Like Tree43Likes
Old 11-11-2012, 12:21 PM   #8686
How is everybody liking the +8 chassis over the stock one? And would it be a good choice form a med. to high bite indoor track?
umpy907 is offline   Reply With Quote
Old 11-11-2012, 01:06 PM   #8687
nismomike's Avatar
Here are a few more pics. When I got my kit, I assembled it per the instructions just to get a view of the baseline and geometry. After I assembled my kit per manual, I took out the front steering links and swapped sides Right to left and left to right so I would not have to pop off the ball cups but move the short ball stud to the knuckle and longer stud to the ackerman. 5mm washers on the ackerman. Note I used an aluminum ackerman which is 3mm thick and did not have to use a low pro nut. But the 4mm carbon fiber ackerman seems to need it per Flame56mx recommendation.
This is a pic at max uptravel. Setup is 1 degree camber 0 toe at 24mm ride height.
And this shows it bottomed out. Seems to only vary about .5 degrees from max droop to bottomed out. I'm pretty happy with that.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 11-11-2012, 01:26 PM   #8688
tobamiester's Avatar
Trader Rating: 281 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Originally Posted by flame56mx View Post
Not a problem, note you need a low profile nut on the bottom of the ballstuds under the rack, clearance is minimal..
yeah i noticed clearance appears a little reduced with the 8+ chassis.
tobamiester is offline   Reply With Quote
Old 11-11-2012, 03:08 PM   #8689
M3Man03's Avatar
Here's my first prototype at my own CF shock towers. I used the aluminum Exotek bits for the front, but will probably make my own eventually.
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 11-12-2012, 08:34 AM   #8690
Trader Rating: 57 (100%+)
Originally Posted by nismomike View Post
7. Front droop screws. Almost everyone shaves the droop tabs off of the front bulk head and takes the droop screws out of the front arms. They instead use 1-2mm of travel limiters in the front shocks.
Thanks for the list. I plan on getting this fairly soon. What 's the benefit of getting rid of the droop tabs?
shagino is offline   Reply With Quote
Old 11-12-2012, 09:34 AM   #8691
nismomike's Avatar
If you are running on dirt or clay, dirt will pack onto the top of the droop pad and change the amount of droop.
Old 11-12-2012, 07:43 PM   #8692
C-MAC's Avatar
Default +8 chassis with stock dex210 body
thought i would try my stock lenth body on the new +8 chassis. seems to work fine.
C-MAC is offline   Reply With Quote
Old 11-12-2012, 07:44 PM   #8693
C-MAC's Avatar
those prototype shock towers look good!
Old 11-12-2012, 09:11 PM   #8694
symmetricon's Avatar
Trader Rating: 27 (100%+)
quick question, is there any reason why there are no setups on the durango site for dirt using the 4 gear rear motor? Is it not worth using?
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-12-2012, 09:21 PM   #8695
Oasis's Avatar
Trader Rating: 36 (100%+)
I know no one seems to want to answer..but how is the +8 chassis working.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 11-12-2012, 09:33 PM   #8696
Trader Rating: 19 (100%+)
Maybe no one is running on really loose tracks. We were going to try it, but traction was awesome on our outdoor track with red ifmar studs. Cush never felt that more grip was needed.
XRAY, RC America, MOTIV, Sanwa, Arrowmax, Neverlift Racing Apparel
Jonny5ive Designs- by racers, for racers!
Jonny5 is offline   Reply With Quote
Old 11-12-2012, 11:07 PM   #8697
Trader Rating: 520 (100%+)
I really like it, the car seems much more forgiving. it seems there's more room for pushing the car little faster, rather than being on the edge..
flame56mx is offline   Reply With Quote
Old 11-12-2012, 11:58 PM   #8698
Oasis's Avatar
Cool..I just put mine on, I'm going to try mine out tomorrow, haven't seen any set ups yet for the plus 8 chassis..
Old 11-13-2012, 05:40 AM   #8699
I didnt change my setup from the std chassis.
Old 11-13-2012, 06:14 AM   #8700
kwiksi's Avatar
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
I ran the DIMEC20 this past weekend at CRCRC. Really liked it. The car felt great w/more corner speed. It felt much lighter on the track. Tried V2 Barcodes and the rear was all over the place. Switched to V1's and it was locked in. Will tweak setup when when I'm able to run again.
Here's a pic of the track I ran on. http://360.io/8nHJDZ. Full house that day with 160 entries! 5 heats of Mod buggy! Unfortunatly I was only able to get about a pack before qual and managed into the C main. I concentrated on learning the track. My fastest lap of the day was only a sec slower than the Amain winners fastest.
Good to see some fellow Durango drivers there as well! Hey Mallott, how did the buggy feel after you "threw everything at it"?
Thanks in 2017 to
Xray/RC America - JConcepts - Trinity - Sanwa - Hobbywing - Exotek - PT Racing Oils -Schelle
kwiksi is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16575 Today 12:44 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-08-2017 12:57 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 10:51 PM
