Like Tree24Likes
Old 11-15-2012, 10:07 PM   #8761
SC10CHAMP's Avatar
They are both 65mm drive shafts mate. Just standard from the kit.
Go hard or go home
SC10CHAMP is offline   Reply With Quote
Old 11-16-2012, 03:07 AM   #8762
The Czechexican's Avatar
Originally Posted by Tunatsol View Post
Im running indoor carpet. mm4, gear diff with AE black carbide grease, 6/1.2 60wt AE front 6/1.2 50wt rear, stock springs, full long wheel base, 3/3 tow block, Schumacher low profile cut staggered fronts and Schumacher mini pin rears AKA red inserts front and rear, shocks laid down front and rear, ride height as low as it can go, shorty all the way back, links as long as they get. Youtube.com you can find a lot of racing at http://www.youtube.com/watch?v=L3VIXZ09Wz4 2wd mod buggy. Small track that can be vary technical. That's all i can think of right now PM for more info Im glade to help. And if this does not help Im sorry.
No it helps! Funny thing is that this is the direction my cars been going I was planing on uping the shock fluid this wkend front and rear and my links are all the way out too. I am also running 3/3 tow block and I was going to lay the shocks down as well.
Thanks Tunatsol! If I have any other Q's I'll PM ya.
:DEX210:
:DEX410V3:
MARCCA Carpet Racer.
"I Huff SXT 3.0"
The Czechexican is offline   Reply With Quote
Old 11-16-2012, 05:33 AM   #8763
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Anybody know what the stock pinion is on the RTR DEX210?
Fishhook
ewashburnaf is offline   Reply With Quote
Old 11-16-2012, 05:56 AM   #8764
Default Damper question.
Hey guys......how are most of you running your shocks? Bladder in or out?
cooperking is offline   Reply With Quote
Old 11-16-2012, 06:00 AM   #8765
Doughty's Avatar
If I remember correctly its 29/81 gearing
Chris Doughty - Team Durango - LRP - BETA Tires - Nibbo Design
Doughty is offline   Reply With Quote
Old 11-16-2012, 09:10 AM   #8766
Pvd brett's Avatar
everybody i know is running them out.
Pvd brett is offline   Reply With Quote
Old 11-16-2012, 09:55 AM   #8767
M3Man03's Avatar
No bladder, bled w/ the bleeder screw.
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 11-16-2012, 12:58 PM   #8768
gatrbite's Avatar
Send a message via AIM to gatrbite
Originally Posted by SC10CHAMP View Post
Hi guys. Ive just bought my a DEX210, and so far the build has been great. Until i realised that the left rear driveshaft is catching on the T-nut of the diff. As a result the arm hesitates when moved up and down. Any help would be much appreciated.
Cheers
Mine hit as well until i got everything together and set the diff correctly. It is no longer making contact.
Jeff Mohn
Studio 14 Photography www.studio14photos.com
Bumps and Jumps RC www.bumpsandjumpsrc.com
gatrbite is offline   Reply With Quote
Old 11-16-2012, 01:39 PM   #8769
Konich's Avatar
What are people running for slipper pads? Right now I run the Associated V2 pads and they seem to work a lot better than the durango and actually lay flat and fit the spur gears better.
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 11-16-2012, 02:52 PM   #8770
Trader Rating: 74 (100%+)
I'm running Garodisc on my 210.
Serpent USA www.serpentamerica.com, King Max Servos, Gens Ace, MIP, www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 11-16-2012, 03:33 PM   #8771
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
AE V2's...had new set laying around after I went through the oem pads.
kwiksi is offline   Reply With Quote
Old 11-16-2012, 06:15 PM   #8772
Default Tires
How many holes r u guys putting in barcodes rears and which inserts blue concepts or red aka?? Thanks
dolfns1 is offline   Reply With Quote
Old 11-16-2012, 07:28 PM   #8773
Trader Rating: 19 (100%+)
2 holes, 3/32-1/8 or so in size. Red AKAs are really good in there, Cush usually likes them best. Proline CC are nice too if you want a softer foam for lower traction surfaces, but they do wear out faster than the AKA.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 11-16-2012, 07:29 PM   #8774
Same here. With RW spurs- but use JC spurs on my stock sc with the Tresrey top shaft setup.
Old 11-16-2012, 08:31 PM   #8775
SC10CHAMP's Avatar
Ive set the diff so that the gear dosent spin when the outdrives are held. The driveshaft still rubs on the t-nut though.....
Go hard or go home
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
