Like Tree27Likes
Old 11-22-2012, 10:21 AM   #8836
Pvd brett's Avatar
Originally Posted by nolimit208 View Post
I did them also from the get go and still had issues, it really comes down to the driver, but once they pop off once they pretty much keep coming off. Atleast thats how it worked out with the 2 sets I had used before I switched them all out for a different brand.
the stock ones fit tight until you take a hard lick then you have to replace them. Im using the concepts cups with tc6 studs and they fit GREAT. If you still have trouble then check those out
Pvd brett is offline   Reply With Quote
Old 11-22-2012, 11:03 AM   #8837
Orion_2kTC's Avatar
Does anyone besides exotek make aftermarket aluminum parts? I'm getting a DEX210 in the future, but it would be neat to get some blue parts instead of the TD Gold.
Orion_2kTC is offline   Reply With Quote
Old 11-22-2012, 12:42 PM   #8838
symmetricon's Avatar
Trader Rating: 27 (100%+)
I have not seen any blue annodized aluminum, but there are other aftermarket options other than exotek (exotek is greath though).
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-22-2012, 02:08 PM   #8839
ekt
ekt's Avatar
Originally Posted by M3Man03 View Post
Where'd you see this?
They are listed on the TD site under option parts. http://www.team-durango.com/parts.ph...t=&scat=&show=
Just red or gold that I know of, Tresrey, Exotek and Revolution Design Racing
ekt is online now   Reply With Quote
Old 11-22-2012, 03:12 PM   #8840
DBL15's Avatar
well i installed the extra 8mm plastic chassis last night and to my eyes its longer then 8mm over the standard alum chassis ?
i am thinking more like 10mm to 11mm its more then 8mm for sure
looking forward to trying it tonight in a testing session
should be good to compair as my stock buggy runs the 8mm carbon chassis and now mod buggy will run the plastic extra 8mm chassis as advertised
really looking forward to running some laps with it
oh yeh what a difference in weight i had to change my pre load on the shocks by over 5mm to get the same ride height
everything fitted perfectly as well and the chassis seems well built for moulded plastic
C/O Coast2coastrc (www.coast2coastrc.com.au) SMC Lipo
Tekno Rc , Team Tekin , Panther-Rc , De Racing , Upgrade Rc , Team Triton rc , M2C clutches , Nitro X fuels
DBL15 is offline   Reply With Quote
Old 11-22-2012, 06:33 PM   #8841
C-MAC's Avatar
Default my dex
took her out for a few laps yesterday. felt pretty dialed with the new longer chassis. using a stock length body for now.
C-MAC is offline   Reply With Quote
Old 11-22-2012, 08:48 PM   #8842
zipperfoot's Avatar
Trader Rating: 16 (100%+)
I would like to try the +8 chassis but i have a freshly painted Finnisher body i just completed. Do you have to mod the body? If so where?
Also, your rear tires look like Calibers. I have found those are great tires for practice on a dry track. They last a long time. I have 10 packs on a set and they still have some tread left.
zipperfoot is offline   Reply With Quote
Old 11-22-2012, 09:23 PM   #8843
C-MAC's Avatar
no mods needed at all. i just had to cut the rear hole alittle. towards the rear of the car. once i did that it popped on with no problem. you will need to use body clips though. the velcro trick i dont think would be wise as the longer chassis is just a tick wider than the stock chassis. fas as the calibers go i couldnt agree with you more. they are great tires to practice and race with. when it calls for it i'll bust out some barcodes or bk bars.
Old 11-23-2012, 03:45 AM   #8844
DBL15's Avatar
Thumbs up
Well 200 laps later and that was a fun little test session.
Longer chassis makes it feel more planted for sure and I did beat my PB lap time by 0.3 of a second but I still need to make more changes I feel to shocks and springs for the lighter buggy now.
All in all was well worth the money for plastic chassis
Old 11-23-2012, 05:04 AM   #8845
t0ddy_44's Avatar
Hey Darren!!!! Where did you nab the plastic chassis from?? I trust the Goldy is still golden.. Be up in a few months!!!
t0ddy_44 is offline   Reply With Quote
Old 11-23-2012, 06:29 AM   #8846
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
of the +8mm chassis what would be the most universal one from dirt to carpet or for indoors carpet would it be better to just use the stock alloy chassis?
what springs are a must tohave in the parts box outside of the stock ones?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 11-23-2012, 06:36 AM   #8847
I would go with the dimec20 chassis, but on higher traction tracks, I actually prefer the aluminum chassis.( keep in mind my experience is with the +8 carbon chassis)
i also use losi springs since they are readily available where i live, and out of all the spring combo's i have tried, I use the losi 22 silver in the front and losi orange in the rear almost exclusivley.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-23-2012, 07:10 AM   #8848
Tech Legend
Cain's Avatar
Thanks for the info!
Old 11-23-2012, 07:57 AM   #8849
zipperfoot's Avatar
This is the kind of info I like to see. Thanks for the update.
Let me know what springs, pistons, and oil you end up going with. And post info on what kind of track you are testing on if you don't mind.
Old 11-23-2012, 08:08 AM   #8850
Trader Rating: 520 (100%+)
Well, I would like to update some info also. I have the std flex +8 chassis, and I installed the Dimec20 in my sons car. I drive on a clay med-med/hi bite track, and his is definitely better than mine. I figured with the lower temps in my area, that the softer chassis may be a better choice, but it makes my car lazy compared to his, the stiiffer chassis is much more consistent, at least IMO. The softer chassis will be good in low traction situations.
flame56mx is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
