Like Tree24Likes
Old 10-30-2012, 11:39 PM   #8491
nismomike's Avatar
Originally Posted by zipperfoot View Post
I made the same switch. Very happy so far. I bought all the usual stuff, arms, towers, wheels, and never needed them so far. For me it was the odd unexpected things that broke. Inner rear camber mount which requires a new tranny. Gear cover cracked, rear hub ball stud pulled out, front ball stud cracked in half, RF hinge pin holder, hinge pin bushings.. because if a hinge pin comes out the bushing will NOT be found on a dirt track.
I am slowly building an arsenal of parts because no one stocks them in my area. I started to accumulate, o-rings, washers, nuts, shock parts, shafts, hinge pins, hubs, bearings. May not need them but if they break you cant use parts from other brands except maybe bearings and screws and nuts.
I bought the Avid spring set front and rear. Running red and red, or yellow front, red rear. 4 hole pistons, 1.3mm.
Check with Joe at the Team Terribles store in Mesa. He just got in all the Durango parts for every kit. And thanks for the tips!
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 10-30-2012, 11:41 PM   #8492
onekiwi's Avatar
Whats Jörn using for turnbuckles and cups?
Lunsford maybe?
Some tips.
Tresrey have a camber mount that can be used if the housing breaks and has more adjustability
Use alu spacer/washer if you have to on that mount and fill the other hole with a grubscrew.
The alu washer will help with not crushing and abeling the stud to move same with the filled hole.
XB2 CE
XB4 16
Sanwa
Hobbywing
#kiwipaint on facebook
onekiwi is offline   Reply With Quote
Old 10-31-2012, 04:34 AM   #8493
coaltrain's Avatar
Originally Posted by Tdiddy View Post
This thread needs more pictures!
Fresh build, hitting the track for the first time on Sunday.
DEX210 DEX410 MIP-SCTE
coaltrain is offline   Reply With Quote
Old 10-31-2012, 05:56 AM   #8494
TAMAK's Avatar
Trader Rating: 28 (100%+)
Lunsford maybe?
Some tips.
Also look at how he mounts his inner steering ball cup. Further in.... This must reduce that pesky wiggle wheel at full steering lock? Those look like V1 cups.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 10-31-2012, 09:01 AM   #8495
Lonestar's Avatar
Hey guys
mine is 95% done for the winter season in MM4... what is a good suggested starting point for droop? the instructions are setup sheets are usually pretty vague on this... thanks!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 10-31-2012, 09:34 AM   #8496
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Mounting the links further inboard is going to change the steering in a few ways. Jorn is likely testing a few new parts on his car, that's his job
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 10-31-2012, 10:17 AM   #8497
Trader Rating: 19 (100%+)
Lunsford maybe?
Some tips.
Those are AE turnbuckles, and look like either sc10 4x4 ballcups or JC ballcups with holes drilled in them for ballstud access.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-31-2012, 11:37 AM   #8498
TAMAK's Avatar
Originally Posted by The Czechexican View Post
Can you please put up a list of all the parts you used to convert the hole camber steering link setup you have, cups, camber links.
thanks!
Here ya go!
ASC31293 (long head 10mm thread)
X2 front shock tower
X4 front hubs
X2 rear gearbox
short head:
x2 Ackerman plate 8mm ASC31289
x2 rear hubs 10mm ASC31290
So to do redo everything on my dex210 I ordered
ASC31293 x 4
ASC31289 x 1
ASC31290 x 1
Associated Setup W/ JC ball cups PN: 2026
Associated B4 Ti Turnbuckle set: PN: ASC1282
Old 10-31-2012, 11:43 AM   #8499
jackcarter3's Avatar
Is that a prototype chassis? It has aluminum spacers in the front......
Lunsford maybe?
Some tips.
jackcarter3 is offline   Reply With Quote
Old 10-31-2012, 11:46 AM   #8500
TAMAK's Avatar
Yes, its a custom +8mm alloy chassis that utilized the plastic side pods from the original car. That also allows the use of aftermarket bodies. Only 8racing and Tresrey make a carbon version of that +8mm chassis. I am hoping an alloy +8mm version comes out soon and does not cost twice as much as an 1/8th scale chassis....
Old 10-31-2012, 11:50 AM   #8501
The carbon version is no longer available.
Old 10-31-2012, 12:01 PM   #8502
TAMAK's Avatar
Thats news to me... I dont see it on the Tresrey USA site either. Tresrey uses 8 racing and is still on there site: http://www.8-racing.de/shop/carbonch...&category_id=1
And Tresrey Japan: http://tresreystore.com/SHOP/OL_TYTD127.html
Old 10-31-2012, 01:09 PM   #8503
We were having some issues with the +8 cf chassis- after a few months of use Cush broke one, then another team driver did as well in the same place. Cush then broke his replacement chassis on the first raceday with it. Rather than sell something with potential issues the product was pulled until either the issue is resolved or a better replacement option is available. There was no disputing that the +8 chassis was beneficial in most applications (Cush still prefers the short car on tight tracks), but we simply couldn't continue to offer something that was found to be flawed.
Old 10-31-2012, 01:21 PM   #8504
It would've been cool if that billet tresrey chassis was plus 8.....
Old 10-31-2012, 01:34 PM   #8505
Tdiddy's Avatar
Send a message via Yahoo to Tdiddy
More pictures!
I'm really proud of how my paint scheme looks on this car.
Mark Thomas
Really cool since 1975.
Tdiddy is offline   Reply With Quote
St Ives RC Club B4Bandit Australian Racing 16564 08-19-2017 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
EbbTide
