Like Tree24Likes
Old 11-10-2012, 07:36 PM   #8671
Mxer59's Avatar
Trader Rating: 114 (100%+)
Originally Posted by nismomike View Post
Maybe they have different parts trees for the pistons. I just got my kit from HRP and it didn't have blanks. Just 2 each of 1.2-1.3-1.4. Or maybe I got unlucky.
The mod does basically just relocate the washers. But it moves them from a 5 or 6mm stack on a piece of plastic to a 5mm stack onto a peice of aluminum. The reason I decided to do it was because of the multiple sources I got it from. After seeing the new triple at Glitch, seems like it might save me a few knuckles.
Ok on the Capt. America mod, you run 2mm washers under steering assembly
And how many washers on arms and knuckles if at 30 degree caster?
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 11-10-2012, 07:52 PM   #8672
nismomike's Avatar
I was told specifically 5.8 for 30 degrees. But 5.5 or 6 is more my speed. 4.8 for 25 degrees. I'm not gonna notice .2-.3 like some people can.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 11-11-2012, 06:32 AM   #8673
symmetricon's Avatar
Trader Rating: 27 (100%+)
So I am using a teking 10.5t geared 69/30, and it is tie to step up to a hotter motor, so I am gonna go with a reedy 8.5t. I have searched this thread and have found most are running around 87/25, can anyone confirm this is a good setup, or recommend a better one?
Also I have switched to the plus 8 carbon fiber chassis and although it needed a totaly new setup, i now have it handling very well. I does provide much better corner grip and is much more nimble due to the weight loss.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 11-11-2012, 08:09 AM   #8674
Am I wrong or is the capt. America mod to try to eliminate bump steer?
umpy907 is offline   Reply With Quote
Old 11-11-2012, 08:15 AM   #8675
Matt Howard's Avatar
it's to eliminate all the spacers you need to run in the stock configuration to eliminate bumpsteer
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-11-2012, 08:30 AM   #8676
Trader Rating: 520 (100%+)
The car had/has bump steer in stock form. Capt. figured out the formula where it was a non issue, and also did away with a pile of spacers, and an unusually long ball stud tower on the c-hub. I have used the same config for 25* and 30* caster, and have had no issues. I can post pics if someone needs to see the original models, it would be a cool sticky for this forum, if thats a possibility because it comes a lot..
flame56mx is offline   Reply With Quote
Old 11-11-2012, 08:41 AM   #8677
I it would awesome if Somebody could post before and after pics or maybe even a how to so everybody can see how to do it.
Old 11-11-2012, 08:51 AM   #8678
Trader Rating: 19 (100%+)
81/24-25 for an 8.5. Very mildly boosted, 10 degrees or less.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 11-11-2012, 09:22 AM   #8679
Here are some pics of mine, dirt and all..2mm washers on the rack 1mm washers on the c/hub. If you use other brand ballstuds, you may have to check the height of them compared to the Durango studs, they are possibly taller (the Losi studs are 1mm taller).
Old 11-11-2012, 10:04 AM   #8680
R/C Tech Charter Subscriber
Trader Rating: 30 (100%+)
Whats everyone doing for shock seals since their on BO everywhere?
Lowrance is offline   Reply With Quote
Old 11-11-2012, 10:04 AM   #8681
Much appreciated.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 11-11-2012, 10:11 AM   #8682
tobamiester's Avatar
Trader Rating: 275 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Thanks for posting the pics
tobamiester is offline   Reply With Quote
Old 11-11-2012, 10:56 AM   #8683
Not a problem, note you need a low profile nut on the bottom of the ballstuds under the rack, clearance is minimal..
Old 11-11-2012, 11:05 AM   #8684
Azagar's Avatar
I use these, trust me when I say you will never look at other o-rings again.
How are you liking the chassis so far flame56? Just got finished transferring my car over to it yesterday. Made a slight mod to it, added my own countersunk holes to the bottom for a new placement of the battery stopper since the spacing is slightly different from the aluminum chassis. Going to be running my battery smack dab in the middle now, since I moved my tekin rs to the rear. Removed my 30g weight up front and went to dark green springs for the rear which should help equalize where I use to run my battery before.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 11-11-2012, 11:20 AM   #8685
Talking
Thanks for the pics :-)
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
