Like Tree27Likes
Old 11-15-2012, 06:47 AM   #8731
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by jzwolen View Post
Looking for some more steering on my 210, running blinky. I just installed the brass front bulkhead, and it seemed to help, but it still seems to push in the corners. Im running RM3, barcodes in the back, scrubs in the front. full stick packs, no shorties. cant seem to cut those corners... more weight in the front?
What kind of track do you run on? With the tires your running sounds like indoor clay?
The buggy needs a shorty pack...try moving your std batt all the way forward. Take the battery stop out if you have to and butt it up against the servo. Don't add anymore weight.
Hudy guide is good check that out.
Try posting your complete setup.
Move rear hubs back
Less trailing
Stiffer spring in rear
Softer spring in front
I have a decent starting indoor setup here. There are many more on the site.
http://www.petitrc.com/setup/durango...CRCRC20121022/
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
Old 11-15-2012, 06:47 AM   #8732
sparkwraps's Avatar
Trader Rating: 34 (100%+)
Could be as easy as tire choice. Maybe flip the scrubs to so they are more aggressive or run Suburbs up front. Could be your rear tires are too hooked and less bit in the rear would balance the car out. Tire choice and balance of grip is a big part of handling.
| AFLAC Designs - Custom Airbrushing, in a hurry! | Jakes RC Pro Am - Topeka's Indoor Offroad Track! |
sparkwraps is offline   Reply With Quote
Old 11-15-2012, 06:48 AM   #8733
Trader Rating: 21 (100%+)
I had that issue too. I forget the link but it's out there. It talks about moving the front axles forward. I did that and it made a difference.
mulepic is offline   Reply With Quote
Old 11-15-2012, 06:48 AM   #8734
M3Man03's Avatar
You know, I thought so too, but I ended up removing the 20g weight under the servo I had in there and it got better.
Stiffen the rear springs, soften the front. Run low ride height, like 25mm or lower depending on the track.
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 11-15-2012, 07:43 AM   #8735
Trader Rating: 37 (100%+)
running indoor clay.
I'll try flipping the front tires, and moving the battery up to the server, there might be an inch of room or so there.
I was also thinking of trying MM4, since im running that on my DEST210 and i like the way it moves.
pretty much running this setup:
http://www.team-durango.com/pdf/setu...umann_2011.pdf
jzwolen is offline   Reply With Quote
Old 11-15-2012, 07:49 AM   #8736
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by M3Man03 View Post
Aluminum shock towers are a very bad I idea, I'd think.
I recently broke my first plastic shock tower on a pretty harmless looking flip.
I would suspect that the aluminum towers would bend REAL easy and then your shock setup is out the window.
That's why I'm moving to the CF ones. If you don't like the look, paint them. But they have the strength and they don't bend!
Are you serious? These are 6mm thick 7076 T6 aluminum and every bit a heavy duty as 1/8 machined aluminum shock towers. How the heck would the bend? I think the chassis would break in half before the tower bend. Just saying.....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is online now   Reply With Quote
Old 11-15-2012, 07:52 AM   #8737
M3Man03's Avatar
I've bent plenty.
Aluminum, even 7076 stuff, is bendable by the crashes that these experience.
Old 11-15-2012, 07:59 AM   #8738
I've bent plenty.
When have you bent a 6 mm thick aluminum shock tower on a 2wd buggy? I have also seen 1/8 e buggies bend aluminum shock towers, but only after horrible crashes, and only on cheaper Rc cars, certainly not on a mugen or x ray. Keep in mind that revolution design products are German.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-15-2012, 09:00 AM   #8739
Originally Posted by Synergy View Post
Chris. How's the drive working?
I havent had a chance to try it yet. The pic was just from the basic fitment. It still needs some shimming and change out the bearings. The topshaft im using is from an SAE car (not the losi) and the durango bearings are metric so i had to source some that will fit from mcmaster. I also need to cut a new topshaft spacer and mill down the bearing seat on the losi backplate to pull it closer to the motor mount plate.
Once i get it all squared away and ready to race ill post all the dirty details for anyone else who wants to do the same thing.
C2 Laser Designs - Custom Laser Engraving and Parts Cutting
Check us out on facebook www.facebook.com/c2laserdesigns
Team Venom
Culetto is offline   Reply With Quote
Old 11-15-2012, 09:10 AM   #8740
Trader Rating: 19 (100%+)
Originally Posted by 05PSD View Post
But there are still a large amount of rtr cars out there.
I think what he's saying is that they (JC/Proline) are holding off making a new body until it's seen what the most popular option is. No offense to any RTR car/owner, but it's generally accepted that racers buy kits, and that's who the new bodies would likely be aimed at. No company wants to make 3 separate bodies for a car if it's found a month later that one of them won't sell enough to justify the mold costs.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 11-15-2012, 09:29 AM   #8741
05PSD's Avatar
I get your point. I guess I'm hoping they'll settle on the +8 DIMEC chassis as I just swapped out my kit chassis and love the +8!
I actually had to add 20g to my car to make weight for our first race of the PNW Shootout Series.
EB48.4
SCT410
B6
05PSD is offline   Reply With Quote
Old 11-15-2012, 09:36 AM   #8742
t8rtot's Avatar
Trader Rating: 14 (94%+)
i doubt it.. don't for get TD is coming out with the alloy +8 car that is being tested by the team.
everyone is getting so wrapped up in the plastics..
Sfida
t8rtot is offline   Reply With Quote
Old 11-15-2012, 09:44 AM   #8743
But since TD went through the effort of creating a new body for the +8, wouldn't you think that even if they decided to release an aluminum chassis, it would be designed so that the +8 body would fit?
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 11-15-2012, 09:53 AM   #8744
05PSD's Avatar
This has a lot to do with the weight of the aluminum car. In 17.5 blinky, the car felt like a slug to me. With the plastic chassis the car definately transitions better IMO and is quite a bit lighter. For mod class the aluminum +8 chassis might be fine but I'm sticking with the plastic.
EB48.4
SCT410
B6
Old 11-15-2012, 11:03 AM   #8745
murky123's Avatar
jorn is only driving a +8mm alu chassis because it is indoor. and indoor you want stiffness
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
