows you to easily adjust them. The less you pop them off and Easter they move the better they preform. I use this method on mine and it works and I crash a lot.
Hope this helps
A MUCH MUCH better solution than just threading the turnbuckle in, is get a M3x0.5 bottoming TAP and cut the threads in.
No matter what with a turnbuckle, you're mashing plastic out of the way, not cutting it. When you pull the turnbuckle out, there's little to no plastic.
When you use a TAP, there's a lot of cut plastic that comes out.
The problem with these ballcups is that the type of plastic used, tries to shrink back to original size after a while, which causes a locked tight grip on the turnbuckle. The only solution is to cut away some of the plastic.
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 11-24-2012, 05:33 PM   #8882
Trader Rating: 31 (100%+)
Originally Posted by C-MAC View Post
sup guys, having a binding problem when i tighten the wheels nuts on the rear tires. the left is passable i guess but the right rear get extremely tight. i heard about a shimm trick. have any of you had this problem and if so how did you fix it? appreicate any info. thx
It happens when u overtighten the wheel nuts. That is why a lot of people buy the alum wheel hexes, it eliminates the problem. Try to back off the nut a little and see if it loosens up, if not, it might be a bearing.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 11-24-2012, 06:13 PM   #8883
Default Ball cup
Has anyone running MM tried aftermarket ball cups? It looks like the left rear won't take a straight ball cup so I was wondering if anyone has come up with an alternative to the stock ones?
MBX6-ECO, B5m
Old 11-24-2012, 06:24 PM   #8884
C-MAC's Avatar
i have the aluminum hexes and still to tight. bearings are new. its really got me stumped. tried adding shimms here and there but that doesnt seem to help. could be a defect in the hub but ive read others having the same problem. appreciate the info though. thank you.
C-MAC is offline   Reply With Quote
Old 11-24-2012, 06:31 PM   #8885
Trader Rating: 38 (100%+)
Not sure if this has ever been posted by anyone else, but I know a lot of people have the same trouble. Take off rear wheel, pin falls out right? I just put a tiny dot of super glue on the pin before sliding it into the driveshaft, problem solved!! And if you need to slide the pin out it just takes a tap with a screwdriver to get it moving....
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 11-24-2012, 07:07 PM   #8886
Matt Howard's Avatar
When I ran the stock hexes I put a drop of locktite on the pin before I installed it. Less permanent than superglue. I now run the Tresrey clamping hexes and have never looked back
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-24-2012, 07:48 PM   #8887
Trader Rating: 74 (100%+)
+20000 on the hexes.. I love my Tresrey parts!
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 11-24-2012, 08:44 PM   #8888
Trader Rating: 19 (100%+)
You need some 5mm ID shims to slide onto the axle. Remove the outer bearing, slide the shims on (I needed .4mm of shim in the aluminum hubs, .3mm in the Tresrey hubs), and reinstall the outer bearing. The axle is supposed to meet the race of the outer bearing and act as a crush tube, but its a few tenths of a mm short. You may have to try a few different shim combos in there, but once you find the right amount you'll be able to lock the wheels down with zero bind and no fear of losing a wheel.
And the Tresrey hexes are super dialed- if you use them I place an additional .3mm shim between the outer bearing and the hex to keep the side load away from the drive pin.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 11-24-2012, 09:08 PM   #8889
C-MAC's Avatar
And the Tresrey hubs are super dialed- if you use them I place an additional .3mm shim between the outer bearing and the hex to keep the side load away from the drive pin.
i have the tresrey hubs i'll give this a shot. thank you!
Old 11-24-2012, 11:07 PM   #8890
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Hope this helps
This is a good method.... But should you have to go through all this trouble? No.
Im gonna say it. The ball cups suck. Plain and simple.
Drill em out, count to five, reverse thread them with a left handed screwdriver, wait for a full moon before adjusting them... Ridculous. I have never had to do this with any other kit.
Some have had problems, some have not. That alone tells me quality is inconsistant. Time for Durango to reformulate the plastic used for the cups.
I went to the jconcepts cups with tc6 studs. No issues since. No grease, no reaming, no taking off a ball stud instead of popping off a cup to make adjustments.
zipperfoot is offline   Reply With Quote
Old 11-25-2012, 05:21 AM   #8891
Trader Rating: 309 (100%+)
+1 I just went to RPM on 410 and 210 and be done with it.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 11-25-2012, 06:13 AM   #8892
Default New Dex 210 coming, part #s needed
I Have a Dex 210 arriving, want to have a back up plan for stock ball cup. Sounds like it could be a problem, can I just use stock ball stud and another ball cup (please include part numbers) ?. Shim for outer rear bearing, 5mm ID, what is the OD, or part# on shim kit I need. Every car has some small issues you have to correct, Do not like DNF's.
Hobby PRO-USA
Agama A8 / A8T / A8E
Team Strike / Sidewinder
Sirio ExTech
Pro Match Racing
Ramirez24 is offline   Reply With Quote
Old 11-25-2012, 06:14 AM   #8893
but, but, but, there's some people that never pop a turnbuckle, your just building them wrong
Sorry, I'm in the same boat. Now when I build a new Durango kit the first thing I do is research what size ballstuds/cups I need to order with it. I thought the new HD cups would be better but they're the same for me, come off way too easily no matter how you build them.
RCTech #361
Old 11-25-2012, 06:31 AM   #8894
When I bought this car, I was told by a guy that has been running one, to boil the ball cups so they don't pop off. It worked for me.
cooper126 is offline   Reply With Quote
Old 11-25-2012, 06:35 AM   #8895
symmetricon's Avatar
Trader Rating: 27 (100%+)
After 1 year of ballcup issues, I am shocked that there are still deniers. Get the lunsford kit or whatever and be done with it!
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
