Like Tree26Likes
Old 11-20-2012, 02:31 PM   #8821
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by M3Man03 View Post
Current pics of my DEX210 - the CF shock towers are mine - I made them. I got the Exotek front aluminum bits because I haven't found a way to make those yet.
Not gonna lie, that's a pretty hot looking car
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is online now   Reply With Quote
Old 11-20-2012, 04:24 PM   #8822
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Originally Posted by zylstra View Post
iu got my 8mm chassy on works awsome is anybody useing losi springs im running on a clay track high bite. need alittle more steering too. thanks.
I have stock durango rears and losi silvers up front. 30wt front/27.5 rear 4 hole 1.3's all the way around. 22mm ride height and car is dialed on medium/high grip dirt.
| AFLAC Designs - Custom Airbrushing, in a hurry! | Jakes RC Pro Am - Topeka's Indoor Offroad Track! |
sparkwraps is offline   Reply With Quote
Old 11-21-2012, 04:01 AM   #8823
ekt
ekt's Avatar
TD looks to be releasing some new bling parts in olive, black, red and gold.
Battery nuts, spacers, wing buttons, front bulkhead buttons and wheel hexes
ekt is offline   Reply With Quote
Old 11-21-2012, 06:14 PM   #8824
nolimit208's Avatar
Send a message via AIM to nolimit208 Send a message via MSN to nolimit208
How did you do the battery brace, where you filled in the lettering?
nolimit208 is offline   Reply With Quote
Old 11-21-2012, 06:31 PM   #8825
nolimit208's Avatar
What alternative o-rings can I use in the shocks since the TD ones are out of stock?
Old 11-21-2012, 11:43 PM   #8826
Azagar's Avatar
I would recommend these. Or if you want the same style as the stock ones then these will do.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 11-22-2012, 05:46 AM   #8827
tedstryker's Avatar
Trader Rating: 74 (100%+)
my many faces after my ball cups popped ...lastnight...
then fixed it with A.E. BALL STUDS ....AND RPM CUPS
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 11-22-2012, 05:59 AM   #8828
R/C Tech Charter Subscriber
Trader Rating: 30 (100%+)
The fancy kyosho X-rings will work but the o.d. is a loose fit to the shock body. I had one rear shock that sucked air really bad past the seals but after a heavy greasing of the seal package everything seems to seal up well. I used some Race Tech (motorcycle) seal grease with these seals since its thicker than green slime or losi grease and provided a better seal.
Lowrance is offline   Reply With Quote
Old 11-22-2012, 06:00 AM   #8829
i use iosi cups and studs never have one pop
zylstra is offline   Reply With Quote
Old 11-22-2012, 06:47 AM   #8830
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
I've ordered these through my lhs. Work great with no leaks.
OFNA 3.0mm Shock O-Ring Seals (8)
[OFN37070]
kwiksi is offline   Reply With Quote
Old 11-22-2012, 08:34 AM   #8831
M3Man03's Avatar
Where'd you see this?
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 11-22-2012, 08:34 AM   #8832
nolimit208's Avatar
Thanks for the many options appreciate it!
Old 11-22-2012, 08:35 AM   #8833
M3Man03's Avatar
Carefully filled it in with paint, let dry and wipe away the extra with paint remover.
Old 11-22-2012, 08:36 AM   #8834
M3Man03's Avatar
I use all stock Durango cups and have never had one pop... Because I did them right in the first place. Lol
Old 11-22-2012, 10:01 AM   #8835
nolimit208's Avatar
I did them also from the get go and still had issues, it really comes down to the driver, but once they pop off once they pretty much keep coming off. Atleast thats how it worked out with the 2 sets I had used before I switched them all out for a different brand.
St Ives RC Club B4Bandit Australian Racing 16570 09-23-2017 03:48 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
