Like Tree27Likes
Old 11-07-2012, 05:08 PM   #8626
Redwings's Avatar
Originally Posted by Redwings View Post
I was having problems with my tranny over the weekend. I'm running a ball diff right now and noticed that there was no power full throttle. I littery had to crank down the slipper in order to get any thing going. I replaced the balls in the tranny, plates and pads. Still tring to figure out what is going on. verything was taken out, cleaned lubed and rebuilt as instructed. i'm stumpted. Please help
Originally Posted by Randy_Pike View Post
Make sure you're thrust bearing snap ring is installed properly.
Thanks Randy, Ill give that a shot, for now I have changed the ball diff for a gear diff. I'll see how that goes.
Redwings is offline   Reply With Quote
Old 11-07-2012, 08:25 PM   #8627
zipperfoot's Avatar
Trader Rating: 16 (100%+)
I had something similar happen when i first built the car but found it had nothing to do with the tranny or slipper. I even went up a few teeth on the pinion but no top end. I found one of the axles was binding at the hub. With the wheels off everything seemed fine. But when the wheels were installed and tightened down i had major resistance. I had installed the Tresrey rear hexes just prior. Took out one of the shims on the axle at the hex, and did not crank the wheel nuts too tight. Problem solved. I even went down two teeth on the pinion. Plenty of top end.
zipperfoot is offline   Reply With Quote
Old 11-07-2012, 08:57 PM   #8628
nismomike's Avatar
Okay I am making the transition to Team Durango and have started with the buggy first. I got the +8mm chassis, aluminum ackerman, and TDR 3 degree aluminum FR hanger. Now my question is, the hanger is 0 anti-squat, how can I adjust that? Obviously just using spacers will not work right. Can I mill the RR hanger? If so does anyone know how much will get me at 2 degrees?
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 11-08-2012, 08:21 AM   #8629
Are you talking about the rear anit-squat? If so you can just run the 0 degree and put washers under it to change anit-squat. I messured it a while back I think its 1mm per anit-squat. Just messured the stock ones to know how much you need to add to change it.
chet is offline   Reply With Quote
Old 11-08-2012, 08:22 AM   #8630
Anyone know off hand the sizes of the stock 6 hole pistons like 1.3mm etc?
thanks
Old 11-08-2012, 08:29 AM   #8631
Trader Rating: 62 (100%+)
I believe it is 1.3 and 1.2mm.
TEKNO RC * TLR * EXOTEK
patrick is offline   Reply With Quote
Old 11-08-2012, 08:33 AM   #8632
nismomike's Avatar
Yes I meant RR. So if I have an aluminum front 3/3, and an aluminum 3 RR hanger, then shiming the rear up 1mm would give me 2 degrees anti squat, and 2mm of shims would give me 1 degree anti squat. Am I understanding this correct?
Old 11-08-2012, 09:05 AM   #8633
I just checked its written on them really small 1.3's and 1.2's it comes with. I thought it came with 1.4's too, guess I was wrong.
Old 11-08-2012, 09:08 AM   #8634
I'm not 100% on that, I've just used a 0 anti squat and shimmed it up at the front only to add anti-squat.
You would of been better to get teh 0 anti-squat and done it that way. If you start adding it to the rear the changes it, I would think it makes it like I losi 22 high roll center?
Sorry man I thought it was a 0 anti-squat block you had
Old 11-08-2012, 10:18 AM   #8635
rcjunky1's Avatar
Theoretically running the 3/3 front block and the stock rear block, shimming the back up 1mm would give it 1.5 anti squate, raise it 2mm for 0 anti squate, doing that would also raise the roll center which might be good on high grip tracks, something to give a try if there is clearance.
Official distributor of Dan-O-Mite Custom Parts- Durango 210 RF pivot blocks
Andrew Butters' Burghgraef
Team Durango Canada
Great Hobbies, Hobbico, Skyrc, Exotek
rcjunky1 is offline   Reply With Quote
Old 11-08-2012, 10:54 AM   #8636
MikeFriery's Avatar
Trader Rating: 19 (100%+)
since the 210 transmission bolts to the front pivot block, adding shims underneath it changes the angle at which your transmission sits...
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 11-08-2012, 11:08 AM   #8637
nismomike's Avatar
Cool thanks guys. And I'm still waiting to hear from you Friery. Check your PM and your FB.
Old 11-08-2012, 08:26 PM   #8638
ok whhen you guys build your big bores do you go by the durango site or do you have your own way if you have your own way can you describe in detail b/c when i put 2mm under the bump stop wich equals 4mm like the dingo site says for the slim bores im getting hydro lock it would be nice if they put out a video of it
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 11-09-2012, 12:52 AM   #8639
Azagar's Avatar
Exactly this, this is something I discovered a while back when I thought I could make use of the many 0/3 I had collecting dust. The transmission case will not sit flat to the chassis if you add any amount of shims.
Team Durango DEX210
Avid | AKA | Exotek | Jconcepts | KO Propo | Lunsford | Tekin | Turnigy Nano-tech
Azagar is offline   Reply With Quote
Old 11-09-2012, 01:26 AM   #8640
Pvd brett's Avatar
when bleeding your shocks, do you get oil coming out of the bleed hole in the cap? make sure you are putting enough oil in the shocks when building, also make sure you work the piston up and down prior to trying to bleed just to make sure oil gets under the piston and everything moves right.
To answer your question, i build all my shocks according to the TD website tips.
Pvd brett is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16572 10-14-2017 01:35 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
coaltrain
