Like Tree23Likes
Old 10-30-2012, 12:34 PM   #8476
Trader Rating: 27 (100%+)
Originally Posted by Cain View Post
Are the springs colored as far as the entire spring or is there an indicator on the spring that is a different color?
There is a colored marking at one side (top/bottom) of the spring.
Edwin Hartman
Tekno RC Regional Team Manager - Southern Midwest region
Sponsors: Tekno RC - Pro-Line Racing - Tekin - LutzRC - O'Donnell Racing Fuel - TrakPower - Advantage Racing Products - Futaba - Sumo Racing
ehartman_49348 is offline   Reply With Quote
Old 10-30-2012, 01:15 PM   #8477
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Originally Posted by nismomike View Post
Switching from AE to Rango. Need a list of spares besides the obvious. Got 3 sets of F/R arms, 2 sets of F/R towers, 3 sets of wheels, and the 210 in my cart. Need to know what spring packs and tuning items as well. Thanks guys!
I wouldn't go overkill on the arms or towers. One set each would do. The car is a tank. I have one set each NIP collecting dust. Only thing I've ever broke was a rear tower in Dec of last year. Landed freakishly on my lid.
Springs I'd get drk blue, drk green, black for front. Rears drk blue, drk green and black.
kwiksi is offline   Reply With Quote
Old 10-30-2012, 02:47 PM   #8478
Trader Rating: 38 (100%+)
Originally Posted by jzwolen View Post
Yes:
1. RPM long ballcups
2. AE TC6 ballstuds
3. Stock Durango links
you may need to swap the rear hubs around for clearance.
like these? http://www.amainhobbies.com/product_...Associated-TC5
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 10-30-2012, 04:25 PM   #8479
Cream's Avatar
Originally Posted by Tdiddy View Post
This thread needs more pictures!
Nice choice of towers
You too TAMAK
Cream Extreme R.C.
http://www.oople.com/forums/forumdisplay.php?f=219
Cream is offline   Reply With Quote
Old 10-30-2012, 06:11 PM   #8480
Send a message via AIM to trashedmaxx
Set up in RM4 for outdoor racing. Just switched it back to RM3 for indoor recently. Waiting for the new plastic +8mm chassis.
Mike Barrett
www.BFastrc.com
www.arcshobbies.com and Raceway
trashedmaxx is offline   Reply With Quote
Old 10-30-2012, 06:41 PM   #8481
The Czechexican's Avatar
Originally Posted by TAMAK View Post
Can you please put up a list of all the parts you used to convert the hole camber steering link setup you have, cups, camber links.
thanks!
:DEX210:
:DEX410V3:
MARCCA Carpet Racer.
"I Huff SXT 3.0"
The Czechexican is offline   Reply With Quote
Old 10-30-2012, 06:43 PM   #8482
nismomike's Avatar
Best spur gear for 13.5 blinky? I see its a 2.6 tranny like the B4. I'm geared 31/69 now, so 32/75 looks like the ticket.
Thanks to my 2013 sponsors!
*Team Durango~Pro-Line~MIP~RDRP~Futaba~Boca Bearings*
*Hacker Electronics~Muchmore Racing~O’Donnell Racing Fuel~O.S. Engines*
nismomike is offline   Reply With Quote
Old 10-30-2012, 08:38 PM   #8483
vazzo's Avatar
Trader Rating: 100 (100%+)
Hi guys
Anyone using those after market shock pistons? The Deleon machined ones? Which way to they go in lol rounded edge down?
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 10-30-2012, 09:10 PM   #8484
Is that servo a 1257 tg??? Thanks
dolfns1 is offline   Reply With Quote
Old 10-30-2012, 09:42 PM   #8485
ekt
ekt's Avatar
Looking at the picture, yes.
ekt is offline   Reply With Quote
Old 10-30-2012, 09:43 PM   #8486
Trader Rating: 19 (100%+)
thanks!
Post 8464 on the previous page he listed everything.
Serpent America/Desoto Racing- www.serpentamerica.com
TrakPower Speed Equipment- www.trakpowerusa.com
B Fast RC Performance- www.bfastrc.com
Futaba | Strictly R/C- Norridge, IL
Thank you all for the help and support!
Jonny5 is offline   Reply With Quote
Old 10-30-2012, 09:44 PM   #8487
P6
Originally Posted by vazzo View Post
Hi guys
Adrian
yes the tapperd side or rounded side goes down so it will allow it to rebound faster
P6 is offline   Reply With Quote
Old 10-30-2012, 10:16 PM   #8488
P6
hey i know u mess with shock pistons i have new shocks for my 4x4 sc i got chassis slap with 40wt 4 hole front from a 12" drop and 50wt 4 hole rear the pistons are 11mm diameter dual taper im pretty sure 1.0 size hole would it be smarter to go up in size maybe a 1.1 4 hole 50wt front and 3 hole 35wt rear maybe go up to 1.3 hole and test weights or should i find pistons with one side taper or no taper
Old 10-30-2012, 10:50 PM   #8489
zipperfoot's Avatar
Trader Rating: 16 (100%+)
Originally Posted by M3Armand View Post
Which AE ballstuds? The 8mm or 10mm? The "short neck" or the "long neck"?
I used long neck all around.
Front: 10mm inner camber and outer camber. 10mm steering hub, 8mm steering rack.
Rear: 10mm inner camber, or 8mm inner camber with carbon plate. 10mm rear hub, with lock nut just in case.
Used the ti-nitrate AE studs with Jconcepts cups and stock turnbuckles. No issues at all.
zipperfoot is offline   Reply With Quote
Old 10-30-2012, 11:02 PM   #8490
zipperfoot's Avatar
I made the same switch. Very happy so far. I bought all the usual stuff, arms, towers, wheels, and never needed them so far. For me it was the odd unexpected things that broke. Inner rear camber mount which requires a new tranny. Gear cover cracked, rear hub ball stud pulled out, front ball stud cracked in half, RF hinge pin holder, hinge pin bushings.. because if a hinge pin comes out the bushing will NOT be found on a dirt track.
I am slowly building an arsenal of parts because no one stocks them in my area. I started to accumulate, o-rings, washers, nuts, shock parts, shafts, hinge pins, hubs, bearings. May not need them but if they break you cant use parts from other brands except maybe bearings and screws and nuts.
I bought the Avid spring set front and rear. Running red and red, or yellow front, red rear. 4 hole pistons, 1.3mm.
St Ives RC Club B4Bandit Australian Racing 16564 Yesterday 05:06 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
