Like Tree24Likes
Old 11-09-2012, 03:40 AM   #8641
murky123's Avatar
when I rebuild my shocks and fill em up with oil. I make sure that the piston is at the bottom before filling.
When I filled the shock en put on the shockcap ( without bleeder screw )
then I push the pistion upwards and stop when I have 8 or 9 mm left to go.
this wil result in 2 or 3 mm rebound
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 11-09-2012, 05:50 AM   #8642
tedstryker's Avatar
Trader Rating: 74 (100%+)
Hey guys i was reading about the diff issues..everybody is having myself included...so I switched it out to the gear diff....packed it with 2000 diff oil...man the car felt a lot better..more consistent and smoother...
I run a blue groove med - high bite track...
I would recommend the gear diff ...I'm not going back to the ball diff..
Just my 2 cents...
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 11-09-2012, 07:00 AM   #8643
jonski's Avatar
Trader Rating: 233 (99%+)
Anyone looking for a great set of new tires...
http://www.rctech.net/forum/r-c-item...5-shipped.html
jonski is offline   Reply With Quote
Old 11-09-2012, 07:15 AM   #8644
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
For the DIME chassis, which would be the one that is the most universal to use? I race where in general its extremely loose, so I am thinking the low temp one. But, in the winter I will be doing indoors carpet. Should I just use the alloy then for carpet in MM config?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 11-09-2012, 08:14 AM   #8645
M3Man03's Avatar
I'm sure you could just use the DIMEC20 (the harder) chassis in both.
Team Durango DESC210R / DEX210 / DEX410 / DETC410 / SJF01-F1 / Tamiya 416x / TE-Maxx 3.3 / OFNA DM-1e
M3Man03 is offline   Reply With Quote
Old 11-09-2012, 10:13 AM   #8646
Is your carpet you run on really high bite? For really loose dirt you would want the DIMEC so you had the flex and help with traction.
I'm in the same vote I run carpet in the winter.
chet is offline   Reply With Quote
Old 11-09-2012, 10:45 AM   #8647
Tech Legend
Cain's Avatar
thats the debate I am having lol. Though, the track also is VERY SMALL ... So maybe the alloy chassis would be better for now to just use and then get one specific for outdoor?
Old 11-09-2012, 12:00 PM   #8648
TAMAK's Avatar
Trader Rating: 28 (100%+)
My testing using stock chassis and DIMEC chassis:
Carpet: Stock chassis MM4
Indoor Loose / MED: DIMEC works great!
High Bite clay: DIMEC is too soft. DIMEC20 I hear is good tuning option.
I may order the DIMEC20 soon, I really wish I can get my hands on a +8mm alloy DEX210 chassis. I emailed RDRP and they say this beast is coming mid DEC...: http://www.rcdriver.com/rcd/index.ph...urango-dex210/
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-09-2012, 01:32 PM   #8649
Mxer59's Avatar
Trader Rating: 114 (100%+)
Sorry if dumb question is the car hardware standard or metric hexs? Thanks for the help
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 11-09-2012, 01:43 PM   #8650
TAMAK's Avatar
Metric
Old 11-09-2012, 06:25 PM   #8651
Redwings's Avatar
Originally Posted by zipperfoot View Post
I had something similar happen when i first built the car but found it had nothing to do with the tranny or slipper. I even went up a few teeth on the pinion but no top end. I found one of the axles was binding at the hub. With the wheels off everything seemed fine. But when the wheels were installed and tightened down i had major resistance. I had installed the Tresrey rear hexes just prior. Took out one of the shims on the axle at the hex, and did not crank the wheel nuts too tight. Problem solved. I even went down two teeth on the pinion. Plenty of top end.
Thanks for the info, I'll look into that one too just in case.
Redwings is offline   Reply With Quote
Old 11-09-2012, 08:34 PM   #8652
nismomike's Avatar
Originally Posted by blingy View Post
ok whhen you guys build your big bores do you go by the durango site or do you have your own way if you have your own way can you describe in detail b/c when i put 2mm under the bump stop wich equals 4mm like the dingo site says for the slim bores im getting hydro lock it would be nice if they put out a video of it
Another trick to use for those irritating times when you didn't put quite enough oil the shock and dont get any oil out of the bleeder. I filled up an old motor bearing Oil dropper with 27.5wt. Whenever i need more oil to properly bleed, I just put the dropper into the bleed hole and add oil till it comes out around the needle. 27.5 is a good medium. And since you are only adding a drop or 2, its not gonna be noticable even if its 50wt in the shock.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 11-09-2012, 08:36 PM   #8653
nismomike's Avatar
Damn, sorry for the enormous pic lol!
Old 11-09-2012, 08:43 PM   #8654
joelwhite's Avatar
Trader Rating: 55 (100%+)
Now thats a bright idea there! Thanks!
HEART OF A HUSTLER RACING TEAM
Trick Graphics--see spdrac430 on this forum for all your painting needs
Team Pit Racers-Fastest Guys In The Pits!
joelwhite is offline   Reply With Quote
Old 11-09-2012, 08:57 PM   #8655
nismomike's Avatar
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
